5
ROM [ROM][6.0.1_r3][BACON][OPTIMIZED]RESSURRECTION REMIX M [UBER-GCC 5.2][CM13]
  1. vaishakh
    Gingerbread Feb 8, 2016
    vaishakh , Feb 8, 2016 :
    Use Tugapower. Awesome battery life without any tweaks
  2. tye359
    Ice Cream Sandwich Feb 8, 2016
  3. venkatg.net
    Froyo Feb 8, 2016
    venkatg.net , Feb 8, 2016 :
    Yes it works with Backup and Restore functionality. I haven't tested the encryption or Decryption and it also flashes the Modem & Firmware properly.
  4. tye359
    tye359 , Feb 8, 2016 :
    Yeah, just tried it tonight, seems to take quite a bit longer than 2.8.6 though?
  5. delpinsky
  6. semper80
    Ice Cream Sandwich Feb 9, 2016
    semper80 , Feb 9, 2016 :
    UPDATE
    ResurrectionRemix - v5.6.3 - Marshmallow 6.0.1_r13
    Android Marshmallow 6.0.1_r10-> 6.0.1_r13 -FWB: Status bar header font style -FWB: Even more fonts to LS clock -Hide Lockscreen clock & date
    -FWB: Notification Header Customizations -SystemUI : 3G Icon Instead Of H+ Switch -Custom header: Add shadow to more TextViews -QS: Selinux Switch Tile -QS: App picker Tile -RR logo Location -Breathing SMS -SystemUI: Double tap to sleep anywhere on the lock screen -NavBar: Add Some More Buttons [ camera,Screenshot,Kill Task, Pie,Torch,RR --config,App picker, screenrecord, Immersive Mode] -SystemUI: HeadsUp whitelists -SystemUI: HeadsUp blacklists -HW keys tweaks -FBW: Add DancingScript / ComingSoon / NotoSerif to Statusbar Temp -FBW: Add DancingScript / ComingSoon / NotoSerif to Statusbar Clock -Make task manager button themeable -Hide arrows in network traffic indicators -Qs : Improve Navbar Tile Logic
    SystemUI: handle when brightness slider is hidden -SystemUI: don't add already attached qs tile pages
    -SystemUI: smoother tile transitions when moving to 1st row -SystemUI: improve tile caching mechanism -Lockscreen fonts: set correct default value
    Make lights out mode of navigation bar consistent to normal mode.
    -SettingsProvider : Don't replay aosp defaults every boot
    -aapt: add check for untranslatable "string-array"s
    -pm: Fix ordering of parameters for sendPackageBroadcast.
    -allow priveleged phone state permission to be whitelisted
    -SystemUI: disable editing tiles while in lock screen
    -Clean Up QSpanel
    -SystemUI: make sure to expand all the way when flinging
    -SystemUI: initialize drag panel with proper column count
    -IMS: Add Ims reason info codes for supplementary service failures
    -IMS: Fix video call forwarding options issue
    -Add mapping string for call reject cause code 26.
    -SysUI: Listen for changes to LIVE_LOCK_SCREEN_ENABLED
    -SystemUI: Don't update if HeadsUp is disabled
    -Intent: Fix a NPE on readFromParcel
    -SettingsProvider: Add missing INTERACT_ACROSS_USERS_FULL permission
    -Taskmanager: Reduce Logging
    -Flip to Mute/Reject Call -SystemUI: add better hints when trying to delete edit tile
    -SeekBarVolumizer : Disable notification volume if RINGER_MODE_VIBRATE -Partially revert 'SOFTAP: implement SOFTAP new requirement in framewo
    -ZenMode : Update defaults for CTSVerifier
    -Tethering: Fix number of device connected
    -am: Don't take down activity process if target intent component is null.
    -Themes: Fix CMSetupWizard package name in ThemeService
    -Themes: def theme package is defined in CMSettings
    -Add keylayout for Xbox One controller
    -SystemUI: make online cpu color green for cpu overlay
    -Don't reuse weather controller before it's changed
    -Wifi tile: don't set items visible from non-ui thread
    -SystemUI: fix contracting qs settings page
    -allow whitelisting of ACCESS_KEYGUARD_SECURE_STORAGE
    -SystemUI: visually disable EditTile in lock screen
    -add routing for explicit call transfer
    -Battery: Show battery fully charged notification
    -Fix pattern visibility settings -Alarm: add missing closedir after opendir when searching for RTC
    -String update, change wording from "Mobile" to "Cellular"
    -Frameworks: Restart last task if last task is dead
    -SystemUI: Allow clearing recents tasks within recents button
    -Frameworks: Lockscreen blur fix & tweak
    -fw: Make sure to get the actual ringtone uri per subId.
    -nms: Actually allow smsRingtone to work.
    -SystemUI : Show create profile if user doesn't have one setup
    -Tethering: Turn off Wi-Fi Hotspot after inactivity -SELinuxTile: use runShellCommand instead of runSuCommand for getenforce -am: Handle potential NPE when activity info can't be resolved.
    -SystemUI: nuke broadcast tile from user tile list
    -base: fix window bounds for left hand navigationbar
    -SystemUI: add flashlight notification reminder
    -Themes: Process applied themes before boot finishes
    -Add FDN enabled related API
    -Themes: Get default theme from CMSettings
    -SysUI: Make sure LLS is enabled after inflation
    -Fix lockscreen disabling for MSIM.
    -SystemUI: update keyguard state when profiles disable keyguard
    -SystemUI: prompt for SIM PIN if lockscreen is disabled
    -systemui: notify everyone that lockscreen is not going to be shown
    -Profiles: Disable lock screen after boot
    -The DUT can't screen shot in guest mode
    -DocumentsUI: Expose appbar elevation value.
    -pm: Allow fall through for protected apps validator activity.
    -GlobalActions: Use circular user avatars
    -LiveDisplayTile : Update entries on locale changes
    -livedisplay: remove user hint notification when clicked
    -GlobalActions: Fix setting ringer mode in global actions
    -lights: Automatically generate an LED color for notifications
    -Remove leftover power menu profile resources -settings: Add preference for automagic LED colors -Settings: blacklist: update iconography
    -Fingerprint: do not error out when stopping to listen
    -ProtectedApps: add up navigation and fix action bar icons
    -All updates and Fixed From CM -Improved Translations -For More Info Track Github Acitivity
    -DUE TO CMS TOYBOX CHANGES ,SYSTEMUI RESTART HAS BEEN BROKEN . WE ARE STILL WORKING ON A FIX
  7. ElRobertson
    Gingerbread Feb 11, 2016
    ElRobertson , Feb 11, 2016 :
    After problems in the official nightlies and Sultans CM13 - I tried this one...
    My Summary after 1 day heavy using - Thats an AWESOME ROM!
    It included all features I was used to from Cyanogenmod:
    - NavBarArrows,
    - LiveDisplay,
    - Stock Non-Google Apps
    and even some more features like StatusBar customizing with Date, Network Up/DownloadRates and KernelManagement, ...
    I removed OmniSwitch, as I don't use it and also think it doesn't fit the Material-Design.;)
    So if someone is searching for a Marshmallow Rom - definitly try out this one guys!:)
  8. yoshpe
    yoshpe , Feb 11, 2016 :
    Agree. But battery life is meh at best.
    Idle isn't bad tho
  9. ElRobertson
    Sorry, I'm German...
    What do you mean with: "But battery life is meh at best." ?
    You think its good/long lasting or bad/short or you don't care ? :)
  10. yoshpe
    Its bad... Getting around 3-4 hours of SOT... Gettiing much more on other ROMs
    RikoMMXV and ElRobertson like this.
  11. Robert Jr
    Ice Cream Sandwich Feb 12, 2016
    Robert Jr , Feb 12, 2016 :
    Like? I love me some battery life
    Laamapalmu likes this.
  12. nishant.roy24
    Cupcake Feb 12, 2016
    nishant.roy24 , Feb 12, 2016 :
    AWESOME PROGRAM BUT THE ONLY PROBLEM IS IT DOES NOT SUPPORT CALL RECORDING WHICH IS ESSENTIAL FEATURE FOR ME
  13. yoshpe
    Gingerbread Feb 12, 2016
    yoshpe , Feb 12, 2016 :
    Heard good things about darkobas, sultans and im ok on tuga atm...
    Robert Jr likes this.
  14. ElRobertson
    ElRobertson , Feb 12, 2016 :
    lol :D My like was not related to the SOT!
    Of course I just liked/thanked him for his useful answer.
  15. Eddie71570
    Cupcake Feb 16, 2016
    Eddie71570 , Feb 16, 2016 :
    Bonjour, j'ai besoin de votre aide !
    J'ai installé la version de la ROM v5.6.0 sortit en décembre 2015. J'aimerais faire une update mais je ne sais pas si je dois flasher la toute derniere MAJ proposée ou alors toutes celles sortit entre temps dans l'ordre.
  16. S0bek
    Ice Cream Sandwich Feb 16, 2016
    S0bek , Feb 16, 2016 :
    Salut normalement après un wipe cache et dalvik tu dois pouvoir flasher sans aucun probleme la dernière version mais je ne le ferai pas pour des très vieilles versions, en général pas de souci ! Tu pourras toujours faire une restauration si jamais les choses tournent mal, mais n'hésite pas à faire un backup avant dans ce cas !
  17. Tuski98
    Donut Feb 24, 2016
    Tuski98 , Feb 24, 2016 :
    I installed the ROM but the "Google play services has stopped" message comes again and again on using Google apps also browser does not works plzzz help and there is no package installer to install apk I am on 13th Dec build
  18. Giuseppe90
    Ice Cream Sandwich Feb 24, 2016
    Giuseppe90 , Feb 24, 2016 :
    Do a clean install of the lastest build
    Download the last unofficial TWRP (2.8.7.0.7 materialized or 3.0.0.0) from here: https://www.androidfilehost.com/?w=files&flid=30332
    download the last RR build from here: https://basketbuild.com/devs/resurrectionremix/bacon
    download arm 6.0 nano gapps from here: http://opengapps.org/
    download the last stock ROM flashable zip, just in case...
    NOW...
    • Install the recovery via fastboot
    Code:
    fastboot flash recovery recoveryname.img
    fastboot reboot
    long press power button+volume down as soon as the pone reboot and now you are in recovery
    • do a nandroid backup including EFS (why not? :p)
    • wipe cache, dalvik/ART cache, System, Data (do not wipe internal storage)
    • Install ROM
    • Install Gapps
    • wipe caches and reboot.
  19. Antoine Vdb
    KitKat Feb 24, 2016
    Antoine Vdb , Feb 24, 2016 :
    Si j'étais toi je ferais un clean flash parce que avec tout ce qu'y a du changer entre temps un clean flash est recommandé pour éviter les bugs ;)
  20. RikoMMXV
    Honeycomb Feb 24, 2016
    RikoMMXV , Feb 24, 2016 :
    Best SOT I got were on Darkobas and TugaPower. I'm on TugaPower now and since their m35 update, the SOT time is around the same as Darkobas now. 5 to 6h15min at best, depending on use.
