39
[ROM][ALPHA] Paranoid Android 8.0.0-DEV - OnePlus 3(T)
  1. Imotep95
    Froyo Nov 21, 2017
  2. Jaizu
    Cupcake Nov 21, 2017
  3. phendrome
    Eclair Nov 21, 2017
  4. Edoardo001
    Gingerbread Nov 21, 2017
    Edoardo001 , Nov 21, 2017 :
    Coming from oreo stock, clean flash but phone reboot every 10 minute if is locked. And when I digit fast status bar goes down
    Can't get log cat, sorry
  5. bendel
    Cupcake Nov 22, 2017
    bendel , Nov 22, 2017 :
    Can't say about the reboots but I have the same issue when typing fast, it brings the status bar down
  6. Edoardo001
    Gingerbread Nov 22, 2017
    Edoardo001 , Nov 22, 2017 :
    Message
    I think that we are near to a stable build(even without aospa features). I faced only this two problems, for the rest system and ui seems to work like they should(for a beta).
    Useful information
    When I digit fast like i'm tapping with more than one finger, the status bar starts the pull down animation. but if i try to tap as fast as possible with only one fingers the problem doesn't appear.
    ps: i know that to be useful i have to post a logcat, i'm really sorry but for work i can't use this rom as daily, congratulation for this very good work. I hope to help maybe in the future with testing in a little more stable build.
  7. fabi280
    Eclair Nov 22, 2017
    fabi280 , Nov 22, 2017 :
    I don't have any reboots.
    But I also got the "fast typing notification bar occurs"-bug. It also presses the 1-Button of my softkeyboard quite often.
    Typing with two fingers is impossible. I've tracked it down to multi-touch in general - but usually you just use it while you're typing
    In this screenshot you can see, that there is a diagonal blue line - I guess nobody can draw such straight lines. Additionally there's also a vertical blue line on the left border of the screenshot. You can also see the tap-location in the top left corner - and also my 2 Finger Movements in the middle of the screenshot
    RKBD and sharmabharath199 like this.
  8. Imotep95
    Froyo Nov 22, 2017
    Imotep95 , Nov 22, 2017 :
    Alex you adult, gtfo with fake profiles. [e]1f602[/e]
    RKBD likes this.
  9. Edoardo001
    so there are problems with touch
    RKBD likes this.
  10. inffy
    KitKat Nov 23, 2017
    inffy , Nov 23, 2017 :
    Thread cleaned, lets stay on topic which is Paranoid Android 8.0
    Lets also remember that developers do this for free and on their "free time". No need to start asking why there isn't builds for ROM X .
    RKBD, theshinybeast and fabi280 like this.
  11. DJNeronight
    Cupcake Nov 23, 2017
    DJNeronight , Nov 23, 2017 :
    Flash nano or pico gapps
  12. elmkzgirxp
    elmkzgirxp , Nov 23, 2017 :
    Anybody else have their /data force encrypted even with Magisk flashed? I had a decrypted data and the patch for disabling force encrypt seemingly did not work, thus encrypting my data. But the catch is it failed in the midst of encryption and now I have an unusable /data partition and had to format it.
  13. Trilochan@86
    Froyo Nov 23, 2017
    Trilochan@86 , Nov 23, 2017 :
    Please share the update instructions video, Thanks
  14. katheria09
    Ice Cream Sandwich Nov 23, 2017
    katheria09 , Nov 23, 2017 :
    Sorry bro i dont have 3T i have 5
  15. Trilochan@86
    Froyo Nov 23, 2017
  16. Grarak
    Recognized developer Recognized Developer Nov 23, 2017
  17. Edoardo001
    Gingerbread Nov 23, 2017
  18. Edoardo001
    Edoardo001 , Nov 23, 2017 :
    in the last build google camera was not work... it's a bug or camera hal setting?
    #38
  19. fabi280
    Eclair Nov 24, 2017
    fabi280 , Nov 24, 2017 :
    You can't use the camera in 3rd-party apps that can normally directly access the camera.
    For example: WhatsApp (to connect to WhatsApp Web), Telegram (you can normally click on the first "picture"-icon to use the camera - or press Camera to use the default camera app, Barcode Scanner (ZXing).
    There also seems to be a problem regarding the battery history
    [​IMG] [​IMG]
    Which logs could help you in general in case of a random reboot?
    #39
  20. Edoardo001
    Gingerbread Nov 24, 2017
    Edoardo001 , Nov 24, 2017 :
    Also whatsapp message sound cracked in the speaker... can you confirm? here is the logcat of google camera crash
    [ 11-24 11:04:38.446 10340:10364 E/CAM_FatalErrorHandler ]
    Handling Camera Open Failure:
    java.lang.Exception: hki
    at cfh.a(Unknown Source:3)
    at cfm.a(Unknown Source:18)
    at hjq.a(Unknown Source:102)
    at hkn.a(Unknown Source:4)
    at hkf.a(Unknown Source:2)
    at hkb.a(Unknown Source:71)
    at hkb.a(Unknown Source:35)
    at hjo.onError(Unknown Source:18)
    at android.hardware.camera2.impl.CameraDeviceImpl$CameraDeviceCallbacks$1.run(CameraDeviceImpl.java:1791)
    at android.os.Handler.handleCallback(Handler.java:789)
    at android.os.Handler.dispatchMessage(Handler.java:98)
    at android.os.Looper.loop(Looper.java:164)
    at android.os.HandlerThread.run(HandlerThread.java:65)
    Caused by: hki
    at hjq.a(Unknown Source:99)
    ... 13 more
    [ 11-24 11:04:38.446 559: 9482 F//vendor/bin/hw/android.hardware.camera.provider@2.4-service ]
    Status.cpp:149] Failed HIDL return status not checked: Status(EX_TRANSACTION_FAILED): 'DEAD_OBJECT: '
    [ 11-24 11:04:38.447 10340:10364 I/CAM_OneCamera-1 ]
    Closing one camera.
    [ 11-24 11:04:38.448 10340:10340 E/CAM_FatalErrorHandler ]
    Show fatal error dialog
    [ 11-24 11:04:38.448 559: 9482 F/libc ]
    Fatal signal 6 (SIGABRT), code -6 in tid 9482 (HwBinder:559_3)
    [ 11-24 11:04:38.455 10340:10364 W/CAM_OneCamera-1 ]
    OneCamera failed to start!
    java.util.concurrent.CancellationException: Task was cancelled.
    at iuj.b(Unknown Source:12)
    at iuj.get(Unknown Source:27)
    at kk.a(Unknown Source:1)
    at ivs.a(Unknown Source:9)
    at ivu.run(Unknown Source:2)
    at iwj.execute(Unknown Source:0)
    at iuj.b(Unknown Source:0)
    at iuj.a(Unknown Source:92)
    at iuj.cancel(Unknown Source:38)
    at dvb.close(Unknown Source:30)
    at hib.close(Unknown Source:61)
    at hjp.a(Unknown Source:65)
    CameraDevice closed.
    I've tried to upload the log, but after finishing uploading i can't see it here
    Edit: Another bug, when during call i attach headphones to the phone, after 10 sec i can't ear and people can't ear me
    #40
