22
[ROM] Havoc OS [OP 3/3T]
  1. elanglois
    Lollipop May 24, 2018
    elanglois , May 24, 2018 :
    3T but my bf has a 3 and just switched to this ROM.
    I did find a single white-LED-of-death issue. The author of the kernel mentioned that the version built into the ROM was a bit old and advised a kernel update. So far so good.
    Their is a rumor that the author doesn't update ROMs, just makes a new thread with a new ROM. We'll see what happens. I hear EAS for Oreo is making progress, so maybe we'll have some EAS options soon.
    Sun90 likes this.
  2. Sun90
    Starting Point Expert Community Expert May 24, 2018
    Sun90 , May 24, 2018 :
    The EAS for Oreo thingy is a good news.
    Do pls update the battery behavior on the op3 with this rom too.
  3. laupuy
    Honeycomb May 24, 2018
  4. elanglois
    Hmm ... DU doesn't have an XDA presence so they are hard to follow, but ... they legally have to provide kernel sources.
    It does look like they have an EAS kernel! Know what that means? Expect a DU review soon [e]1f603[/e]
    laupuy likes this.
  5. Paschfire
    KitKat May 24, 2018
    Paschfire , May 24, 2018 :
    Just so you're aware, Dirty Unicorns uses Telegram and G+ .
  6. Paschfire
    KitKat May 24, 2018
    BeingIncog likes this.
  7. elanglois
    Yeah I know. Wanna kill your battery, just install Telegram. I'm not a fan. It's mostly noise and porn. And G+ is so scattered and unorganized. XDA is a LOT better.
  8. elanglois
    Yeah, I know [e]1f603[/e] I checked the kernel source myself. I'm just wondering if they are using work done by Render and Joshuous or if it's something else.
  9. laupuy
    elanglois likes this.
  10. elanglois
    Lollipop May 25, 2018
    elanglois , May 25, 2018 :
    I seem to have developed a slight drain somewhere, maybe something installed running in the background since I see 2.2% drain when idle, which is WAY more than normal. Usually 1.6% or so.
    Accubattery predicts almost 7 hours based on usage history. Today/now is ...
    That's at 66% used. So, that in theory could give me over 8 hours, nearly 9 since today has been a light usage day with lots of screen on time and no GPS use. Other days I'll have the GPS going and Bluetooth and heavy file transfers, stuff that eats more battery, which is why the Accubattery average is less.
  11. elanglois
    Lollipop Jun 5, 2018
    elanglois , Jun 5, 2018 :
    Another Battery screenshot ... constant use, no setting down phone, mostly web and contacts .... did not turn on battery saver until 10% remaining
  12. Sohaibahsan007
    Cupcake Jun 25, 2018
  13. elanglois
    Lollipop Jun 25, 2018
    elanglois , Jun 25, 2018 :
    Not likely to be ROM related. Uninstall Skype and install again
  14. fahad_maniar
    Gingerbread Jun 25, 2018
    fahad_maniar , Jun 25, 2018 :
    Are you on the latest build? Because it's kind of stable. Even i am experiencing fc of some apps. The dev has confirmed that it'll be fixed in the next update.
  15. Sohaibahsan007
    Sohaibahsan007 , Jun 25, 2018 :
    Yes, I'm on the latest build I tried Lineage OS which had bad battery performance and now havoc Os, Dash Charge is not working. charged only 50% since 1h:20 mint. At morning I charged it and it just gives me 10 hours and about every 2 mint 1% of the battery goes down.I'm going back to Orignal
  16. elanglois
    Lollipop Jun 26, 2018
    elanglois , Jun 26, 2018 :
    First, the chance of dash charge not working is slim to none. It's a kernel feature that has been in all OP3 kernels for nearly a year. Havoc uses Mady's kernel and it hasn't changed.
    Verify the charge current. Dash is working, but you have something burning away the juice as fast as it charges. Did you clean flash the build?
  17. _DEDSEC_
    Jelly Bean Jun 26, 2018
    _DEDSEC_ , Jun 26, 2018 :
    I was one of the first to try Havoc OS, a friend of mine told me it was made by Unleashed ROM. Like hell I knew what ROM that was. I booted it in my Brother's OP3, it bootlooped. I needed to format userdata to get it bootable. Then it booted for like 5m, I thought it would be worth it. But no, it was absolutely havoc! it's disgusting U.I, buggy UX, and performance Issues that required the dev to rebase to LOS. TBH, I hated that ROM so much, I wanted to report it for wasting my time ;_; But this is a great review though. ;)
  18. elanglois
    no idea why you would have to reformat your user data I've never formatted my data
    #38
  19. _DEDSEC_
    It was day one I guess. It wouldn't boot otherwise.
    #39
  20. adil.shaw
    Cupcake Aug 7, 2018
    adil.shaw , Aug 7, 2018 :
    My phone boots up in recovery when I restarted after flashing everything correctly and successfully
    #40
