22
[ROM] Havoc OS [OP 3/3T]
  1. elanglois
    Lollipop Aug 7, 2018
    elanglois , Aug 7, 2018 :
    Obviously you didn't do something right. You need to tell us what you did wrong
    #41
    adil.shaw likes this.
  2. adil.shaw
    Cupcake Aug 7, 2018
    adil.shaw , Aug 7, 2018 :
    elanglois
    Obviously you didn't do something right. You need to tell us what you did wrong​
    I can go step by step:
    I first went into bootloader mode through adb
    Next I booted TWRP using the command fastboot boot twrp.img and flashed TWRP package
    Then I booted into recovery and it worked fine and I was in TWRP
    I cleared system, user data, cache
    Next I flashed the Havoc zip file and then the GAPPS zip file.
    Then when I rebooted it simple loops back into recovery.
    Maybe it has to do with slots I guess (the partitions A and B) but I never tamper with them
    #42
  3. elanglois
    what A&B partitions?
    #43
  4. elanglois
    what phone do you have?
    #44
  5. adil.shaw
    Cupcake Aug 7, 2018
    Actually when I reboot into Slot A, I simply get a blank screen and my last resort is the MsM tool
    #45
  6. adil.shaw
    Cupcake Aug 7, 2018
    #46
  7. elanglois
    if you scroll up, this one is for the OnePlus 3. The reason your phone goes into recovery mode is you flash the OnePlus 3 ROM on your OnePlus 6. Next time please read before you brick your device
    #47
  8. adil.shaw
    Cupcake Aug 7, 2018
    #48
  9. BeingIncog
    Nougat Aug 29, 2018
    BeingIncog , Aug 29, 2018 :
    i don't know if you are around or not, it would be great if you answer my weird (cupcakeish) question(s)!!! what font it is and is it system wide???
    #49
  10. adil.shaw
    Cupcake Aug 29, 2018
    #50
  11. adil.shaw
    adil.shaw , Aug 29, 2018 :
    It must be Open Sans. No it isn't system wide
    #51
  12. elanglois
    Lollipop Aug 29, 2018
    elanglois , Aug 29, 2018 :
    It's Glacial Indifference, and yes it's System Wide. I modified the built-in font chooser APK to include this font.
    #52
  13. elanglois
    See post above
    #53
  14. BeingIncog
    Nougat Aug 29, 2018
    #54
  15. elanglois
    FYI, latest Havoc Oreo switched to LOS as a base and I didn't like it at all. The latest Havoc is now Pie/AOSP based, but I haven't tried it out yet since I'm happy running OmniDragon Oreo at the moment
    #55
    Dhiren Velari likes this.
  16. elanglois
    Lollipop Dec 17, 2018
    elanglois , Dec 17, 2018 :
    Update: New Havoc has matured and OmniDragon seems to spurt strange bugs over time. I'm now on Havoc, all Pie goodness, great experience so far ... can't comment on speed or battery yet.
    BTW - no decryption needed
    #56
    fahad_maniar likes this.
  17. BeingIncog
    Nougat Dec 17, 2018
    BeingIncog , Dec 17, 2018 :
    it's super buggy after every update/ota install =( home button does not work, etc...
    #57
  18. fahad_maniar
    Gingerbread Dec 17, 2018
    fahad_maniar , Dec 17, 2018 :
    Do give us update on the battery life as well. I would like to switch to havoc.
    #58
  19. elanglois
    No such for me at the moment. Those sound like issues with not wiping dalvik cache perhaps since youbsay its just after an update.
    #59
    BeingIncog likes this.
  20. elanglois
    Battery life can NOT be compared between users. Your usage and mine are not comparable.
    #60
