74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. LoneStar144
    Honeycomb Dec 6, 2015
  2. theshinybeast
    Marshmallow Dec 6, 2015
    theshinybeast , Dec 6, 2015 :
    Hmm, I tried the same thing and still no go. I´ll try again and see what happens.
  3. Soccerbob7
    Froyo Dec 6, 2015
    Soccerbob7 , Dec 6, 2015 :
    Awesome, got sultan up and running! Does anybody know what happened to the following two features?
    1. Don't have same volume for notification and ring tone
    2. Toggling system profiles through the power menu?
    Did these options move somewhere else because I can't seem to figure it out.
  4. NathDerbyshire
    Gingerbread Dec 7, 2015
    NathDerbyshire , Dec 7, 2015 :
    V1.2 work absolutely fine for me o_O
    theshinybeast likes this.
  5. NathDerbyshire
    I use 2.8.3.0 so I can use aroma gapps and its perfect for me, just use any twrp this ROM I'd way more stable and it should be fine.
    Soccerbob7 likes this.
  6. bhavinvis
    Ice Cream Sandwich Dec 7, 2015
  7. Jalil Fierro
    Jalil Fierro , Dec 7, 2015 :
    Developer options/root access/apps and ADB
  8. Adidz
    Adidz , Dec 7, 2015 :
    Hi guys , Sultanxda mentioned that he has reverted to old gps libs on the Dec 6th build. Can someone on that build check if this fixes the gps bug? (On previous builds it was showing the wrong location).
  9. Jalil Fierro
  10. jstepa
    KitKat Dec 7, 2015
    jstepa , Dec 7, 2015 :
    I have had no problems with GPS on any build, so maybe you try it and tell us?
    Yes you should be able to dirty flash with no problem...
    GhilS likes this.
  11. NathDerbyshire
    I don't think its recommended to dirty flash at the moment to many changes under the hood.
  12. jstepa
    KitKat Dec 7, 2015
    Any build newer than 11/24 is safe to dirty flash...
    GhilS likes this.
  13. siva-kumar
    siva-kumar , Dec 7, 2015 :
    Yes. The new update fixed GPS for me
    Adidz likes this.
  14. biltoad
    Honeycomb Dec 7, 2015
    biltoad , Dec 7, 2015 :
    Got strange bugs in the 6th dec build, can't make phone calls, and when I play music, the sound only come from the earpiece. The speaker on the bottom won't make any sound.
  15. csabreu
    csabreu , Dec 7, 2015 :
    Really strange indeed. KCal v1.2 installed and worked fine for me too, on the stock kernel.
  16. csabreu
    Not implemented yet on CM13 (I don't know if official CM13 have those already, but I doubt it). Those are CM features and SultanXDA doesn't add anything. You have to wait for upstream changes, if they will ever happen.
    jstepa likes this.
  17. swarup.siddharth
    swarup.siddharth , Dec 7, 2015 :
    that would be because of certain modules that allow you to view pictures on snap chat without a countdown and save pictures without notifying he sender. it lets you spoof locations as well.
  18. swarup.siddharth
    try flashify
    Soccerbob7 and theshinybeast like this.
  19. zapablast05
    zapablast05 , Dec 7, 2015 :
    If you still haven't gotten it to work, pm so I can send you the .apk I have that ended up working.
    No GPS issues for me. I had a major GPS location issue on 1 (300mi off). I clean flashed from 1 to 6 and now it's as accurate as it was on earlier builds.
  20. zapablast05
    I hope you guys are still flashing Sultan's CPU clock unlock after every build release. It still isn't part of the build. I was playing around with my phone last night and opened CPU-Z when I noticed my CPU max clock was 1.9Ghz. I went ahead and reflashed the clock unlocker, and now I have the full 2.46Ghz.
    I haven't checked the OP since early November, so if anyone needs that .zip, I'll post it here again. To install, just flash through recovery. No need to wipe dalvik/catch.
    GhilS likes this.
