74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. swarup.siddharth
    Honeycomb Dec 10, 2015
    swarup.siddharth , Dec 10, 2015 :
    had the same problem before using another rom on marshmallow.
    theshinybeast likes this.
  2. swarup.siddharth
    you clean flashing all the updates chief?
  3. h0aX
    h0aX , Dec 10, 2015 :
    Even I am not having this feature too on 06/12 build
    Some features don't work here too
    fswijoyo likes this.
  4. @punto
    Ice Cream Sandwich Dec 10, 2015
    @punto , Dec 10, 2015 :
    i will be trying layers that's why o asked.... thnk u.. by the way is there any problem of " white text on white background " on the above ? i guess i cud make u understand
  5. theshinybeast
    Marshmallow Dec 10, 2015
    theshinybeast , Dec 10, 2015 :
    No not all of them. Just did this one to welcome 6.0.1  normally I dirty flash most builds without incident.
  6. theshinybeast
    Yeah their might be a problem with purity yellow but Skyblue works really well.
    @punto likes this.
  7. @punto
    thnxxx will try....
  8. gaster
    Lollipop Moderator Dec 10, 2015
    theshinybeast and jstepa like this.
  9. zapablast05
    zapablast05 , Dec 10, 2015 :
    Have you tried a different GApps? I've been using BaNkS GApps without any issues.
  10. csabreu
    csabreu , Dec 10, 2015 :
    Just to clarify, I'm talking about the "swipe to the right" to show a menu for settings (shows a tiny cog wheel along the dots), not the "swipe to the left", which was around for a while, I know.
    That said, I don't remember seeing that settings menu on the 20151204 build, even on the 20151206, but I don't always explore that kind of things after each flashing. I must keep a closer eye on the official CM13 nightlies change logs from now on :)
  11. csabreu
    Now that you mentioned it, I never had a random reboot since day one (11/06) with each and every build. However, yesterday the history changed with a random reboot using the 20151209 build when I was finishing the installation of an app update and at the same time was opening the CM messenger. But until now, it was a one time event.
    GhilS likes this.
  12. csabreu
    Just to be sure you're doing everything right... You access that settings QS menu when you press the tile "Edit tiles" from the QS dropdown menu. Sorry if my post was uncalled for.
    GhilS likes this.
  13. tye359
    tye359 , Dec 10, 2015 :
    9-12-15 build has been fine for me, no FC or any other major issues. I have noticed that wifi can be a bit funny and disconnect/reconnect every few seconds though when waking the phone up (I have it set to always on)
  14. Shub91
  15. Nicolas_g134
    Gingerbread Dec 10, 2015
    Nicolas_g134 , Dec 10, 2015 :
    Strange, I dirty flashed from a clean flashed 1201 build and although it seems less smooth I do not face your Problems :s
  16. Jalil Fierro
  17. Shub91
    Shub91 , Dec 10, 2015 :
    My phone randomly rebooted twice. happened on 12/09 build never happened before @jstepa @69gm
    Jalil Fierro and Nicolas_g134 like this.
  18. SayMyName
    Jelly Bean Dec 10, 2015
    SayMyName , Dec 10, 2015 :
    Daaayum I was just about to flash the latest build 'thanks for the heads-up folks, hope the mess gets sorted out.
  19. zapablast05
    Ice Cream Sandwich Dec 11, 2015
    zapablast05 , Dec 11, 2015 :
    Ooohhhh yeah I don't have that, not on 06 or 09 lol
  20. Noitham
    Donut Dec 11, 2015
    Noitham , Dec 11, 2015 :
    Installed the latest rom few hours ago and faced 3 reboots already, am I the only one?
