74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. jstepa
    KitKat Dec 25, 2015
    jstepa , Dec 25, 2015 :
    If you would have just search this thread, you might have found this ,or several other posts like this, but I know it's pain to search...
  2. Areebanwar
    Honeycomb Dec 26, 2015
    Areebanwar , Dec 26, 2015 :
    I was asked to flash to 2.8.6.0, but I didn't because well like I said flashing the nightly and then the ROM worked.....temporarily. Anyway I will do that now..thank you so much :)
  3. werty2445
    werty2445 , Dec 26, 2015 :
    I keep dropping my cell signal every minute or so and its infuriating.Tried flashing oxygen os modem but that doesnt help. :mad:
  4. Azezo89
    Gingerbread Dec 26, 2015
    Azezo89 , Dec 26, 2015 :
    I had the same problem, I flashed the oxygen modem, I lost mobile and WiFi. Then I flashed the one plus firmware, and the ROM, now everything looks fine. Mobile signal stable.
  5. werty2445
    Link to firmware? Please. :)
  6. Azezo89
  7. Areebanwar
    @jstepa no good..I did everything on clean install..it worked..and later just to check I rebooted, had the same problem. :/
    Edit: now my mobile network keeps dropping..I flashes the oneplus firmware and yet the problem persists :(
  8. Areebanwar
  9. Jalil Fierro
  10. jstepa
    KitKat Dec 26, 2015
  11. SayMyName
    Jelly Bean Dec 26, 2015
  12. JayminVyas
    Ice Cream Sandwich Dec 26, 2015
    JayminVyas , Dec 26, 2015 :
    Can I flash the firmware without disturbing the running os? Or it needs a clean flash? I too have sometimes annoying network issues. Apart from signal dropping at times, it's going great!
  13. jstepa
    KitKat Dec 26, 2015
    jstepa , Dec 26, 2015 :
    Yes you can flash Firmware/ modem at anytime, no need for even wipe nothing.
    JayminVyas likes this.
  14. fgaurano
    fgaurano , Dec 26, 2015 :
    Have you tried using the latest build? 12/24?
    GhilS likes this.
  15. Dr. Indest
    Lollipop Dec 27, 2015
    Dr. Indest , Dec 27, 2015 :
    Anyone fix the gps issue?
    Tried many things to no avail. I even tried the gps status app and it works for a few hours before the issue presents itself again.
  16. JayminVyas
    Ice Cream Sandwich Dec 27, 2015
    JayminVyas , Dec 27, 2015 :
    GPS is not an issue in this ROM for me at all. For official cm13, I used faster GPS app, that was suggested by someone. That too fixed the issue well.
    In this ROM, even that's not needed.
  17. GhilS
    GhilS , Dec 27, 2015 :
    Not yet :) going to flash it today :)
  18. jstepa
    KitKat Dec 27, 2015
    jstepa , Dec 27, 2015 :
    New build!
    Changelog:
    December 27, 2015:
    ROM:
    *Latest upstream CyanogenMod changes
    *Reverted to older proprietary libraries (random data disconnects and reboots are fixed)
  19. jstepa
    KitKat Dec 27, 2015
    GhilS likes this.
  20. GhilS
    jstepa likes this.
