74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. GhilS
    Ice Cream Sandwich Dec 27, 2015
    tye359 and jstepa like this.
  2. Dr. Indest
    Lollipop Dec 27, 2015
    Dr. Indest , Dec 27, 2015 :
    When I update the rom via a dirty flash, the agps data gets erased. Do you know where it is located so I can make a flashable zip?
  3. SayMyName
    Jelly Bean Dec 27, 2015
    SayMyName , Dec 27, 2015 :
    Does anyone know how to enable call recording on this rom? I tried apps like ACR, which used to work on cm12.1, but it doesn't record calls anymore, I always get an error.
  4. JayminVyas
    JayminVyas , Dec 27, 2015 :
    Nopes, no idea mate! Have never gone much deeper into the system files, except for replacing the hosts file, and sometimes removing the nfc folder. And yeah, very recently, for disabling xposed, since 1 of the modules caused a bootloop. :D
  5. fabipro92
    Donut Dec 27, 2015
    fabipro92 , Dec 27, 2015 :
    Hi,
    I (clean) flashed the latest version but after I installed everything (apps, theme, xposed) I wanted to do a backup with TWRP. After that my phone stucks in a bootloop. Wiped cache/s, flashed latest version (27.12.), disabled xposed but no luck. Thats the second time I have that problem.
    Can anyone help pls?
    Thanks!
    FAbi
  6. werty2445
    Honeycomb Dec 27, 2015
    werty2445 , Dec 27, 2015 :
    Cell signal still dropping occasionally on the latest build.Clean flashed.Anyone can help me out here? I tried flashing OxygenOs Modem but no difference.
  7. JayminVyas
    There probably was a mismatch somewhere. Either some theme that wasn't compatible, or some app, or maybe if you had installed supersu as well. If not, try a full data wipe & flash again.... Ensure that all the data that you need is backed up somewhere outside your phone!
    I have flashed Hydrogen os modem that @jstepa shared 1 or 2 pages back. No issues with network yet. Almost a day has gone by since I flashed it.
    jstepa and fabipro92 like this.
  8. werty2445
    Will try
  9. werty2445
  10. JayminVyas
    Hydrogen os or H2 os modem, whichever is the term used there. That has been working well for me.
  11. werty2445
    I might try 44S modem first as that was perfect back in the kitkat days
  12. BrokeBaconLover
    BrokeBaconLover , Dec 27, 2015 :
    December 27, 2015:
    ROM:
    *Latest upstream CyanogenMod changes
    *Reverted to older proprietary libraries (random data disconnects and reboots are fixed)
    Omggg this version is so aweeesome <3 @Sultanxda
    Thank you <3
    xoxo
    jstepa likes this.
  13. JayminVyas
    Now I do not know if that causes any compatibility issues. I am yet to understand that part - whether modem versions has anything to do with OS version itself or not.
  14. werty2445
    What sort of issues? :eek:
  15. JayminVyas
    As I said, I have no idea actually. Whether an older version of modem will be compatible with such a newer version of Android. Someone needs to tell us here if that has any compatibility issues or not.
  16. bhavinvis
    bhavinvis , Dec 27, 2015 :
    @JayminVyas which carrier u are on?
    I wanted to flash H2OS firmware but i had simcard not detected error.
    Thou i am using twrp 2.8.7.0
  17. werty2445
    I guess I will be that someone
    JayminVyas and GhilS like this.
  18. xythiii
  19. jstepa
    KitKat Dec 27, 2015
    jstepa , Dec 27, 2015 :
    I think is safe to dirty flash, I flashed from 12/06 and all went well...
    xythiii and GhilS like this.
  20. GhilS
    GhilS , Dec 27, 2015 :
    Did a dirty flash too from 12-21 to 12-27, no problem so far :)
    xythiii and jstepa like this.
