74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. fabipro92
    Donut Dec 27, 2015
    fabipro92 , Dec 27, 2015 :
    You're right, maybe it was a theme oder an app.
    Thanks for your help!
    JayminVyas likes this.
  2. wordlife3
    Gingerbread Dec 27, 2015
    wordlife3 , Dec 27, 2015 :
    Using 1227. Clean flashed.
    Battery draining before 2 hrs.
    Screen is consuming 13% battery. Please help.
  3. jstepa
    KitKat Dec 27, 2015
    jstepa , Dec 27, 2015 :
    I don't think nobody can help you about this, screen (and games) are the most battery consuming things. Maybe lower screen brightness? Take off ambient display and adaptive brightness?
  4. hream41
    Froyo Dec 27, 2015
    hream41 , Dec 27, 2015 :
    This is the only peoblem i have in this rom.. While watching videos on full screen the i pull down the status bar.. This one shows up.. Anyone having this issue.? Help would be appreciated.. Peace
  5. JayminVyas
    Ice Cream Sandwich Dec 28, 2015
    JayminVyas , Dec 28, 2015 :
    Airtel 2G.
    OK, so I really didn't knew. But connecting the dots, u mean to say that there are no compatibility issues?
  6. werty2445
    Honeycomb Dec 28, 2015
    werty2445 , Dec 28, 2015 :
    So far so good.No issues
  7. dhaval1111
    Eclair Dec 28, 2015
    dhaval1111 , Dec 28, 2015 :
    I am not receiving notifications from Gmail or Outlook in the latest build. Any suggestions?
  8. wordlife3
    Gingerbread Dec 28, 2015
    wordlife3 , Dec 28, 2015 :
    Ambient display and adaptive brightness are already off after flashing. Brightness is also pretty low.
    I had changed DPI from 480 to 400 recently. Can that be a reason?
  9. juragan
    Cupcake Dec 28, 2015
    juragan , Dec 28, 2015 :
    Already update to the latest build.
    But why my browser (default browser) always error/crash when downloading something.
    If using another browser is fine.
    Does anyone has experience of it and has a solution to fix it.
    Thanks
  10. jstepa
    KitKat Dec 28, 2015
    jstepa , Dec 28, 2015 :
    I doubt it, but you can try...
  11. jstepa
    KitKat Dec 28, 2015
    I think that's due to aggressive doze. Go to settings >battery >tap three dot menu on the right top>battery optimization >show all apps. >find Gmail and Outlook select no optimization.
    GhilS likes this.
  12. GhilS
    GhilS , Dec 28, 2015 :
    Thanks for the tip :)
    jstepa likes this.
  13. se7enlyn
    se7enlyn , Dec 28, 2015 :
    20151227, i have no drain
    suggest reboot
  14. bmark240
    bmark240 , Dec 28, 2015 :
    On the latest couple of builds (24th/27th December) I am getting Error in Executing Update. Failed.
    I have wiped Cache,Dalvik Cache, OTA update and even Clean Flashed latest build zipfiles.
    It's a shame because I was loving this ROM.
    Anyone have the same issues. Maybe I need to flash an official CM13 nightly first, then Sultans build on top like I did when I first came to this ROM.
  15. dhaval1111
    Eclair Dec 28, 2015
    Thanks for the tip.... I hope it works
    jstepa likes this.
  16. jstepa
    KitKat Dec 28, 2015
    What is your TWRP version and Baseband?
  17. bmark240
    The TWRP version is 2.8.6.0
    Baseband version is DI.3.0.c6-00241-M8974AAAAANAZM-1
  18. megatomic
    megatomic , Dec 28, 2015 :
    Ok, I'm on board with this ROM. The stock CM13 nightly caused way too many random reboots for me.
    GhilS and jstepa like this.
  19. jstepa
    KitKat Dec 28, 2015
    Ok so it's nothing to do with TWRP or baseband, do you have screenshot of the error in TWRP?
    So you tried wiping everything but the internal storage and otg and then flash ROM and GApps + wipe Dalvik and cache?
  20. jstepa
    KitKat Dec 28, 2015
    Welcome aboard, no random boots or FC's for me on this latest build :)
    megatomic likes this.
