74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. bmark240
    Ice Cream Sandwich Dec 28, 2015
    bmark240 , Dec 28, 2015 :
    Yes. I got it to run despite the error.... I didn't have a boot animation, had random reboot, screen freeze & problems with downloaded files corrupting. I might clean flash cm13 as a base then wiping system & installing Sultanxda over it.
    Valeri_S_K and jstepa like this.
  2. tye359
    tye359 , Dec 28, 2015 :
    i still get wifi randomly disconnecting which is strange... even though it is set to 'always on'
    h0aX likes this.
  3. jstepa
    KitKat Dec 28, 2015
    jstepa , Dec 28, 2015 :
    I just use wifi when I need it, so it's not always on.
    But when it's on, no disconnects...
  4. h0aX
    Honeycomb Dec 28, 2015
    h0aX , Dec 28, 2015 :
    Facing similar problem.
  5. megatomic
    megatomic , Dec 28, 2015 :
    Thanks, and none for me so far. Once I get all my apps installed I'll transfer my SIM to my OPO for a real load test. :)
    jstepa likes this.
  6. tye359
    hopefully an update for this soon, not sure if it is to do with the firmware or something else in CM!
  7. Albarda
    Cupcake Dec 28, 2015
    Albarda , Dec 28, 2015 :
    I've a problem related tot Evernote
    A photo taking within Evernote will give black pictures. I've this problem since I installed Sultans rom. I didn't get this problem with the CM13 nightly.
    I reinstalled Evernote, which didn't solve the problem.
    Does someone has a suggestion to solve this?
  8. jstepa
    KitKat Dec 28, 2015
    Just installed (and removed) Evernote, no problems with pictures...
  9. Albarda
    Thanks for trying. I flashed the newest rom and reinstall Evernote. Still black pictures. Someone else with suggestions?
  10. Laamapalmu
    Jelly Bean Dec 28, 2015
    Laamapalmu , Dec 28, 2015 :
    Was there somewhere a changelog for the 27th update? Or does it contain anything else than random reboot fix.
  11. jstepa
    KitKat Dec 28, 2015
  12. f_reza
    Eclair Dec 28, 2015
    f_reza , Dec 28, 2015 :
    Hi,
    If currently on CyanogenOS 12.1 LP ROM (YOG4PAS3JL), then how can @Sultanxda's CM 13.0 MM ROM be installed AND also reverted back to YOG4PAS3JL, WITHOUT losing data such as call logs, SMSes/MMSes, saved WiFi SSIDs, and Firefox tabs?
    Thanks for your help!
  13. f_reza
    Eclair Dec 28, 2015
    And after going to @Sultanxda 's CM 13.0 MM ROM, would CyanogenOS account features like Locate, Remote Wipe, Lock Device work, @69gm ?
  14. qriusme
    qriusme , Dec 28, 2015 :
    Trying out 12/27 build - I was wondering about those random data disconnects.
  15. highdiver_2000
    Ice Cream Sandwich Dec 29, 2015
    highdiver_2000 , Dec 29, 2015 :
    Buy Titanium backup. Copy everything from your phone to your Windows machine.
    Install Backup and restore for SMS.
    Root your phone
    Backup everything and SMS
    unlock your bootloader
    Read opening post.
    f_reza and jstepa like this.
  16. highdiver_2000
    I am on 21 Dec. For the first time, tried out phototaking in Evernote. Works perfectly.
    Same goes for Whatsapp Web QR camera
    jstepa likes this.
  17. raiashu92
    Gingerbread Dec 29, 2015
    raiashu92 , Dec 29, 2015 :
    new baseband to be released in todays official nightly, hopefully random reboots will be solved.
  18. werty2445
    Honeycomb Dec 29, 2015
    werty2445 , Dec 29, 2015 :
    To anyone experiencing dropped cell signal and have been on 44S before,I recommend flashing the 44S modem. :)
    jstepa likes this.
  19. Alignof
    Cupcake Dec 29, 2015
  20. jstepa
    KitKat Dec 29, 2015
    jstepa , Dec 29, 2015 :
    What random reboots? No reboots with latest build 12/27
    theshinybeast likes this.
