74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. suskisunami
    Gingerbread Jan 2, 2016
    suskisunami , Jan 2, 2016 :
    ok sorry about that ahah but if i uncheck those things it will make something to my wifi ?? or it will run without any problems ?
    jstepa likes this.
  2. chitocr
    Honeycomb Jan 2, 2016
  3. jstepa
    KitKat Jan 2, 2016
    jstepa , Jan 2, 2016 :
    Wifi is just not on all the time, otherwise it will work fine
    suskisunami likes this.
  4. jstepa
    KitKat Jan 2, 2016
    I'm just about the worst person to ask battery life (SOT), I'm not an heavy user.
    For me it's all about idle time and that's like 1-2% for about 8 hours of sleep...
  5. tye359
    Ice Cream Sandwich Jan 2, 2016
    tye359 , Jan 2, 2016 :
    I get around 48 hours of usage and about 5 hours SOT; usually plug the phone in to charge at around 7-8%
    I don't do any gaming though so that might be different for you. Mostly just social media and WhatsApp
  6. Andas
    Andas , Jan 2, 2016 :
    Yo how to remove that shitty google search from home screen ?? Also how can I customize Messenger? I don't like it, and also don't want to use hangouts.
  7. chitocr
    chitocr , Jan 2, 2016 :
    Always 3G?. I dont play games xD.
  8. Andas
    Also how do I set lockscreen wallpaper ? Can't do that :S
  9. tye359
    I'd say about 70% WiFi, 30% 3G!
  10. jstepa
    KitKat Jan 2, 2016
    Shitty google search: Long press on empty spot on home screen, three dots up, Search bar->off
    Customize messenger and Hangouts, dunno...
    Two ways:
    1. CApps-ThemeChooser from: https://forums.oneplus.net/threads/zip-trimmed-capps.407375/
    Or:
    2. Put the image you want for the lockscreen in data/system/users/0 and name it keyguard_wallpaper
    In order to see those hidden folders, you would need a file browser that can show hidden files and folders. Reboot phone.
    GhilS likes this.
  11. Deactivated User
    Jan 3, 2016
  12. chitocr
    Honeycomb Jan 3, 2016
  13. highdiver_2000
    Ice Cream Sandwich Jan 3, 2016
    highdiver_2000 , Jan 3, 2016 :
    1. In Settings, Wifi, Advanced, set to never for Wifi on while sleep.
    2. Set your GPS to Device
    jstepa likes this.
  14. highdiver_2000
    I have tried that, not effective. So far the only that works is set GPS to device only.
    jstepa likes this.
  15. jstepa
    KitKat Jan 3, 2016
    jstepa , Jan 3, 2016 :
    1. I don't have this option? But if you mean keep wifi on in power-saving mode, I have this "always".
    This setting does not mean it's always on while sleep, rather than if device is on power-saving mode (batery low).
    2. GPS on high accuracy, although I only turn it on when I need it, it's not always on
    No wifi drain for me, but if you have set location on high accuracy and it's always on, that could explain it.
  16. yaltis
    Jelly Bean Jan 3, 2016
    yaltis , Jan 3, 2016 :
    Am i blind again?
    icant find a way to delete a single call i made ,from my call history.
    Any help?
  17. yaltis
    SOLVED
    Just figured it out. You do the same way as you did in lollipop. You just need to single click in the middle of the card, not the profile picture/initial and obviously not the phone icon, to get the details option. I was trying to long press or touch the profile picture. I guess I was trying not to call the number again.
  18. highdiver_2000
    In Settings, WiFi, Advanced, "Keep Wi-Fi on during sleep", set to never
    GPS, set to "Device" There are 3 choices "High accuracy, Battery saving, Device"
    https://code.google.com/p/android/issues/detail?id=189018#c209
  19. jstepa
    KitKat Jan 3, 2016
    What ever works for you, but like I said I have it set to always and GPS is set to high accuracy, no wifi battery drain for me. Plus you missed my points completely...
  20. csabreu
    csabreu , Jan 3, 2016 :
    Well I'm back after 1 week of holidays doing snowboard in Andorra. A few things have changed it seems... updated modem and WiFi firmware. I've to confess, so "much time" without flashing a ROM was getting unbearable. I left my beloved OP1 at home and took along my backup and smaller screened N4, in case I crashed on the slopes. Even after driving more than 1100 km and a few hours of sleep I had to install the latest build. Nothing like starting the New Year with a new build :) So far so good.
    GhilS, theshinybeast and jstepa like this.
