74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. Jalil Fierro
    Gingerbread Jan 4, 2016
    Jalil Fierro , Jan 4, 2016 :
    Hii, im on 27th build, and I want to flash 20160104 build, can I dirty flash or I need to do something strange?
    Also I have less than 3 hrs SOT, how can I change that? I play clash of clans and YouTube a lot.
  2. jstepa
    KitKat Jan 4, 2016
    jstepa , Jan 4, 2016 :
    I suggest to read at least previous page and OP before asking this kind of question...
    GhilS, JayminVyas and se7enlyn like this.
  3. jstepa
    KitKat Jan 4, 2016
    New build!
    Changelog:
    January 4, 2016:
    ROM:
    *Latest upstream CyanogenMod changes
    *Modem firmware is no longer built into the ROM (you can use the Lollipop modem if you had issues with the new modem)
    GhilS, theshinybeast and h0aX like this.
  4. Tholsen
    Tholsen , Jan 4, 2016 :
    Ambient display is disabled.
    I have neither priority or total silence enabled.
  5. se7enlyn
    Ice Cream Sandwich Jan 4, 2016
    se7enlyn , Jan 4, 2016 :
    strange, suggest a clean flash.
  6. tye359
    tye359 , Jan 4, 2016 :
    Uploaded to Google Drive now ;)
    GhilS and h0aX like this.
  7. werty2445
    Honeycomb Jan 4, 2016
    werty2445 , Jan 4, 2016 :
    Then who can? :eek:
  8. h0aX
    h0aX , Jan 4, 2016 :
    Folder link?
    Edit : I got it
  9. jstepa
    KitKat Jan 4, 2016
    Fair warning, settings FC's for me, so reverted back to 01/01
    Backup before dirty flash, do let me know if settings works for you
  10. Alexmoorlag
    Alexmoorlag , Jan 4, 2016 :
    Hey guys ( and girls ),
    I've encountered a problem with this rom.
    I use to update via ota, but since a couple of builds that doesn't work anymore.
    So I download the rom, try to dirty flash it, but then twrp encounters a problem so I can't install a newer version anymore...
    Anyone an solution?
  11. se7enlyn
    which build works for you?
    which build did you try to dirty flash?
    please read 1st page
    tye359 and jstepa like this.
  12. Alexmoorlag
    I'm on 27-12, it always worked, don't know what's going wrong
  13. se7enlyn
    December 30, 2015:
    ROM:
    *Switched to new modem
    *Modem firmware is now included in the ROM (you cannot change the modem)
    *New firmware is required to install this update (if you see an "oppo.verify_trustzone" error when trying to install this update, dirty flash the newest CM13 nightly and then dirty flash this update)
    JayminVyas and jstepa like this.
  14. Alexmoorlag
    Hmm ok, haha just came out of bed, still sleeping I think :)
    Do I have to reinstall all my apps if I flash both?
    And do I flash the nightly and right after the sultan's?
  15. csabreu
    csabreu , Jan 4, 2016 :
    You need to flash new firmware first. Dirty flash cm13 nightlies and then flash a newer build, like stated on the change logs.
  16. csabreu
    No need to reinstall all your apps. Just dirty flash a newer cm13 nightly and then the SultanXDA's build.
  17. Alexmoorlag
    OK, just installed, no sim card...
  18. Alexmoorlag
  19. Ne0x
    Ne0x , Jan 4, 2016 :
    Some people have issues with sim card and apn settings.
    Try to remove your current APN and just add a new one.
  20. Alexmoorlag
