74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. Alexmoorlag
    Ice Cream Sandwich Jan 4, 2016
    Alexmoorlag , Jan 4, 2016 :
    How can i do that?
  2. suskisunami
    Gingerbread Jan 4, 2016
    suskisunami , Jan 4, 2016 :
    How can I take a log from my error?
  3. theshinybeast
    Marshmallow Jan 4, 2016
    theshinybeast , Jan 4, 2016 :
    No settings FCs for me on 01/04 so far .In fact everything seems fine and dandy,so far.
    jstepa likes this.
  4. Ne0x
    Ne0x , Jan 4, 2016 :
    In "settings > cellular networks > Acces Point Names" then delete your current and add one.
  5. jstepa
    KitKat Jan 4, 2016
    jstepa , Jan 4, 2016 :
    Then it's clean flash time for me :(
    GhilS and theshinybeast like this.
  6. theshinybeast
    Hope I'm not too late but I've just had a couple of System UI FCs and an FC on settings:confused::(
    jstepa likes this.
  7. jstepa
    KitKat Jan 4, 2016
    Just clean flashed newest build, no FC's this far
    I have my 01/01 build backed up, so if FC's continues, I'll use that
    tye359 and theshinybeast like this.
  8. theshinybeast
    Yeah I've backed up 01/01 as well.I had 0 FCs on SlimSaber for weeks so if this keeps up....
    jstepa likes this.
  9. h0aX
    Honeycomb Jan 4, 2016
    h0aX , Jan 4, 2016 :
    FC's in few sections under Settings App!
    Thanks for your advice ;)
    jstepa likes this.
  10. windshear
    windshear , Jan 4, 2016 :
    A
    Are u trying to be a d.ck or what? Screen on Time, moron!
  11. tye359
    tye359 , Jan 4, 2016 :
    does anyone else have the issue where double tap to wake does not work, unlock the phone with the power button and when you go to swipe to unlock the screen goes off again? :D
    This is pretty rare, maybe once or twice a day...
  12. se7enlyn
    se7enlyn , Jan 4, 2016 :
    OK, I thought you wanted to show your wake locks. Your SOT is about average.
  13. gjegadeesh
    gjegadeesh , Jan 4, 2016 :
    That option itself disabled... :( i mean it's in non-editable mode..
  14. irobot007
    Froyo Jan 4, 2016
    irobot007 , Jan 4, 2016 :
    i have issues with the new Modem so i will stick with the old modem.
    Anyone got a link to the old Modem only - DI.3.0.c6-00241-M89744AAAAANAZM-1 zip file to flash?
    my idea is, since i got TWRP 2.8.7.0.5 which can flash modems, after flashing the modem ill just flash the TWRP version which cannot flash the modems and ill stick to that version flashing the updates OTA? any objections? Thanks in advance
  15. jstepa
    KitKat Jan 4, 2016
    All modems/ Firmwares I know, are listed here (there might be more)
    Do as you like, no objections ;)
    I don't know if it will work, or you could get trustzone error when flashing new build, but do test...
    irobot007 likes this.
  16. irobot007
    Froyo Jan 4, 2016
    well, the Sultan himself noticed, that there are some issues with a few carriers, so he wrote in the last changelog that the modem isnt anymore built in..
    jstepa likes this.
  17. jstepa
    KitKat Jan 4, 2016
    Yes modem is not in build anymore, but I'll bet that it needs H2OS Firmware order to flash, but you try an tell me.
    If it does not work, you should flash in this order, H2OS Firmware, ROM, your modem.
    Edit: If it works, you don't need to change TWRP version, because the ROM won't update Firmware/ modem, if it's not in ROM anymore...
  18. csabreu
    csabreu , Jan 4, 2016 :
    I've been running the latest 20160104 build since early morning (dirty flash) and everything seems fine. No settings FC until now. I've tested most of the menus, after reading some are having troubles. Where in particular are those settings FC occurring?
  19. jstepa
    KitKat Jan 4, 2016
    I did not even get to settings at all, now after clean flash no FC's at all for about 3 hours.
    Where do you get FC's, I'll try with my clean flash?
  20. Tholsen
    Tholsen , Jan 4, 2016 :
    It already is a clean flash :( might try clean flashing the 1/1 build, if a dirty wont work
