74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. yaltis
    Jelly Bean Jan 11, 2016
    yaltis , Jan 11, 2016 :
    OOTS
    random reboots.
    before your help i tryed to flash kitcat and also flashes the 44 s modem .
    with no use.NOW I CANT OPERATE ANY VERSION ON MY PHONE
    PLEAQSE HELP
  2. se7enlyn
    Ice Cream Sandwich Jan 11, 2016
    se7enlyn , Jan 11, 2016 :
    are you sure you have twrp 2.8.6.0 ?
  3. yaltis
    IFsomeone stupid as me messhed up her phone howcan go back lets say to loloipop or kit cat.ive tryed calulin version but no help .
    any KIT to start with?
  4. yaltis
    its writen multirom twrp 2.8.6
  5. se7enlyn
    don't worry, many ways to fix your phone
    have you tried using the fastboot method?
  6. yaltis
    whats that?
  7. se7enlyn
    you will need to connect your phone to a pc, you will need to download adb, twrp,rom. then you will need to flash files to the phone by issuing commands from the pc.....this is the fastboot method, but it will erase all your data and internal storage.
  8. yaltis
  9. yaltis
  10. rajaspardeshi
  11. jstepa
    KitKat Jan 11, 2016
    jstepa , Jan 11, 2016 :
    I don't use custom kernel, see Sultan's post on XDA
    "The included kernel is the most stable one for this ROM, and it is the only one that I will provide support for. Every custom kernel based off of mine, except for Phoenix Wright's kernel, completely removes any guarantee of stability that I worked very hard to achieve.
    Unless you have a reason to use a custom kernel, I wouldn't recommend it."
    rajaspardeshi likes this.
  12. Ne0x
    Gingerbread Jan 11, 2016
    Ne0x , Jan 11, 2016 :
    last build installed. No issues as no far. A lot of CM changes.
    Perfect like always
    GhilS, tye359, iriad and 2 others like this.
  13. tye359
    GhilS and h0aX like this.
  14. 69gm
    GhilS, JayminVyas and jstepa like this.
  15. JayminVyas
    JayminVyas , Jan 11, 2016 :
    Just in case you do need a custom Kernel, Lightning CAF is working good with this ROM. Check details in my signature....that version is surely working.
    rajaspardeshi and jstepa like this.
  16. rajaspardeshi
    rajaspardeshi , Jan 11, 2016 :
    the primary reason i need a custom kernel on my phone is synapse, is synapse compatible with Lightning CAF?
  17. h0aX
    Honeycomb Jan 11, 2016
  18. JayminVyas
    Yes. Synapse works! :)
    I am using custom profile too. Just that I think - a few settings in that profile is incompatible with the latest Synapse version, which was why I had to manually set the values.
    But yes, Synapse works, custom profiles work. If not, set them manually.
  19. rajaspardeshi
    Worked, thanks. the app animations are a bit broken though, same as xposed.
    JayminVyas likes this.
  20. megatomic
    megatomic , Jan 11, 2016 :
    Installed build from 1/11 this morning. Had to reset my theme and reboot but aside from that everything is working perfectly as expected.
    jstepa likes this.
