74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. megatomic
    Ice Cream Sandwich Jan 12, 2016
    megatomic , Jan 12, 2016 :
    I'm going to install this ROM on my wife's OPO, this code is ready for prime time.
  2. tenorman1224
    Donut Jan 12, 2016
    tenorman1224 , Jan 12, 2016 :
    Try this version of TWRP. I had the same issue going from 2.8.7. Just flash the zip in 2.8.7 and reboot. https://www.androidfilehost.com/?fid=23991606952609056
  3. tye359
    tye359 , Jan 12, 2016 :
    haha, surely it can't still be classed as an 'alpha build' :D
  4. rajaspardeshi
    rajaspardeshi , Jan 12, 2016 :
    I guess I had installed the normal ad blocker from xposed, but the issue got solved suddenly after I installed chromium.
  5. rajaspardeshi
    Is it finally fixed? For real? You mean I can use location services, sync, and not use privacy guard anymore? Must update.
    Edit: By google services, you mean even Google play services battery drain is fixed?
  6. eddyh
    Gingerbread Jan 12, 2016
  7. pjcsantos
    Froyo Jan 12, 2016
    pjcsantos , Jan 12, 2016 :
    @anguianoj nice results, did you changed anything or are you using any battery saving apps? I'm still using Sultan's 5.1.1. It's nice and very stable but with such battery life on MM I think I might give it a shot.
  8. yaltis
    Jelly Bean Jan 12, 2016
    yaltis , Jan 12, 2016 :
    please read my A###########
    my problem just solved through xda
    the problem (and no one mention it on 704n xda pages)is that i was using twrp 2.8.6 but the Multirom version.after their help i flashed the regural one.
    and finally works!!1
    i was using multiron although i didnt want to multirom sultans rom with any other .
    highdiver_2000 likes this.
  9. luukbernardes
    luukbernardes , Jan 12, 2016 :
    Are you guys encountering many bugs on this rom or is it stable? Lagging on any specific apps, bad battery life, random rebooots...?
  10. se7enlyn
    Ice Cream Sandwich Jan 13, 2016
    se7enlyn , Jan 13, 2016 :
    the only method i'm familiar with is by using fastboot. very simple just one line of command. there are other methods but i'm not familiar with those.
  11. se7enlyn
    good. i am not familiar with multirom twrp so i couldn't offer any help.
  12. chuck_stones
    Gingerbread Jan 13, 2016
    SayMyName and itsinder like this.
  13. jstepa
    KitKat Jan 13, 2016
    jstepa , Jan 13, 2016 :
    Just installed root explorer, no FC's nor in FX file explorer
  14. Ne0x
    Ne0x , Jan 13, 2016 :
    I mean my google play services % in battery stats before was 12-15~% now just 4-5% without any privacy guard changes.
    btw, I ask about the hostfile because I know a bug in modified host files that gives some lag opening chrome and scrolling it.
    rajaspardeshi likes this.
  15. chuck_stones
    chuck_stones , Jan 13, 2016 :
    Yeah, CM file browser seems to allow access to root and other root apps aren't affected. Tried to uninstall and reinstall Root Explorer, cleared app data and cache, but FC still persists.
    Not sure what the issue is... Might be time to clean flash again!
  16. TimeFlies7
  17. SayMyName
    Jelly Bean Jan 13, 2016
    SayMyName , Jan 13, 2016 :
    I still can't send and receive MMS on 11/01 build. Could it be related to the modem?
  18. jstepa
    KitKat Jan 13, 2016
    It is related to APN, remove it and add it again according to your carrier and restart phone.
    There can't be no misspellings of any kind in settings, or it won't send MMS messages
  19. jstepa
    KitKat Jan 13, 2016
    Lots of different clock widgets in Play Store, choose one
    TimeFlies7 likes this.
  20. SayMyName
    Thanks, but it didn't work. Everything works except MMS.
