74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. bright_wal
    Honeycomb Mar 24, 2016
    bright_wal , Mar 24, 2016 :
    Funny thing is Darkobas also used to use the sultanxda's camera hal until recently 3-22, he switched to color os hals and brother oh brother, the camera is really really good, there is a slomo bug, minor playback issue but other than that the cam actually seems much better than the sulatanxda cam hal, some darkobas optimistaions but then, im on sultanxda cm13 and its improved a lot too
  2. jstepa
    KitKat Mar 24, 2016
    jstepa , Mar 24, 2016 :
    New build:
    Changelog:
    March 24, 2016:
    ROM:
    *Latest upstream (stable/cm-13.0-ZNH0E) CyanogenMod changes
    *Fixed WiFi MAC address
    *Re-enabled noise cancellation for phone calls
    *Removed Cyanogen recovery
    *Camera: Reduced JPEG quality to 95% (image files are smaller with no visible impact to quality)
    GhilS and theshinybeast like this.
  3. ofer5813
    Cupcake Mar 24, 2016
    ofer5813 , Mar 24, 2016 :
    please somebody help me.. i dirty flashed an updated rom on identical older build and from ten on whenever i get incoming call my opo just reboots automatically.. tried to restore using twrp and get the error "cannot restore system mounted read only" what can i do in order to be able to restore?
    or i have to do a complete clean flash of anothe rom?
  4. fenice
    KitKat Mar 24, 2016
    fenice , Mar 24, 2016 :
    I've been using TWRP 3.0.0 for a while and not had any problems, is there some specific reason you're asking?
  5. aravipistha
    Gingerbread Mar 24, 2016
    aravipistha , Mar 24, 2016 :
    Clean flashed latest build (24/03) and bluetooth has gone bonkers! Opening android wear simply crashes device and reboots it! Will try changing firmware and see if something works!
  6. h0aX
  7. aravipistha
    Update - despite trying several firmware and clean flashes, there is a crash! Opening android wear and bluetooth crashes the device and reboots..
  8. tye359
    Ice Cream Sandwich Mar 24, 2016
    h0aX likes this.
  9. kodo
    Eclair Mar 24, 2016
    kodo , Mar 24, 2016 :
    Yup, me. Works just fine.
    foralltolisten1 likes this.
  10. johncel.espares
    Froyo Mar 24, 2016
  11. kanagadeepan
    KitKat Mar 24, 2016
  12. Evokkimus
    KitKat Mar 24, 2016
    Evokkimus , Mar 24, 2016 :
    Me and @HR_778 have noticed that 2d rendering on Sultan's ROM is not that smooth. I came from DU and HR from CM nightlies and we both think animations were smoother on those. Any idea why it is like that?
    Otherwise at its current state, this ROM is pretty solid :)
    HR_778 likes this.
  13. ofer5813
    where the hell is the snapdragon camera i install the latest build and got only google camera from the open gapps package..?
  14. Evokkimus
    KitKat Mar 24, 2016
    Did you flash Stock GApps? That replaces stock camera.
  15. ofer5813
  16. Shubh21
    Shubh21 , Mar 24, 2016 :
    Most probably you'll have to clean flash again..
    You can either use a smaller Gapps package, or if you want to use the Stock (Full) Gapps package, you can use a script to not let Gapps remove the SDcam app..
    For the script, have a look in the Advanced Features & page of opengapps
  17. 69gm
    Jelly Bean Mar 24, 2016
    69gm , Mar 24, 2016 :
    Did you try to re-pair?
  18. 69gm
    Did you try going into Dev options and changing all the animations to .5 (or whatever you like). On other ROMs I noticed it's changed by default to another number. Sultan kept it at the CM default of 1.
    Evokkimus likes this.
  19. 69gm
    Try and see! :D
  20. Dendedanamekian
    Dendedanamekian , Mar 24, 2016 :
    Quick question, I just flashed 0322 build and can't figure out how to get rid of the google search bar at the top of the screen. Is it removable? Also theme store, is that available for 6.0.1?
