74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. E-Blade
    Cupcake May 12, 2016
    E-Blade , May 12, 2016 :
    On the April 30th update I keep losing mobile signal, I'm in the same place as I was before on the earlier updates and didn't have this issue. Any suggestions.
  2. Morttem
    Ice Cream Sandwich May 12, 2016
    Morttem , May 12, 2016 :
    So I have to install SU in the recovery not after rebooting.
  3. Oschara
    Gingerbread May 12, 2016
    Oschara , May 12, 2016 :
    You can really install it either way. What I do is setup the rom and then nandroid it and finally flash it in the event that something goes wrong!
  4. helloworld08
    helloworld08 , May 12, 2016 :
    anybody having bluetooth issues? the phone is unable to connect to the car stereo after updating to CM13
  5. 69gm
    Jelly Bean May 12, 2016
    69gm , May 12, 2016 :
    Did you check your APN?
  6. 69gm
    Are you talking specifically about this ROM or CM13 in general?
    I personally have not had any problems with bluetooth in a long time.
  7. 69gm
    What I generally do is download the update, go into recovery, flash the update, flash SuperSU, Wipe dalvik/cache (although I'm finding I don't need to...the phone knows what to do...but habit), reboot.
    All goes well. If anything goes wrong, it's usually a bad download which happens, albeit rare.
  8. helloworld08
    This ROM specifically, i have not tried any other CM13.
  9. nasosrr
    Donut May 12, 2016
    nasosrr , May 12, 2016 :
    I know it's stupid to quote myself, but I could really use some help with this and this forum is my only source of support for my OPO. It's very much non-practical to have to reboot the phone to recovery each time I want to copy photos to my computer.
    Thank you in advance for any help you can provide.
  10. Morttem
    Thanks! I'll try it today.
  11. yashk1611
    Eclair May 13, 2016
    yashk1611 , May 13, 2016 :
    Could the bad download be a reason for me facing the issues of lock screen not working (unless I set up a pattern lock) and quick settings not opening? The download had paused twice and resumed due to spotty network
  12. 69gm
    Jelly Bean May 13, 2016
    69gm , May 13, 2016 :
    Hmm, not sure. Usually with a bad download, it's all or nothing...like you wouldn't even be able to boot.
    What exactly is your problem with the lockscreen? If you don't want one, it's "none". If you want one but you don't want to input any security, it's "swipe". Otherwise it's the usual pattern/pin/password thing...
  13. Morttem
    Ice Cream Sandwich May 13, 2016
  14. 69gm
    No. If you get one, send a log to @Sultanxda.
  15. yashk1611
    Eclair May 14, 2016
    yashk1611 , May 14, 2016 :
    Lock screen does not appear at all if it's set to swipe. If its set to pattern lock, the quick settings refuse to open after the first unlock. Also, I noticed this happens only if I install gapps, but I doubt it could be an issue with those as I have used the same nano 31st march build of open gapps for all MM ROMs that I have tried without any issues.
  16. yashk1611
    Eclair May 14, 2016
  17. 69gm
    Jelly Bean May 14, 2016
    69gm , May 14, 2016 :
    Just for shits and giggles, why not download the latest open gapps? I have not had this issue and don't remember others reporting it so it sounds pretty isolated...
    jstepa likes this.
  18. 69gm
    Jelly Bean May 15, 2016
    69gm , May 15, 2016 :
    New Build!
    May 14, 2016:
    ROM:
    *Latest upstream (stable/cm-13.0-ZNH2K) CyanogenMod changes
    *Android Security Patch Level: May 1, 2016
    *Fixed choppy audio in Miitomo app
    Kernel:
    *Increased scheduler tick rate to 300 Hz (reduces overall system latency)
    *Updated WiFi drivers to CAF LA.BF.1.1.3_rb1.13
    h0aX, jstepa and thewardy like this.
  19. h0aX
    Honeycomb May 15, 2016
  20. 69gm
    h0aX likes this.
