74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. jstepa
    KitKat May 15, 2016
    jstepa , May 15, 2016 :
    @69gm is Sultan going to drop support for OPO at some point?
    Just read in xda that his daily driver is now OPX...
    rocstarmohit and h0aX like this.
  2. h0aX
    Honeycomb May 15, 2016
    h0aX , May 15, 2016 :
    Only GDrive as no speed caps on Google services for my ISP
  3. Tuqano
    Ice Cream Sandwich May 15, 2016
    Tuqano , May 15, 2016 :
    @69gm
    Can you please confirm if file manager is working properly? I can't find the option to gain root mode....
  4. thewardy
    Froyo May 15, 2016
    thewardy , May 15, 2016 :
    File manager is still broken for me.
    You have to flash SU with each update currently, it's no longer included by default.
  5. thewardy
    Froyo May 15, 2016
  6. Tuqano
    Well, thanks for your feedback! I hope they'll fix file manager!
  7. 69gm
    Jelly Bean May 15, 2016
    69gm , May 15, 2016 :
    No he's not. He'll dev together since his ROM for both are not that different from each other...
    jstepa likes this.
  8. 69gm
    I've never used the built in file manager. I've always liked ES File Explorer, although there's been controversy with it recently...so I've started using FX File Explorer. So far I like it! And, yes, it has root access, although you need to download a separate file for it at the PlayStore.
    jjrojoc and Tuqano like this.
  9. 69gm
    JayminVyas and h0aX like this.
  10. 69gm
    JayminVyas, h0aX and jstepa like this.
  11. rocstarmohit
    Honeycomb May 16, 2016
    rocstarmohit , May 16, 2016 :
    Maybe because nowadays he is very biased towards OPX owners :p
    Edit - Oops! read later that he doesn't
  12. 69gm
    Jelly Bean May 16, 2016
    h0aX likes this.
  13. 69gm
    69gm , May 16, 2016 :
    Didn't understand this post...
  14. chuck_stones
    Gingerbread May 16, 2016
    chuck_stones , May 16, 2016 :
    Dirty flashed 14/05 build over previous build (can't recall build date, performed clean flash) yesterday, been getting terrible battery drain. Seems to be caused by cLock... Possibly because I've added a weather provider?
    Screenshot_20160516-125721.png Screenshot_20160516-125812.png Screenshot_20160516-125816.png Screenshot_20160516-125831.png
  15. 69gm
    That does look weird. If what you suspect is true, though, it's either a CM or weather provider app problem. Unfortunately, not ROM related...
    I use a completely different weather app (Weather & Clock Widget) so I haven't noticed this problem....although I don't remember anyone else reporting something similar either...
  16. Morttem
    Ice Cream Sandwich May 16, 2016
    Morttem , May 16, 2016 :
    Since I made the clean installation for this new update my apps are crushing everytime I use them, does anyone knows any kind of solution for this? By the way my mic problem came back again :(
  17. Alivethereality
    Jelly Bean May 17, 2016
    Alivethereality , May 17, 2016 :
    so yesterday i went to sleep with the phone with 17 or so %, woke up in the middle of the night with the sound of the phone turning off, as i know that the phone's alarm doesn't work when its turned off i put him to charge and still my alarm didn't work in the morning
    good that i woke up in my usual time so i didn't miss my work, but i still can't understand why did it ran out of battery just for the night, its 6.1 its supposed to last longer then 5.1 and it never happened before
    the reason for the alarm not working is that for some reason the soundtrack i use for the alarms got messed up and i now noticed it says 502 instead of the name of my soundtrack, so it basically plays no sound
    i've changed it back, rebooted the phone ( the reboot didnt mess it up ) and it seems to work now but can anybody explain why did it got reset ?
    for some reason this 6.1 version doesn't have built-in alarm sounds, so i have to choose a custom one
    also when i put the phone to charge i turned it on and went to the toilet, when i came back it wasn't on again, so i did and noticed that when you turn it on the backlight causes the phone to drain the battery so fast that it has no time to recharge so it turns off, so when i turned it on i immediately locked it so it wouldn't drain battery right away
    is there any way to put the phone to sleep at night so it wouldn't waste so much battery ? i didn't expect this to be so bad with people talking about how cool 6.1 is with doze
    ps : i was using the 12/3/16, today updated to the latest. Using the stock cclock app
  18. thewardy
    Froyo May 17, 2016
    thewardy , May 17, 2016 :
    I also seem to be having an issue if I try and share anything, I get an error message saying that Android has stopped. I'm not sure if this is Rom related?
  19. Morttem
    Ice Cream Sandwich May 17, 2016
    Morttem , May 17, 2016 :
    IT'S GIVING ME A LOT OF PROBLEMS SINCE THE LAST UPDATE
  20. thewardy
    Froyo May 17, 2016
    I also get a lot of package installer has stopped errors.
    I'm sure they'll fix it if it is the Rom.
