74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. theshinybeast
    Marshmallow Sep 21, 2016
    theshinybeast , Sep 21, 2016 :
    Are you sure? I only get that when I play a lot of Tsum Tsum or is it Fap Fap? Whatever, @69gm a fix? :p
    se7enlyn and 69gm like this.
  2. DrJMun
    Jelly Bean Sep 21, 2016
    DrJMun , Sep 21, 2016 :
    Thanks, nice to know I'm not alone LOL. I take it it's not really on as I cannot access the net even though it's supposedly on.
    se7enlyn likes this.
  3. 69gm
    69gm , Sep 21, 2016 :
    YES! Just make sure to format your internal memory and then reboot. It will take a while, but just sit there and wait...It will only work if you are patient so just continue waiting...:D:D:D
  4. 69gm
    I don't think ANYONE can find a fix for YOUR FapFap...;););)
  5. 69gm
    Seriously though, I would get a very strange bug that during game play, the volume would spike for a second. This would happen even if I turned the sound all the way down to zero. Weird bug. Not sure if it affects other apps too so that's why I was going to make it available if anyone had that or similar bug.
    This is strictly for sound...in my case, it would spike really loudly for a second. It seemed random too. I only had it during the game TsumTsum, but I can't say it doesn't happen on another app.
    Anyway, if you have this similar bug this might be a fix for you...
  6. yaltis
    Jelly Bean Sep 24, 2016
    yaltis , Sep 24, 2016 :
    i m on 20160921 version .after clean installation i noticed 2 probl
    1)is my phone a bit slower?/
    2) when im on my dialer and trying to send an sms to any caller,when i press the message button i m getting a black screen.
    anyone else?
  7. Tarfex
    Ice Cream Sandwich Sep 25, 2016
    Tarfex , Sep 25, 2016 :
    can't tell if this a troll or not. is this ROM updated to CM14?
  8. DrJMun
    Jelly Bean Sep 25, 2016
    DrJMun , Sep 25, 2016 :
    I'm thinking of going to this newer version as my current version, the one just before this one, the battery drain is terrible. WiFi is always on, even though I have scanning set to Never.
  9. se7enlyn
    se7enlyn , Sep 25, 2016 :
    Hahaha , you will need to install a giant statue of 69gm first before he uploads the cm14 update.
    69gm likes this.
  10. subaryota
    Froyo Sep 25, 2016
    subaryota , Sep 25, 2016 :
    Not sure if this is a operating system issue or app issue. I've noticed gmail using up a lot of mAh. I've always left WiFi On and for it to never sleep. My recent decrease in battery life seems to correlate with the increases mAh use by Gmail. Previously, Gmail mAh usage was low. But recently, it is the highest battery user, more than SOT.
  11. DrJMun
    Hmmmm thanks. I'll give that a shot. When I look at battery power usage per app it doesnt show up, but something sure is eating up battery. Today it was dropping at 7%/hour
  12. DrJMun
    Jelly Bean Oct 6, 2016
    DrJMun , Oct 6, 2016 :
    I ended up installing the latest version, cm-13.0-ZNH2K-20160921-STABLE-Sultan-bacon.zip, and that seems to have significantly improved my battery drainage issue.
  13. Alivethereality
    Alivethereality , Oct 6, 2016 :
    currently on 08/08 wanted to dirty flash 21/9 + setup ( xposedv26 + supersu 2.46 ) , bootloop
    dirty flashed 08/08 back with my setup, bootloop
    dirty flashed 08/08 without setup, totally fine
    dirty flashed 21/9 without setup, totally fine
    question, is xposed 26 not compatible with 21/9, or do i need to install ít somehow fancy ?
    PS : xposed is ofcourse arm
    DrJMun likes this.
  14. DrJMun
    I had same problem so I just gave up on Xposed... maybe someone has a solution.
  15. Alivethereality
    yea i cant give up on xposed, it what differentiates me from those filthy iphone peasants, its pure freedom, its who i is
    hopefully the solution will come soon
  16. JayminVyas
    Ice Cream Sandwich Oct 7, 2016
    JayminVyas , Oct 7, 2016 :
    That's the reason I prefer clean flashes almost always. And like everyone says, I too would suggest to flash ROM/GApps/SU, boot into the ROM, go back to recovery, and then try to flash Xposed. Don't know the rationale, I am sure someone who knows better, might explain, but that works many times.
  17. Alivethereality
    Jelly Bean Oct 7, 2016
    Alivethereality , Oct 7, 2016 :
    i just tried to flash Supersu, bootloop
  18. Alivethereality
    Jelly Bean Oct 8, 2016
  19. subaryota
    Froyo Oct 9, 2016
    subaryota , Oct 9, 2016 :
    Did you try clean flashing?
  20. DrJMun
    Jelly Bean Oct 9, 2016
    DrJMun , Oct 9, 2016 :
    OK, I was able to get it to work. I used TWRP, cleaned Davlik and Cache. Installed SuperSU. Rebooted. Then went back to TWRP cleaned both caches as above... installed Xposed Framework. Rebooted. Then installed Xposed Installer and rebooted. I'm not sure each of the reboots was necessary but that's what I did to get it to work.
    xposed-v86-sdk23-arm.zip
    XposedInstaller_3.0_alpha4.apk
    UPDATE-SuperSU-v2.76-20160630161323.zip
    No bootloops..and everything working as it should. Hope this helps.
    JayminVyas likes this.
