74
ROM [ROM+KERNEL][6.0.1] Unofficial CyanogenMod 13.0 with 3.4.0 kernel
  1. Tuski98
    Donut Oct 11, 2016
    Tuski98 , Oct 11, 2016 :
    Is there any kernel compatible with sultan cm 13 so I can use multi ROM as sultan inbuilt Kernel does not support kexec encoded kernel if there please give the link or post to reply
  2. subaryota
    Froyo Oct 13, 2016
    subaryota , Oct 13, 2016 :
    Just a quick followup to this battery issue. As of this morning, my battery life is back to 'normal'. I noticed as of this morning, the gmail app is using far less mAh. I am still on the same Sultan build (Sept 21).
    Thusly, sudden changes in battery life are not always due to issues with the operating system, and is more likely related to updated apps.
    Cheers
  3. 69gm
    Jelly Bean Oct 13, 2016
    69gm , Oct 13, 2016 :
    It's actually sorta a combination. Google silently updates their core elements like Play Services. Until the devs of the apps updates, it doesn't always play so nice on the phone with the Google updates...
    se7enlyn and subaryota like this.
  4. neokostas1
    Gingerbread Oct 16, 2016
    neokostas1 , Oct 16, 2016 :
    Hi I am running the nightlies latest build 12.1 with 2.8.6.0 twrp . I flash the snapshot without changing the twrp version?
    1.Wipe system/cache dalvik / data
    2.Flash cm.13 snapshot official cm
    3.Wipe system/cache dalvik
    4. Flash sultans rom and then gapps
    5.wipe cache dalvik
    6. Reboot?
    Is that it?
    P.S what is a cpu underclock?
    P.S2 the latest build of cm13 snapshot official is this cm-13.0-20160819-SNAPSHOT-ZNH5YAO0IN-bacon.zip
    am I right? or should I flash this .zip you mention ? 16/3 version
  5. Pahapoika91
    Ice Cream Sandwich Oct 17, 2016
  6. neokostas1
    Gingerbread Oct 18, 2016
  7. Pahapoika91
    Ice Cream Sandwich Oct 18, 2016
    Pahapoika91 , Oct 18, 2016 :
    I dont know. I used this like 6-months ago. Then i went back to Marsh.
  8. andy2000
    Cupcake Oct 19, 2016
    andy2000 , Oct 19, 2016 :
    Does this ROM supports/passes Safetynet checks (does this run Pokemon Go)? I'm not planning to use root and read, that this doesn't include root.
  9. 69gm
    Jelly Bean Oct 20, 2016
    69gm , Oct 20, 2016 :
    Snapchat works fine AFAIK.
  10. 69gm
    Err, not true. I'm rooted. I have Snapchat. The only thing that I've ever noticed that conflicted with Snapchat is Xposed.
  11. 69gm
    No. But if that happens, unroot, set up Snapchat, reroot. It should work.
    For something to be really locked like Android Pay, it will NEVER work. :D
    anzi2001 likes this.
  12. striker280
    Gingerbread Oct 22, 2016
    striker280 , Oct 22, 2016 :
    Any ideas why the wifi keeps turning off during sleep? Sometimes i don't get notifications until i turn the phone on. I've already kept the keep wifi on during sleep setting on, but it still keeps turning off. Any ideas or solutions? Thanks
  13. highdiver_2000
    Ice Cream Sandwich Oct 23, 2016
    highdiver_2000 , Oct 23, 2016 :
    The apps that you missed the notification, exempt it from Doze. How? Google for it.
    striker280 likes this.
  14. se7enlyn
    se7enlyn , Oct 23, 2016 :
    Go to battery, 3 dots, battery optimization, search for your app and turn off battery optimization for that particular app
  15. striker280
    Gingerbread Oct 23, 2016
    striker280 , Oct 23, 2016 :
    Optimization is off for all of them, but not too sure why wifi turns off during sleep, leaving just data on causing possible battery drain. Could it be because i have force doze?
  16. 69gm
    Jelly Bean Oct 24, 2016
    69gm , Oct 24, 2016 :
    New build is up. I think I did all the necessary changes. Let me know if something doesn't work!
  17. subaryota
    Froyo Oct 25, 2016
    subaryota , Oct 25, 2016 :
    Just tried to clean install sultan Oct 23 build with OpenGapps full (Oct 23). OpenGapps full gave error 70. Not enough space in Systems partition.
    Sultan Sept 21 build would allow install of OpenGapps full (Oct 23) during clean install.
    Clean install using TWRP 3.0.2 via USB OTG.
  18. thewardy
    Froyo Oct 25, 2016
    thewardy , Oct 25, 2016 :
    And a 25th build too now ?
  19. kodo
    Eclair Oct 25, 2016
    kodo , Oct 25, 2016 :
    Changelog:
    October 26, 2016:
    ROM:
    *Removed Gello browser
    October 25, 2016:
    ROM:
    *Added new off-mode charging animation from CM nightlies
    Kernel:
    *Fixed power-off/reboot not working correctly (kernel would crash, causing the device to always reboot back into Android)
    *Fixed random reboot issue caused by WiFi drivers
    ziepicwaffle likes this.
  20. 69gm
    Jelly Bean Oct 25, 2016
    69gm , Oct 25, 2016 :
    Yes, yes...coming coming...:p
