48
ROM [ROM][LineageOS][Android 6.0.1] TugaPower
  1. TugaPower
    Jelly Bean Dec 23, 2016
    TugaPower , Dec 23, 2016 :
    Thanks all of you guys for the support.
    Will take a litle vacation of one week +-, all time will be spend with family, over this time do not expect any updates of this ROM, to all a very good Merry Christmas and a happy New Year.
    Pedro Formigo, CaBooSe and manlio62 like this.
  2. rajaspardeshi
    Ice Cream Sandwich Feb 1, 2017
  3. CaBooSe
    Gingerbread Feb 1, 2017
    CaBooSe , Feb 1, 2017 :
    Has been discussed at XDA by developer should be updated probably very soon....
    rajaspardeshi likes this.
  4. TugaPower
    Jelly Bean Feb 5, 2017
    TugaPower , Feb 5, 2017 :
    Need to manage time to update stuff and time its a thing dont have.
    Sorry guys, but this is not yet ended.
    rajaspardeshi and Pedro Formigo like this.
  5. TugaPower
    Jelly Bean Feb 26, 2017
    TugaPower , Feb 26, 2017 :
    Build 2017/02/26
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower M99.0 CM13 #OnePlus #Android 6.0.1
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366
    If your Gapps provider dont supply backup script, you can see in folder /system/addon.d you will need to flash gapps after ROM.
    Gapps advised per the CyanogenMod Wiki to CM13 its Open Gapss Nano Package.
    http://opengapps.org/?api=6.0&variant=nano
    Change log:
    [STRIKE]Automatic turn on data to send/recebe MMS if data is off[/STRIKE] -> will fix on next update
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise Deuteronomy 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Kcal Support ( use Color Control app to adjust colors )
    Xposed Installer Materialised latest version included thanks @DVDandroid
    You must flash manually the xposed framework, its a one time step, over my nexts releases it will survive.
    You can use the built in install / unnistall of Xposed installer
    Gello removed and replaced by latest TugaBrowser beta v55.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    Multi-ROM Support , that way you can try my N ROM :)
    Increase max chg current to 2000/500mA
    PoGO: Gonna catch then all
    Powered by Magisk Manager and MagiskSU
    If you are in other builds, make a factory reset, flash ROM, then flash Gapps. Reboot
    Full Change log:
    Since last build change log is huge, its upload to past bin the full chnagelog:
    http://pastebin.com/E9j0icUU
    ROM -> https://www.androidfilehost.com/?fid=457095661767140374
    MD5: de65635977d9049855eee8a4c1fcae1e
    Happy flashing
    Source:
    CyanogenMOD: https://github.com/LineageOS
    Kernel source: https://github.com/TugaPowerROM/kernel_oneplus_msm8974
    Banners TugaPower ROM
    Cobrin and CaBooSe like this.
  6. CaBooSe
    Gingerbread Feb 26, 2017
    CaBooSe , Feb 26, 2017 :
    Excellent , just manually downloaded and installed it :) Don't know why system update wouldnt download it. Tks #tugapower
    TugaPower likes this.
  7. Cobrin
    Ice Cream Sandwich Feb 27, 2017
    Cobrin , Feb 27, 2017 :
    I think I'm in for a change and TugaPower looks to be it, thanks TP for all your effort put in to this.;)
    winstonsmith and TugaPower like this.
  8. santhoshraon
    Cupcake Mar 15, 2017
    santhoshraon , Mar 15, 2017 :
    This is perhaps the best ROM available for OPO. Best in terms of performance, battery life and stability. I have tried every single ROM stock/custom Marshmallow/Nougat available out there, and have finally zeroed in on this ROM. Tons of thanks to @TugaPower :)
    TugaPower and ziepicwaffle like this.
  9. ankit1999
  10. TugaPower
    Jelly Bean Mar 18, 2017
    TugaPower , Mar 18, 2017 :
    Can you be more specifique? Not uderstanding the statment you made.
  11. TugaPower
    Jelly Bean Mar 19, 2017
    TugaPower , Mar 19, 2017 :
    Build 2017/03/18 #OPO #LineageOS 6.0.1
    TugaPower ROM G+
    #TugaPower M100.0 LineageOS #OnePlus #Android 6.0.1
    Call Record
    Full Change log:
    February Security Patch
    Project name: android_hardware_libhardware
    Fix security vulnerability: potential OOB write in audioserver
    Project name: android_vendor_cm
    Add target to make a flashable su addon
    backuptool: Preserve the SELinux context of the files
    backuptool: Don't rely on the order of the elements in the list
    cm: Import init.superuser.rc into init.local.rc
    Project name: cm_platform_sdk
    CMSettingsProvider: remove per-user cursor observation
    CMSDK: Tests: AIRPLANE_MODE_ON has moved
    Project name: android_frameworks_native
    Fix SF security vulnerability: 32706020
    Correct overflow check in Parcel resize code
    Project name: android_frameworks_base
    Retain DownloadManager Uri grants when clearing.
    Check provider access for content changes.
    Project name: android_frameworks_av
    Effect: Use local cached data for Effect commit
    Project name: android_build
    Update su binary added with addonsu zip
    Update security patch level to 2017-02-01.
    build sign_target_files_apks.py: clean tmp on exit
    build: core: Remove BUILD_TINY_ANDROID checks
    Project name: android_packages_apps_UnifiedEmail
    Don't allow file attachment from /data through GET_CONTENT.
    Project name: android_packages_apps_LockClock
    res: use selectableItemBackgroundBorderless for refresh button background
    Project name: android_packages_apps_Messaging
    resolve merge conflicts of eafd58a to nyc-dev
    Security Vulnerability - AOSP Messaging App: thirdparty can attach private files from "/data/data/com.android.messaging/" directory to the messaging app.
    Security Vulnerability - heap buffer overflow in libgiftranscode.so
    Project name: android_packages_apps_Snap
    Snap/Strings: sensivity -> sensitivity
    Project name: android_packages_apps_Bluetooth
    Remove MANAGE_DOCUMENTS permission as it isn't needed
    ROM -> https://www.androidfilehost.com/?fid=817550096634754746
    MD5: 974fe5d44b520e2dcc0e86163007fc53
    Happy flashing
    CaBooSe likes this.
  12. CaBooSe
    Gingerbread Mar 19, 2017
  13. TugaPower
  14. chetanx
    Donut Mar 24, 2017
    chetanx , Mar 24, 2017 :
    Hey, I downgrade from Lineage N to this ROM. Hope this will be stable and keep providing updates.
  15. chetanx
    Donut Mar 24, 2017
  16. Dilip Jain(DJ)
    Ice Cream Sandwich Mar 25, 2017
  17. Sanjit0789
    Cupcake Mar 25, 2017
  18. Dilip Jain(DJ)
  19. chetanx
    Donut Mar 25, 2017
    chetanx , Mar 25, 2017 :
    No
  20. TugaPower
    Jelly Bean Mar 26, 2017
    TugaPower , Mar 26, 2017 :
    Build 2017/03/25 #OPO #LineageOS 6.0.1
    TugaPower ROM G+
    #TugaPower M101.0 LineageOS #OnePlus #Android 6.0.1
    Call Record
    Full Change log:
    March Security Patch
    android: Switch to our libhevc
    Project name: android_bootable_recovery
    Add a checker for signature boundary in verifier
    Project name: android_frameworks_ex
    resolve merge conflicts of 89cdd4cb to mnc-dev
    Project name: android_frameworks_opt_net_wifi
    configparse: do not delete passpoint configuration file
    Add @GuardedBy annotation to PersistentDataBlockService#mIsWritable.
    Prevent writing to FRP partition during factory reset.
    avc_utils: skip empty NALs from malformed bistreams
    Don't initialize sync sample parameters until the end
    audioflinger: fix recursive mutex lock in EffectHandle.
    improve audio effect framwework thread safety
    Updating Security String to 2017-03-01 on nyc-dev
    Project name: android_external_libhevc
    Added check for invalid log2_max_transform_block_size in SPS
    Fixed handling invalid chroma tu size for error clips
    Fixed out of bound reads in stack variables
    Fix in Chroma SAO for non-multiple of 8 height
    Handle invalid slice_address in slice header
    Project name: android_external_boringssl
    Rewrite BN_bn2dec.
    Project name: android_external_libnfc-nci
    Fix native crash in nfc_ncif_proc_activate
    Project name: android_external_libavc
    Decoder: Fixed an out of bound access while parsing SEI
    Decoder: Initialize ps_cur_slice->u1_mbaff_frame_flag correctly for error cases
    Call ih264d_deblock_display only for valid process calls
    Decoder: Fixed DoS in header decode when no PPS is present
    Decoder: Fix initialization of ps_next_dpb during reference list creation
    Decoder: Fix in error concealment in the case of Mbaff clips
    Decoder: Fix in checking first_mb_in_slice
    Decoder: Increase memory allocation for weights & offsets for interlaced clips
    Decoder: Padded gau1_ih264d_top_left_mb_part_indx_mod to avoid an out of bound read
    Decoder: Fix in MB count in MBAff error handling
    Decoder: Fix in the case of error in the first MB in frame.
    Decoder: Fixed cur_mb_info initialization in error cases
    Decoder: Fixed allocation of ps_dec->ps_nbr_mb_row
    Decoder: Fix in returning incomplete frame error
    Project name: android_packages_apps_CertInstaller
    WifiInstaller: add permission for access downloaded files
    WifiInstaller: remove the installation file
    Project name: android_packages_apps_PackageInstaller
    Prioritize package installer intent filter
    32764144 Security Vulnerability - heap buffer overflow in libgiftranscode.so in colorMap->Colors[colorIndex]
    33388925 Mismatched new vs delete in framesequence library
    Project name: android_packages_apps_Settings
    Settings: point to lineageos updater
    ROM -> https://www.androidfilehost.com/?fid=745425885120719195
    MD5: 0d3b3959efd6117f278219cb06b4554b
    Happy flashing
