48
ROM [ROM][LineageOS][Android 6.0.1] TugaPower
  1. TugaPower
    Jelly Bean Mar 26, 2017
    TugaPower , Mar 26, 2017 :
    Have no issues with 4G ( LTE ) tests done with my device.
    Dilip Jain(DJ) likes this.
  2. chetanx
    Donut Mar 26, 2017
    chetanx , Mar 26, 2017 :
    But I'm facing problems, that's one of main reasons why I move from Lineage N to Tugapower M for 4g. Also when phone off after automatic lock and within a sec I want to on my phone it gives me trouble. Atleast I have to click power button 4-5 time to turn my phone on.
  3. TugaPower
    Wich firmware you have on your phone? ( baseband )
  4. ultimatescar
    Cupcake Mar 26, 2017
    ultimatescar , Mar 26, 2017 :
    Hi I am on m99 I have couple of questions....
    1. I dont get Otas even when I manually search updates it says there are no updates and here I am now looking at m101.
    2. Sometimes its hard to jump start mobile data after disconnecting from wifi.. I have to restart /soft restart the device so that mobile data would work again. I've tried mobile data off and on again many times but of no avail.
    3. I hadn't tried waze on long drive I tried today but it lost gps signals multiple times as in many many many times.. had hard times locking gps signal. are there some gps fix? thanks.
  5. TugaPower
    OTAs in lower then M100 are brokens, because of place where OTA search changed ( dropbox ended public folders )
    You need to manually flash M101, after that you will recebe OTAs again when available.
    Relative to GPS issue, wich firmware you using ?
  6. chetanx
    Donut Mar 27, 2017
    chetanx , Mar 27, 2017 :
    Here it is.
  7. TugaPower
    Jelly Bean Mar 27, 2017
    TugaPower , Mar 27, 2017 :
    Try changing the firmware to the c7 and see if get better for you.
  8. chetanx
    Donut Mar 27, 2017
    How I can change it??
  9. TugaPower
  10. chetanx
    Donut Mar 27, 2017
    Thanks for file, I have flashed it. I will let you know status on this.
    Can fix second problem, whenever my screen off due to automatic lock and within in a sec if I tried to on my phone. I have to press power button 4-5 times at least to turn my phone on. It should respond with in 1-2 attempt.
  11. TugaPower
    That's not normal at all, would suggest you a clean install of rom. And prior to install stuff test the unlock method.
  12. chetanx
    Donut Mar 27, 2017
    I have done clean flash.
  13. TugaPower
    And prior to install apps, tested the unlock screen?
  14. Dilip Jain(DJ)
    Ice Cream Sandwich Mar 28, 2017
    Dilip Jain(DJ) , Mar 28, 2017 :
    Thanks sir for this superb Rom.
    4g wrking perfct.
    no crash in any app
    no crash of camera.
    SOT ALMOST 5H 40M.
    NO HEATING AT ALL.
    VRY FAST CHARGING....
    TugaPower likes this.
  15. Dilip Jain(DJ)
    N LAST NT THE LEAST.
    GRT NAUGAT FLNG....
    THANKS AGAIN SIR FOR SUCH A SUPERB ROM..N GIVING OTA....GOOD WRK SIR KEEP IT UP....
  16. chetanx
    Donut Mar 29, 2017
    chetanx , Mar 29, 2017 :
    How 4G is working??
  17. Dilip Jain(DJ)
    Ice Cream Sandwich Mar 29, 2017
  18. chetanx
    Donut Mar 31, 2017
    chetanx , Mar 31, 2017 :
    No... Wanted to know.. It's 4G or LTE working??
  19. ultimatescar
    Cupcake Mar 31, 2017
  20. chetanx
    Donut Apr 1, 2017
    chetanx , Apr 1, 2017 :
    So I'm able to fix the problem screen problem, it was happening due to "Greenify" app. Now I have disable auto hibernation and everything is fine.
