58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. mickcost
    Honeycomb Sep 30, 2016
  2. se7enlyn
    Ice Cream Sandwich Oct 1, 2016
    se7enlyn , Oct 1, 2016 :
    notification led custom actions working?
  3. ziepicwaffle
    ziepicwaffle , Oct 1, 2016 :
    Custom led stuff is not yet working, quick pulldown isn't working for me either. As for lock screen, I don't think you can change to to something different than your wallpaper... Personally I keep wallpaper and lock screen the same cause I like how the lock screen always corresponds to the background i have :p
    rajaspardeshi and se7enlyn like this.
  4. sridiculous
    Gingerbread Oct 1, 2016
    sridiculous , Oct 1, 2016 :
    In Nougat, you can use two finger gesture for quick pull down, just drag from the top using 2 fingers instead of 1 and you have your quick pull down.
  5. Valokuvaaja
    Honeycomb Oct 1, 2016
    Valokuvaaja , Oct 1, 2016 :
    No. There are no exposed for N (yet).
  6. jstepa
    KitKat Oct 1, 2016
    jstepa , Oct 1, 2016 :
    Well you can, but it's not so simple thing:
    Go to data/system/users/o, delete file wallpaper, put your *jpg (*.png) image in this folder, reneme it to wallpaper (no .jpg, .png or nothing, just wallpaper) , reboot device, now you have same as wallpaper and lockscreen wallpaper, just change your wallpaper.
    ziepicwaffle, se7enlyn and tye359 like this.
  7. mickcost
  8. harshdangi
    Froyo Oct 1, 2016
    harshdangi , Oct 1, 2016 :
    Hey...... Can you please add a feature in which it shows how many devices are connected via hotspot..... Thanks in advance
  9. drsamirpatel
    Eclair Oct 1, 2016
    rajaspardeshi likes this.
  10. TugaPower
    Jelly Bean Oct 2, 2016
    TugaPower , Oct 2, 2016 :
    There is no VoLTE support for OPO, it have only from third party apps operator must supply, like Jio did.
    drsamirpatel likes this.
  11. ramcon12
    Gingerbread Oct 3, 2016
  12. siva-kumar
  13. ziepicwaffle
    Ice Cream Sandwich Oct 3, 2016
    jstepa and siva-kumar like this.
  14. sridiculous
    sridiculous , Oct 3, 2016 :
    Just checked and power off alarm also works with this ROM (I am on rc 08).
    One thing I noticed is the idle battery drain. Miscellaneous and Cyanogenmod system are both eating up the battery, in that order. Hardly finishing the day off with more than 25% juice left, with very modest usage.
  15. ramcon12
    ramcon12 , Oct 3, 2016 :
    I also see the Miscellaneous thing but getting almost 24+ hours with medium use
  16. ziepicwaffle
    ziepicwaffle , Oct 3, 2016 :
    The Miscellaneous thing isn't a battery drain. It is just the difference between the computed power use and the actual power use. If you tap on it, it will explain it to you.
    jstepa likes this.
  17. ramcon12
    I am getting very bad cell reception, many yellow and greenish colors. With CM13 is always green. Any ideas to fix it?
  18. theshinybeast
    Marshmallow Oct 3, 2016
    theshinybeast , Oct 3, 2016 :
    It might be a firmware/modem thing.Check out this thread , I've always had better reception with Oxygen 2.1.Firmware (00013)
    But that's me ,probably a different country, carrier etc so check which one is best for you.
    jstepa, ziepicwaffle and ramcon12 like this.
  19. G_Susana_Francisco_KEAo
    Eclair Oct 3, 2016
  20. lostLambda
    Lollipop Oct 4, 2016
    lostLambda , Oct 4, 2016 :
    Ain't that the sad truth :rolleyes:
    jstepa and theshinybeast like this.
