58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. se7enlyn
    Ice Cream Sandwich Oct 6, 2016
    se7enlyn , Oct 6, 2016 :
    Which one is this? I've lost count:p:D
    jstepa, KforHorizon and theshinybeast like this.
  2. theshinybeast
    Marshmallow Oct 6, 2016
    jstepa, KforHorizon and se7enlyn like this.
  3. KforHorizon
    KitKat Oct 6, 2016
    KforHorizon , Oct 6, 2016 :
    The 4th one! It's okayish! Still has purple and green tint but not as bad as the other ones! So yeah I'll be replacing it! Will try my luck with the soft gold!
  4. theshinybeast
    theshinybeast , Oct 6, 2016 :
    Definitively, you are now OP´s quality control in India. Do they pay well?:rolleyes:;)
  5. se7enlyn
    Good luck! :p:D
    jstepa and KforHorizon like this.
  6. csabreu
    csabreu , Oct 6, 2016 :
    You're definitely going to lead OP to bankruptcy ;)
  7. KforHorizon
    KitKat Oct 6, 2016
    Haha yeah they do let me unbox new phones and return them for free so yeah I'll take that as my payment!
  8. KforHorizon
    KitKat Oct 6, 2016
    Or improving their quality control! :rolleyes:
    jstepa, ziepicwaffle, csabreu and 2 others like this.
  9. ziepicwaffle
    ziepicwaffle , Oct 6, 2016 :
    Hmm... Maybe wipe system and reflash the ROM and open Gapps for 7.0...
    se7enlyn likes this.
  10. TugaPower
    Jelly Bean Oct 6, 2016
    TugaPower , Oct 6, 2016 :
    Build 06/10/2016
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 0.9 RC CM14 #OnePlus #Android 7.0
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366
    Relative to gapps, testing open gapps 7.0 nano package, working without issues
    http://opengapps.org/?api=7.0&variant=nano
    ROM have OTA updates already implemented, so next update you will be receving notification update, configure the CM Updater ( TugaPower ROM Updates) check sheduler.
    Kernel its permissive
    Gello removed and replaced by latest TugaBrowser beta v52.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t347245
    Viper4Android included and removed audiofx
    Multi ROM support out of the box
    Kcal control included ( use Color control included to tune RGB )
    Powered by SuperSU 2.78 SR1 by @Chainfire
    Full support for suhide out of the box, just flash latest suhide after rom flash, nothing more to do, this will survive next OTAs but the list is reseted each OTA, will see with chainfire a temp solution for this.
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    MicroG is still not working, it need new update to work on Nougat but the support its already present.
    What does not works:
    Settings/Status bar options its not working very good
    Change log:
    Security Patch from 5 October
    Fixed flac files play ( need some test, please report if it works )
    Project name: device_oneplus_bacon
    Fix Bluethoot not working because of new changes
    Project name: android_external_ffmpeg
    ffmpeg: Adjust build hacks
    android: Don't use Snapdragon LLVM when building
    vp9: fix a few signed integer left-shifts.
    Project name: android_build
    Show complete command with args when ComputePatch fails
    ninja: use host's ninja if it exists
    Project name: android_prebuilts_gcc_darwin-x86_arm_arm-linux-androideabi-4.9
    Add missing symlink for stripper to the kernel toolchain
    Add missing -androidkernel-readelf symlink
    Project name: android_hardware_ril
    Allow board to provide libreference-ril
    Fix RIL_CardStatus_v5 Parceling.
    RIL: Fix CellInfo for RIL version < 12
    ril-caf: Allow using RIL version 10
    Project name: android_hardware_qcom_media
    mm-video: venc: Correct a typo in variable name
    Project name: android_hardware_qcom_display
    Revert "sdm: Add support for adaptive variable refresh feature"
    sdm: Always include kernel headers
    sdm: Add support for legacy extension library
    Fix duplicate copy file rules
    Project name: android_hardware_qcom_audio
    hal: Remove compress voip formats and voip_rx flag
    hal: Fix routing issue for voip use case
    hal: Stop log spam when COMPRESS_VOIP_ENABLED is not defined
    hal: Fix device selection at start of the voice call
    Add AudioRecord timestamps
    hal: Don't try to record using 3-mic unless we mean it
    Project name: android_frameworks_av
    Rename dump methods to dumpState
    camera: Better fix for janky metadata issue
    Revert "Stagefright: update decoding times for recording with batch-input"
    Remove incorrect forward declaration
    IMediaSource: Pack alignment of ReadOption struct
    media: Fix graphic buffer leak.
    cameraservice: Resolve message vs start/stop preview races
    stagefright: Setup B-frames for codecs
    camera: add ability for a device to specify MAX_CAMERAS
    camera: Workaround for GCC-compiled HAL3 drivers
    omx: Improve debug messages for null buffers
    avextensions: Fix build for non QCOM
    camera: Allow devices to load custom CameraParameter code
    avextensions: Fill in QC feature support (part 1)
    stagefright: Trivial FFMPEG fixes
    Project name: android_frameworks_native
    Conditionally revert "HWC2: Don't set null handle for client layers"
    surfaceflinger: fix build for devices not using hwc2
    surfaceflinger: Fix build for HWC2
    Revert "input: Adjust priority"
    SF: Fix a couple of Layer ref count issues
    Build SF executable with USE_HWC2 when needed
    HWC2: Clear transform for SolidColor layers
    HWC2: Use SolidColor composition for DimLayer
    HWC2: Kill logspam for non-HWC virtual displays
    HWC2: Fix virtual displays
    HWC2: Hook up to BoardConfig variable
    HWC2: Skip validate/present if display is off
    Build fix after CAF merge
    Project name: android_frameworks_base
    Frameworks: Allow/Prevent notification light in Zen mode (1 of 3)
    lights: Automatically generate an LED color for notifications
    NotificationManager: always restore identity on notification error
    batteryservice: remove unneeded catch clause and fix build
    batteryservice: Avoid exception if device doesn't support HVDCP
    base: cm-iy adb notification icon
    SystemUI: add volume tones back
    connectivity-service: fix/improve unique hostname
    Ensure DHCP requests have nonempty hostnames
    Download: Add support to manually pause/resume download
    Forward port CM Screen Security settings (1/2)
    keyguard: Allow disabling fingerprint wake-and-unlock
    camera: Tolerate errors in getHorizontal/VerticalViewAngle
    Screenshots info is not updated when device is plugged in MTP mode
    Reset mCurrentUserId when fingerprintd died
    MountService: Prevent NPE with DropBoxManager
    Revert "SystemUI: Fix no emergency call button on lock screen"
    Project name: android_frameworks_opt_telephony
    SIMRecords: If there's no EF_SPN record, fallback to EF_PNN
    DCT: Tear down MMS+default connections raised by config_enable_mms_with_mobile_data_off
    Project name: android_device_oppo_common
    configpanel: Fix bootup behavior
    Project name: android_bionic
    bionic: fix scorpion architecture
    linker: Make platform text relocations denial optional
    libc: allow forcing compilation with gcc
    bionic: Use a more simple strrchr for arm64
    libc: AArch64: Tune memcpy
    libc: ARM64: add assembly strrchr
    libc: ARM64: improve performance in strlen
    libc: ARM64: optimize memset.
    libc: ARM64: Optimize memcpy.
    libc: ARM64: remove bcopy from memset
    libc: arm: add optimized memchr implementation
    libc: Add Scorpion-optimized variant
    Project name: android_system_sepolicy
    sepolicy: Allow optional platform text relocations
    Project name: android_system_bt
    bt: Fix HCI driver selection logic for Qualcomm Bluetooth
    bt: Select H4 HCI driver when QC bluetooth prop is unset
    Revert "Fix the command timeout issue with TX idle timer"
    Project name: android_system_core
    Add color mode enums
    Project name: android_packages_providers_DownloadProvider
    DownloadProvider: Add support for manual pause/resume
    DownloadProvider: Display download speed in notification
    Project name: android_packages_providers_MediaProvider
    Project name: android_packages_apps_Dialer
    dialer: Hide SIP dial icon
    Remove SIP dial icon in dialer for some carriers
    Project name: android_packages_apps_CMParts
    CMParts: statusbar: Set summary for clock AM/PM style
    PackageListAdapter: unbreak icons
    ApplicationLightPreference: fix saving
    CustomDialogPreference: Properly dispatch onClick from OnDismissListener
    CMParts: Navigate backwards when up button is pressed
    Project name: android_packages_apps_SoundRecorder
    SoundRecorder: Add AAC recording option
    Project name: android_packages_apps_CMFileManager
    FileManager: Editor: Fix race on completion wait/notify
    Project name: android_packages_apps_Settings
    Settings: hook up volume tone preference to CMSettings
    Settings: forward port lock pattern grid size (2/2)
    settings: Unbreak PIN scramble
    Revert "Open WiFi network when pull out the USB line."
    Project name: android_packages_apps_Eleven
    Avoid NPE
    eleven: Fix crash when unplugging headphones
    Eleven: Set preferences on play
    Eleven: Do not uppercase unnecessarily
    Project name: android_packages_apps_Snap
    snap: Fix module name conflict
    Fix another mismerge of "SnapdragonCamera: fix screen flash on resuming"
    SnapdragonCamera: Fix blank preview issue during pause & resume
    Snap: Add picture resolutions for Axon 7
    Revert "cm: Unfork x86 compilers"
    This is cm14, adapt repo init command
    cm: Graduate from staging
    cm: Switch to CM GCC 4.9 forks
    Project name: android_vendor_cm
    extract_utils: Add ability to set custom device guard
    extract_utils: Add ability to set custom vendor.mk name
    cm: config: Select the appropriate default alarm tone
    Added option (-z) to generate a zipfile with the bugreport.
    sepolicy: Fix class* property trigger denial
    Project name: android_vendor_codeaurora_telephony
    Revert "IMS-VT: Add API to get CSretry config value"
    Download link:
    MeoCloud: https://1itbgd.s.cld.pt
    Gdrive: https://drive.google.com/open?id=0ByxlOYAKcbyTS2hmLTBmYmM4bk0
    Mega: https://mega.nz/#!EJtlSbLR!SZGudyVNug3dN-WjR6bpgsN1qUH4GGLY7Dm4UIvpu3U
    Android File Host: https://www.androidfilehost.com/?fid=312978532265362471
    MD5: 23dd21150c3fe4ff6ec98a031a09ebf1
    Please dont mirror for now the roms zips, thanks
    Special thanks to @@amardeep434 for initial work on making booting and also big thanks for @updateing
  11. ziepicwaffle
    Custom notification lights seem to be fixed! Settings are sticking and no force closes. Everything else is working so far on .9RC :)
    Edit: Forgot to mention, battery icon changes in status bar still do not work. October security patch included.
  12. se7enlyn
    Ice Cream Sandwich Oct 7, 2016
    se7enlyn , Oct 7, 2016 :
    Any option for lockscreen rotation?
  13. ziepicwaffle
    ziepicwaffle , Oct 7, 2016 :
    I don't think so... Where would one find that? Do you use lock screen rotation?
  14. avibored
    Honeycomb Oct 7, 2016
    avibored , Oct 7, 2016 :
    I want an app to block ads since no xposed is there do you guys use any app that works well for YouTube and other apps
  15. se7enlyn
    Yes lockscreen rotation helps when i charge my phone on my bedside table. In the ROM that I'm using now, it's in the display>rotation settings,
    ziepicwaffle likes this.
  16. ziepicwaffle
    ;) it's there and it works. That's interesting, I've never known about this feature. May try it out :p
    Edit: not really sure how to post pictures, evidently i did it wrong? screenshot doesn't appear to be working.
  17. se7enlyn
    Hint, when you tap reply, there is an UPLOAD A FILE button next to the post reply.
  18. se7enlyn
    I can't find this data folder, mind telling me exactly where. I've tried searching many times, is it in the Android folder?
  19. jstepa
    KitKat Oct 7, 2016
    jstepa , Oct 7, 2016 :
    It's in System (not in storage), you need root file explorer like FX
    se7enlyn and theshinybeast like this.
  20. theshinybeast
    Marshmallow Oct 7, 2016
    theshinybeast , Oct 7, 2016 :
    So , ETA of my OP3 is November 9th , you? Never thought I'd get all excited all over again but I am.:p
