58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. tye359
    Ice Cream Sandwich Oct 13, 2016
  2. ziepicwaffle
    ziepicwaffle , Oct 13, 2016 :
    Have you tried suhide or full unroot?
  3. p2p
    Honeycomb Oct 13, 2016
    p2p , Oct 13, 2016 :
    The safetynet api from google was updated so you must do the same and update Suhide to 0.54
  4. tye359
    tye359 , Oct 13, 2016 :
    thanks guys - that's a pain in the arse!
    Think i'll not bother, don't really care much for Snapchat!
    se7enlyn and ziepicwaffle like this.
  5. rajaspardeshi
    Ice Cream Sandwich Oct 14, 2016
    rajaspardeshi , Oct 14, 2016 :
    Is it just me, or is privacy guard not working in the lastest build? Settings app crashes when I try to open it.
  6. TugaPower
    Jelly Bean Oct 14, 2016
    TugaPower , Oct 14, 2016 :
    Its not working...
    rajaspardeshi likes this.
  7. TugaPower
    Although have this fixed on my device. Running 0.9.2 RC, will try to release OTA today.
  8. Pahapoika91
  9. niTe_RiDeR_Pro
  10. kidorikko
    Cupcake Oct 14, 2016
  11. tye359
    Ice Cream Sandwich Oct 15, 2016
    tye359 , Oct 15, 2016 :
    Live display works if you manually set it, auto doesn't work. SOT of about 4.5 hours
  12. kidorikko
    Cupcake Oct 15, 2016
    kidorikko , Oct 15, 2016 :
    Looks tempting.
  13. TugaPower
    Jelly Bean Oct 15, 2016
    Pahapoika91 likes this.
  14. venkata srihari
    Gingerbread Oct 16, 2016
    venkata srihari , Oct 16, 2016 :
    Where is the stock theme engine which will comes along with CM. I haven't seen any where in Tugapower ROM.
    darksavior21 likes this.
  15. jstepa
    KitKat Oct 16, 2016
  16. avibored
    Honeycomb Oct 16, 2016
    avibored , Oct 16, 2016 :
    Is there any way to get updates as incremental files rather than downloading the entire rom ?
  17. TugaPower
    Jelly Bean Oct 16, 2016
    TugaPower , Oct 16, 2016 :
    Build 15/10/2016
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 1.0 CM14 #OnePlus #Android 7.0
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366
    Relative to gapps, testing open gapps 7.0 nano package, working without issues
    http://opengapps.org/?api=7.0&variant=nano
    ROM have OTA updates already implemented, so next update you will be receving notification update, configure the CM Updater ( TugaPower ROM Updates) check sheduler.
    Kernel its permissive
    Gello removed and replaced by latest TugaBrowser beta v52.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Viper4Android included and removed audiofx
    Multi ROM support out of the box
    Kcal control included ( use Color control included to tune RGB )
    Powered by SuperSU 2.78 SR1 by @Chainfire
    Full support for suhide out of the box, just flash latest suhide after rom flash, nothing more to do, this will survive next OTAs but the list is reseted each OTA, will see with chainfire a temp solution for this.
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    MicroG is still not working, it need new update to work on Nougat but the support its already present.
    What does not works:
    Settings/Status bar options its not working very good
    Entering settings of selected lock screen it FCs
    Change log:
    Fix Privacy settings FC
    Fix flac files not playing
    Broke Lock Screen Settings, you can change the type of lock screen but not enter on is settings( fix will comme )
    Project name: kernel_oneplus_msm8974
    Increase max chg current to 2000/500mA
    Project name: android_packages_apps_Eleven
    Eleven: Simplify MediaSession queue processin
    Project name: android_frameworks_av
    mediaserver: Fix LOCAL_CFLAGS
    stagefright: omx: Don't signal dataspace change on legacy QCOM
    Project name: android_frameworks_native
    Rename dump methods to dumpState (again)
    Project name: android_frameworks_base
    Lockscreen: Introduce window type TYPE_KEYGUARD_PANEL
    input: Add option to toggle pointer icon when using stylus
    GlobalActions: Use circular user avatars
    Move high touch sensitivity and hovering to InputService
    statusbar: fix overlapping backgrounds when expanded
    Keyguard: Get your weather on... the lock screen [1/3]
    Add Weather Content Provider [5/5]
    Project name: android_device_qcom_sepolicy
    Sepolicy: Allow mediaserver to access media_settings_xml_prop
    Sepolicy: Allow mediaserver/mediacodec to access media
    Project name: android_system_tools_aidl
    AIDL: Add option to generate No-Op methods
    aidl: Support for duplicate methods having different arguments
    Project name: android_packages_services_WeatherService
    weatherservice: Update target SDK
    Project name: android_packages_services_CMAudioService
    cmaudioservice: Make direct boot aware
    Project name: android_packages_providers_WeatherProvider
    weatherprovider: Make direct-boot aware
    Project name: android_packages_apps_CMParts
    cmparts: Implement SummaryProvider for a few components
    cmparts: Add PartsRefresher for updating remote UI components
    cmparts: Weather service settings
    Fix fragment launching
    Fix reaching PrivacySettings menu
    CMParts: Update contributors cloud DB
    cmparts: Reposition a few dashboard items
    cmparts: Search improvements
    Project name: android_packages_apps_Settings
    settings: Add permissions for CMParts
    settings: Add link to Weather settings in CMParts
    Keyguard: Get your weather on... the lock screen [3/3]
    Project name: android_packages_apps_LockClock
    lockclock: Use protected broadcasts when talking to SystemUI
    Project name: android_packages_apps_Nfc
    Nfc: read extra properties of Mifare Classic
    Use cm android_system_tools_aidl
    cm: Update to android-7.0.0_r14
    Project name: android_build
    ninja: increase maximum suffix length
    Add LOCAL_AIDL_FLAGS
    Project name: android_vendor_cm
    sepolicy: Allow apps to find the weather service
    Project name: cm_platform_sdk
    cmsdk: Update API
    cmsdk: Add support for PartsRefresher to CMPartsPreference
    cmsdk: Migrate STYLUS_ICON_ENABLED to CMSettings
    cmsdk: Remove duplicate legacy system element
    cmsdk: Start Weather service in onUnlockUser
    cmsdk: Add constraints support for CMHardware features
    cmsdk: Re-enable use of custom AIDL generation
    Project name: android_external_cyanogen_UICommon
    uicommon: Fix StopMotionVectorDrawable for N
    BluetoothAdapter: disable logspew
    systemui: Tweak the media queue UX
    SystemUI: tuner: Allow Tuner API for System settings
    Revert "Add support for sending raw commands"
    SystemUI: make sure to expand all the way when flinging
    Do not scan a file which cannot be read
    Should use scan flag, or it will not scan device.
    MediaScanner: Detect folders
    Properly handle null URIs.
    MiniThumbFile: Fix image/bitmap retrieval
    Rework thumbnail handling
    mountservice: Don't nuke all volumes when decrypting
    mountservice: Shut down volumes before restarting framework
    MountService: ensure VolumeRecord with UUID exists before modifying
    perf: Add missing activity resumed trigger
    Revert "SystemUI: tuner: Fix up button navigation in activity"
    Project name: android_packages_apps_CMWallpapers
    cmwalls: Clear lockscreen wallpaper too
    cmparts: Cleanup on aisle 9
    CMParts: weather: Actually mark selected provider as active
    cmparts: Overhaul the performance and power setttings
    Project name: android_packages_apps_WallpaperPicker
    Update the WallpaperPicker
    Project name: android_packages_apps_Bluetooth
    bluetooth: Disable logspam from GattService
    Kill logspam during battery level events
    bluetooth: Tone down the logspam
    Settings: Add toggles for several CM additions
    settings: Implement SummaryProvider for external tiles
    Settings: battery: Add CMParts perf profiles preference
    cm: Re-add WallpaperPicker
    Update to smali/baksmali v2.2b3
    cm: changelog: Update changelog for 13.0 releases
    cm: config: Build telephony-ext for all devices
    cmsdk: Update performance profile descriptions
    Download link:
    MeoCloud: https://9nbt2k.s.cld.pt
    Gdrive: https://drive.google.com/open?id=0ByxlOYAKcbyTeUhReWdkekp1Qkk
    Mega: https://mega.nz/#!YJ01BRZJ!4_3Xk51SmxwOrxFTsyCQzkfFf9haRr-f8eWSQ3qyAk4
    Android File Host: https://www.androidfilehost.com/?fid=385035244224385079
    MD5: 174b1eaebfebb74536b5178090e3fff9
    Please dont mirror for now the roms zips, thanks
    Special thanks to @amardeep434 for initial work on making booting and also big thanks for @updateing
    jstepa and ziepicwaffle like this.
  18. TugaPower
    Not possible.
    avibored likes this.
  19. baluda
    jstepa and tye359 like this.
  20. jstepa
    KitKat Oct 17, 2016
    jstepa , Oct 17, 2016 :
    No need to thank me, @TugaPower is the Dev, he is the one you should thanking ;)
