58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. jstepa
    KitKat Oct 17, 2016
    jstepa , Oct 17, 2016 :
    Kill app back button setting back in Developer options and it actually works :)
  2. mickcost
    Honeycomb Oct 17, 2016
    mickcost , Oct 17, 2016 :
    How can I do a screenshot? (Power button menu doesn't work in settings menu). Thanks in advance.
  3. se7enlyn
    Ice Cream Sandwich Oct 17, 2016
    se7enlyn , Oct 17, 2016 :
    volume down+power button
  4. tye359
  5. theshinybeast
    Marshmallow Oct 17, 2016
    theshinybeast , Oct 17, 2016 :
    Yep, battery life is going to be mighty on Nougat when we get more solid builds. For the moment this suits me fine. Until the 9th N anyway.
  6. mickcost
    se7enlyn likes this.
  7. butaixyz8016
    butaixyz8016 , Oct 17, 2016 :
    I couldn't find anything in that system folder, :(
  8. Prinze Martin
    Prinze Martin , Oct 17, 2016 :
    Mount system ;) and then it'll be there
    ziepicwaffle likes this.
  9. butaixyz8016
    Would u please explain those steps a bit more!
  10. Prinze Martin
    Mount system in twrp
    Then go to file manager in twrp
    navigate to system folder >>> priv-app >> setupwizard folder
    Go in and delete it :D
    se7enlyn and ziepicwaffle like this.
  11. butaixyz8016
    Thanks
    Prinze Martin likes this.
  12. ziepicwaffle
    Ice Cream Sandwich Oct 18, 2016
    ziepicwaffle , Oct 18, 2016 :
    Flashed the first build, one thing I found was that when you try to customize the lock screen, (security, screen lock, pressing on the gear) it force closes.
  13. venkata srihari
    Gingerbread Oct 18, 2016
    venkata srihari , Oct 18, 2016 :
    Last app switching not working with any of the settings (double tap/long press either with menu/home button)
  14. ziepicwaffle
    With the way nougat works, you can just double tap the recent apps button and it'll go to your last app.
    baluda likes this.
  15. venkata srihari
    Here the problem is not going to last app, ROM providing an option specifically last app.. But when you configure the button press functionality to last app, it's not working that's the issue, developer needs to be solve it in coming release.
  16. ziepicwaffle
    Eh I was just trying to say that there's an alternative that is even better than long press so it doesn't really matter. Also, the dev doesn't "need" to solve anything.
    Also by the way, most likely cm will fix this problem sometime
  17. Antoine Vdb
    KitKat Oct 18, 2016
  18. jstepa
    KitKat Oct 19, 2016
  19. highdiver_2000
    Ice Cream Sandwich Oct 19, 2016
  20. jstepa
    KitKat Oct 19, 2016
    jstepa , Oct 19, 2016 :
    Don't know, don't use them...
    highdiver_2000 likes this.
