58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. Ganeshgns
    Froyo Oct 19, 2016
  2. highdiver_2000
    Ice Cream Sandwich Oct 19, 2016
    highdiver_2000 , Oct 19, 2016 :
    I just realised that if I want to try Nougat, I have to root to backup. Upgrade, root to restore and unroot.
    jstepa likes this.
  3. jstepa
    KitKat Oct 19, 2016
    jstepa , Oct 19, 2016 :
    Just download whole ROM...
  4. Ganeshgns
    Froyo Oct 19, 2016
    Ganeshgns , Oct 19, 2016 :
    Thanks but it seems like the ota downloaded just fine!
    Flashing now :D
    jstepa likes this.
  5. Ganeshgns
    Froyo Oct 19, 2016
    ziepicwaffle likes this.
  6. rajaspardeshi
    avibored likes this.
  7. se7enlyn
    rajaspardeshi likes this.
  8. se7enlyn
    se7enlyn , Oct 19, 2016 :
    yes
    afaik
    battery icon
    system profiles
    battery performance setting
    mostly minor issues
  9. Ganeshgns
    Froyo Oct 19, 2016
    so not a issue for me ! Thanks!
    se7enlyn likes this.
  10. Roshanghosh09
    Roshanghosh09 , Oct 19, 2016 :
    I was also facing the same . . .
    Go to twrp wipe dalvik , cache , system & them flash the latest build n latest gapps . .
    Worked fine fr me. .
  11. Antoine Vdb
    KitKat Oct 19, 2016
    tye359 and jstepa like this.
  12. jstepa
    KitKat Oct 19, 2016
  13. ziepicwaffle
    se7enlyn and jstepa like this.
  14. jstepa
    KitKat Oct 19, 2016
    Don't know if he will, this is only test build
    Edit: Going fast through settings I noticed no changes, but I can be wrong...
    ziepicwaffle and se7enlyn like this.
  15. kartike4u
  16. kartike4u
  17. kryshnakishore
  18. se7enlyn
    yes, i have experienced this issue before. i had all 4 cores running at 2.4mhz.
  19. kartike4u
  20. kartike4u
    kartike4u , Oct 19, 2016 :
    Hey man
    In every other cm ROM the charging voltage was around 3.6v but in this ROM it shows 4v and the amp reading are high too (checked using ampere),I'm asking you this because as u know small change in voltage from recommended on can harm the hardware very easily so is this fine or not?
