58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. kmistry007
    Cupcake Nov 7, 2016
    kmistry007 , Nov 7, 2016 :
    Also I want to install the Microsoft mods in this , is it possible to flash it .
  2. Anglofile
    Eclair Nov 7, 2016
    Anglofile , Nov 7, 2016 :
    What file did you flash for the Pixel camera?
  3. darksavior21
    Froyo Nov 7, 2016
  4. Dojojo122
    Donut Nov 7, 2016
    Dojojo122 , Nov 7, 2016 :
    How to underclock?
  5. tye359
    Ice Cream Sandwich Nov 7, 2016
    tye359 , Nov 7, 2016 :
    install kernel adiutor
  6. Dojojo122
    Donut Nov 7, 2016
  7. se7enlyn
    se7enlyn , Nov 7, 2016 :
    Open it , go to cpu and under clock, don't forget to apply on reboot and then reboot.
    tye359 likes this.
  8. Anglofile
    Eclair Nov 7, 2016
    Found another thing that doesn't work - individual sound levels for ring volume and notifications. If one of them is changed the other follow. @TugaPower
  9. TugaPower
    Jelly Bean Nov 7, 2016
    TugaPower , Nov 7, 2016 :
    N5 pushed true OTA, check the changelog on OTA and read carefully, no time for regular post. Time to sleep 4h
    Just backup your sms if you need, also make sure the backup use xml backup, N5 will clear your sms because of new database or phone will fc in loop and SIM not detected.
    All written on changelog.
    Read all
    Cya guys
  10. okak24
    Gingerbread Nov 7, 2016
    okak24 , Nov 7, 2016 :
    Daniel e link meo para download? não vai ter? abraço e obrigado
  11. keen36
    Gingerbread Nov 8, 2016
  12. avibored
    Honeycomb Nov 8, 2016
    avibored , Nov 8, 2016 :
    I dirty flashed the n5 and didn't lose messages is that bad..
  13. mickcost
  14. se7enlyn
    Ice Cream Sandwich Nov 8, 2016
    se7enlyn , Nov 8, 2016 :
    Titanium backup?
  15. hmayaz
    hmayaz , Nov 8, 2016 :
    I used SMS Backup & Restore
    Worked great and had no problems
  16. mickcost
    mickcost , Nov 8, 2016 :
    Thanks
  17. mickcost
    se7enlyn likes this.
  18. keen36
    keen36 , Nov 8, 2016 :
    if you use titanium backup, use the xml method (the yellow one)! it is more compatible and tugapower mentioned that it is preferable
    edit:
    i think that there was a database change, that is why it is deleted in the first place. that probably also means that backup methods which are more direct could fail easily.
    ziepicwaffle likes this.
  19. tye359
  20. mickcost
    I installed TugaPower N5 following your instructions: everything OK. Thanks.
    adlibitum, keen36 and ziepicwaffle like this.
