58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. TugaPower
    Jelly Bean Jan 21, 2017
    TugaPower , Jan 21, 2017 :
    Build 2017/01/21 #OPO
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 15.1 LineageOS #laos #OnePlus #Android 7.1.1 #OMS7 #Substratum #OPO
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise Deuteronomy 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Kcal Support
    Gello removed and replaced by latest TugaBrowser beta v54.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    kernel 3.4.113
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to SuHide ( fixed iGoogle November security patch, install suhide to pass safety net )
    Full support to Substratum OMS7 :)
    Kernel support to NetHunter aka Kali its present, you need to flash the generic zip and you are good to go ( https://goo.gl/UsFuPg )
    Powered by SuperSU 2.79 Stable
    What does not works:
    Let me know to add here :)
    Change log:
    N15.1
    bacon: re-enable blur effect support
    Project name: android_system_sepolicy
    domain: Create a dummy domain for qc's rmt and let it access /dev/mem
    Project name: android_hardware_intel_img_psb_video
    Encode: correctly handle VAConfig attributes on medfield/CTP
    Fix video encoding on clovertrail
    Add clovertrail support (based on the tree at 686e11709b57bc57ee94c3166f187fec959fd43b)
    Cleanup pvr_drv_video makefile for clovertrail support
    Project name: android_hardware_intel_common_omx-components
    omx-component: fix video corruption
    Project name: android_hardware_qcom_display
    Fix duplicate copy file rules
    Project name: android_hardware_qcom_audio
    msm8974: Remove deprecated FM stuff.
    Project name: android_hardware_qcom_fm
    Use BOARD_HAVE_QCOM_FM flag
    Revert "fm: do not build for BCM FM devices"
    Project name: android_vendor_cm
    apns: Add Freedompop foggmobile APN
    bootanimation: get all the parts
    build: Append -dtb to kernel image name if TARGET_KERNEL_APPEND_DTB is set
    cm: bootanimation: Improve boot animation
    extract_utils: Detect output existence before moving it for backup
    cm: bootanimation: Clear intermediaries
    vendor: lineage boot animation
    Sepolicy: Add perm for find cmstatusbar
    cm: config: Remove obsolete props
    Project name: cm_platform_sdk
    cmsdk: Fix @deprecated annotation mismatch warnings
    Project name: android_frameworks_base
    windowmanager: Add support for blur effects
    PlatLogo: Show lineage platlogo when tapping on LineageOS version
    SystemUI: add Notification volume stream title
    Readded Platinum Alarm sound as I miss it in newer builds.
    AudioService: Launch default music player on headset connect
    NetworkManagement : Add ability to restrict app data/wifi usage
    sensors: Allow opting out of default batch size
    Switch to Lineage chromium-webview fork
    Project name: android_build
    build sign_target_files_apks.py: clean tmp on exit
    Project name: android_packages_apps_Settings
    Revert "settings: Remove lock screen blur stuff breaking build"
    Settings: point to lineageos updater
    Settings: Launch default music player on headset connect
    Settings: Add volume link notification switch
    Move notif volume pref on top of increasing ring pref
    Settings: per-app cellular data and wifi restrictions
    Settings: DeviceInfo: Clean up the PlatLogo checks
    Project name: android_packages_apps_CMParts
    Update contributors cloud db
    Use valid network resources in getNetworkModeString()
    CMParts: profiles: Remove old PagerTabStrip hack
    ButtonBacklight: Preview timeout once user stops dragging
    CMParts: Update button backlight brightness in real time
    Download links:
    Android File Host: https://www.androidfilehost.com/?fid=745425885120702144
    MD5: 072467654df1b98336e87d79d851060b
    Please dont mirror for now the roms zips, thanks
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
  2. Anglofile
    Eclair Jan 22, 2017
    Anglofile , Jan 22, 2017 :
    If you select a wallpaper both for background and lock screen it isn't added to the lock screen, but it works if it is added separately.
  3. Zh_kilat
    Android Q Jan 22, 2017
  4. guimenez
    Gingerbread Jan 22, 2017
    guimenez , Jan 22, 2017 :
    Everytime I update the rom do I need to flash the firmware? I'm using oxygen firmware because of the signal.
    Thanks
  5. Amin78
  6. fenice
    KitKat Jan 22, 2017
    fenice , Jan 22, 2017 :
    N
    No, you don't unless you have specific problems.
  7. guimenez
    Still have problem with solid streamz.
    Doesn't play channels, something related with audio.
    KoRnFlOcUs likes this.
  8. TARUNMANGLIA
    Cupcake Jan 23, 2017
    TARUNMANGLIA , Jan 23, 2017 :
    Hi,
    Need help installing ROM.
    I have oxygen OS 2.1.4 with One plus recovery
    I tried installing TWRP recovery but it is not working.
    Followed below steps:
    1. connected mobile to PC with USB debugging option
    2. adb reboot-bootloader
    3. fastboot flash recovery twrp.img -> displayed success
    4. fastboot reboot
    Switch off and reboot to recovery - still see One plus recovery
    Followed below steps as well
    3. fastboot erase recovery -> displayed success
    4. fastboot flash recovery twrp.img -> displayed success
    Not able to install TWRP in recovery.
    Also observed phone heating issue now while using LTE.
  9. guimenez
    Gingerbread Jan 23, 2017
    guimenez , Jan 23, 2017 :
    What ROM are you using and from what dev?
    I need that to help you returning to normal TWRP.
  10. TARUNMANGLIA
    guimenez likes this.
  11. guimenez
    Go here and follow the instructions, this will change TWRP from Oxygen to TugaPower.
    This is the only thing i use to change from Oxygen to another ROM when i lost the default TWRP.
  12. TARUNMANGLIA
    Thanks guimenez, will try this option and confirm if it worked for me.
  13. sathish D C
  14. joaoppecurto
    armmani2001 likes this.
  15. armmani2001
    KitKat Jan 23, 2017
  16. sathish D C
    Gingerbread Jan 24, 2017
  17. sathish D C
  18. sathish D C
    sathish D C , Jan 24, 2017 :
    Xtreme music with viper is working with this rom? most 7.x.x roms not supporting Xtreme music. Where can we find the blur effects in this ROM
  19. fenice
    KitKat Jan 24, 2017
    fenice , Jan 24, 2017 :
    Go to the System Settings menu and type "blur" in the search field, it's not that hard to find.
  20. Zalx
    Cupcake Jan 24, 2017
    Zalx , Jan 24, 2017 :
    Hello,
    I'm on N15, and today system avert me to an ota update N16.
    So i downloaded it.
    And now how can i upgrade it ?
    Via twrp with install and choose the N16.zip update ?
    All the data / app are deleted after that or only the system is updated ?
    Thanks for your help
