58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. TugaPower
    Jelly Bean May 22, 2017
    TugaPower , May 22, 2017 :
    Build 2017/05/20 #OPO
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 35.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise Deuteronomy 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser beta v55.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    kernel 3.4.113
    Kernel permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root and Magisk Manager
    What does not works:
    Let me know to add here :)
    Change log:
    Project name: android_kernel_oneplus_msm8974
    kernel: Fix potential refcount leak in su check
    Project name: android_system_keymaster
    Fix bugs regarding KeyStore::isHardwareBacked always returning true.
    Project name: android_system_sepolicy
    Allow recovery to alter / on userdebug/eng builds
    Project name: android_vendor_cm
    extract_utils: fix extracting XML files containing binary characters
    Project name: android_frameworks_native
    sensorservice: Fix orientation sensor for HAL's missing rotation vector sensor
    Project name: android_build
    Revert "Revert "ota: Remove cruft we don't care about""
    apicheck_msg_current: Don't do this in LineageOS
    Project name: interfacer
    Add interface to get API version and app authentication status
    Fix permissions for CTS [2/2]
    Project name: android_packages_apps_CMParts
    Update contributors cloud
    Project name: android_packages_apps_Dialer
    Dialer: lock screen appear before incoming call screen
    Changelog N34
    kernel: Only expose su when daemon is running
    Project name: android_hardware_qcom_audio
    msm8996: ultrasound: Initial open source hal for Elliptic Ultrasound
    Project name: android_system_core
    Revert "init.rc: set initial cpuset to all cores"
    Project name: android_hardware_qcom_display
    display: Add color metadata definition
    hwc2: Only set display_width and display_height when equal to zero
    Project name: cm_platform_sdk
    cmsdk: Add CMSettings option for QS auto brightness
    Project name: android_frameworks_base
    SystemUI: Add tunable for auto brightness icon
    Validate handler of wakelock option for flashlight.
    telecom: Fix order of arguments when creating Details object
    Project name: android_packages_apps_DeskClock
    DeskClock: Use accelerometer instead of orientation sensor
    DeskClock: Move default action for flip and shake to overlay
    DeskClock: Fix "GoogleNow cancel alarms crash"
    Project name: android_packages_apps_Snap
    Snap: Fix crash switching from back to front cam in video mode
    CMParts: add brightness slider tunables
    Thanks all for the support.
    Download links:
    Android File Host: https://www.androidfilehost.com/?fid=889764386195900603
    MD5: 828f8eef76e3e5070826cc2151abd0f7
    Please dont mirror for now the roms zips, thanks
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
    TheJames and pikota like this.
  2. sridiculous
    Gingerbread Jun 5, 2017
    sridiculous , Jun 5, 2017 :
    Found an issue where Face unlock isn't working. Both setup and actual usage are both non functional. Hope that gets fixed.
    Faced another weird issue today where the phone became unresponsive to anything, but the LED notifications were still working, not sure what the issue might have been, will post more updates should I encounter this again.
  3. Ciriac George
    Cupcake Jun 5, 2017
  4. ahnaf084
    Cupcake Jun 12, 2017
  5. winstonsmith
    Honeycomb Jun 12, 2017
    winstonsmith , Jun 12, 2017 :
    You flash your firmware in twrp along with rom, gapps etc...
    TugaPower likes this.
  6. TugaPower
    Jelly Bean Jun 18, 2017
    TugaPower , Jun 18, 2017 :
    Build 2017/06/18 #OPO
    TugaPower ROM G+
    #TugaPower N 37.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Disable manually AudioFX to hide the icon from drawer
    Call Record
    Multi-ROM Support
    kernel 3.4.113
    Kernel permissive
    Powered by Magisk root v13.x and Magisk Manager 5.0.x beta versions
    Change log:
    Project name: android_device_oneplus_bacon
    bacon: disable NfcF HCE
    manifest: android-7.1.2_r8 -> android-7.1.2_r17
    Project name: android_system_bt
    bt: Disable AVRCP 1.6
    libcutils: fix schedboost after 31f78ddf4ea2ab7963d873cb16db98e976346468
    Project name: android_hardware_ril
    ril: fix a memory leak.
    Project name: android_hardware_ti_omap4
    omap4: Correct disabling of dirty regions invalidation
    Add sensitive numbers for Israel.
    sensitive_pn: Add sensitive phone numbers for Czech Republic
    sensitive_pn: Add Canadian sensitive numbers
    sensitive_pn: Add more numbers from the Netherlands
    fix check_blacklist function to work on wiped /system partition
    sensitive_pn: Add sensitive numbers for Serbia
    Project name: android_device_qcom_common
    power: Use the correct opcode for STOR_CLK_SCALE_DIS
    Aapt2: Fix png leak
    Destroy Allocation right away on exception
    SymbolComparator operator() is missing const
    StatusBar: Catch OOM caused by third-party icons
    Adopt lockscreen shortcut hint from AOSP
    CaptivePortalLoginActivity correctly gets UserAgent
    Prettify the captive portal sign-in activity
    LocationTile: Behave like other tiles
    Fix a use-of-uninitialized-value warning.
    Check for spurious wake ups
    Reduce hwui CPU time by using glDrawRangeElements
    Stop holding mProxyLock while downloading PAC script data.
    Format Japanese numbers using national format when in Japan.
    NullPointerException: Attempt to invoke virtual method 'int android.os.Parcel.dataSize()' on a null object reference
    SystemUI: allow user to dismiss a locked task by swiping it away manually
    SystemUI: animate icon when locking a task
    SystemUI: Support recents task locking
    fingerprint: handle PerformanceStats NULL pointers
    Optimised hwui rounded corners shader
    Remove FastJNI optimization on AssetManager to avoid dead lock.
    Fixed NPE in canAddMoreManagedProfiles
    QS: Remove listeners only if added
    SystemUI: Remove trailing whitespace on high_accuracy_description
    StorageManager: Improve exception handling
    Add support for page theme color to WebView and WebChromeClient.
    Project name: android_external_chromium-webview
    Update webviews
    Project name: android_external_stagefright-plugins
    ffmpeg-extractor: StageFright supports Opus files
    Revert "FFmpegExtractor: Don't use our extractor when we agree with StageFright"
    Project name: android_packages_services_Telephony
    Fix Phone Service crash on MSIM devices as Guest user
    VoicemailSettingsActivity: Fix some NPEs
    Project name: android_packages_apps_WallpaperPicker
    Fix bad wallpaper preview image format
    Project name: android_packages_apps_Nfc
    NfcNci: make T3T/Nfc-F HCE optional
    Project name: android_packages_apps_Email
    Adjust Email UnitTests to e353ae2ea19c9ea800d10b37e05de7b0ea1aeeb4
    Project name: android_packages_apps_CarrierConfig
    Remove TIM from non-roaming networks list of H3G IT
    CarrierConfig: allow 3 ITA roaming
    SnapdragonCamera: Fix ghosting when non-zsl in VGA/QVGA size
    SnapdragonCamera: Fix live shot image stretch when recording is 4K
    SnapdragonCamera: Fix photo reversed when enable selfie Mirror
    SnapdragonCamera: Fix preview in wrong size
    SnapdragonCamera: Fix front camera preview flipped
    SnapdragonCamera: Fix preview is flipped on 8996
    SnapdragonCamera: Camera1 Selfie Mirror orientation check
    SnapdragonCamera: Fix Camera1 force close when refocusing the picture.
    SnapdragonCamera: Change video snapshot picture size logic
    SnapdragonCamera: Avoid cancel AF shortly after trigger
    SnapdragonCamera: Fix crash during UI stress test
    SnapdragonCamera: Fix OutOfBoundsException in monkey test
    SnapdragonCamera: Fix FC for NullPointerException
    SnapdragonCamera: Reset zoom value when resuming
    SnapdragonCamera: Fix capture with flash will get black image.
    SnapdragonCamera: Fix FC cause by Null pointer
    SnapdragonCamera: Make copy of location before altering timestamp
    Snap: Sign with platform key
    Add orientation correction for landscape devices
    Snap: Simulate back button press when menu back button is pressed
    Project name: android_packages_apps_CustomTiles
    CustomTiles: Kill Battery Saver Tile
    Project name: android_packages_apps_Settings
    Revert "Settings: Fix internal storage summary for non-emulated storage"
    Settings: Fix automatic hotspot turn off summary
    Project name: android_packages_apps_Eleven
    Eleven: Remove unused permission REAL_GET_TASKS
    Project name: android_packages_apps_AudioFX
    AudioFX: Sign with platform key
    Project name: android_packages_apps_Bluetooth
    BluetoothOppTransferActivity: fix after ad46f6a52d7240ed1e2127c4263a5cbcf454df09
    Project name: android_packages_apps_Terminal
    Terminal: Fix keyboard Ctrl- and ALT-key input.
    Project name: android_packages_apps_Gallery2
    Gallery2: support GIF animation
    Increase the size of the tiles when decoding images
    Download: https://cld.pt/dl/download/e025530a-1059-40a1-aab5-d8abda4fccc7/TugaPowerN37.zip
    MD5: 4cc9eb44745b4b0e7c2ee307ad76659c
    Sources :
    ziepicwaffle likes this.
  7. full1993
    Gingerbread Jun 23, 2017
    full1993 , Jun 23, 2017 :
    @TugaPower im really interested in trying this out but I never installed anything manually before. Im still on CM 13.1.2. Is there any video that I could use to install everything and get everything working? Thanks in advance!
    wilsmits likes this.
  8. Xavkno
    Cupcake Jun 23, 2017
    Xavkno , Jun 23, 2017 :
    Can i dirty flash this rom over normal lineages os without encountering problems?
  9. winstonsmith
    Honeycomb Jun 23, 2017
  10. winstonsmith
    winstonsmith , Jun 23, 2017 :
    Tried that last month ...fail. But maybe you will get it right
  11. viren66
    Donut Jun 26, 2017
    viren66 , Jun 26, 2017 :
    change to high accuracy
    fenice and TugaPower like this.
  12. sridiculous
    Gingerbread Jul 7, 2017
    sridiculous , Jul 7, 2017 :
    @TugaPower , Can we get the face unlock fixed maybe in the next update? That's been broken for a while and should make to the list of things not working.
  13. daniga74
    Jelly Bean Jul 7, 2017
    daniga74 , Jul 7, 2017 :
    Which gapss are you using?
    Did you try with opengapss?
  14. sridiculous
    Gingerbread Jul 8, 2017
    sridiculous , Jul 8, 2017 :
    I am using opengapps as well, been using it since N27 and I believe it stopped working from N31 or 32.
  15. daniga74
    Jelly Bean Jul 8, 2017
    daniga74 , Jul 8, 2017 :
    Did you try to remove face unlock pattern and set again?
  16. sridiculous
    Stupid of me not to have tried that. Works now after removing and adding again. Thanks for the tip.
    daniga74 likes this.
  17. TugaPower
    Jelly Bean Jul 9, 2017
    TugaPower , Jul 9, 2017 :
    Build 2017/07/08 #OPO
    TugaPower ROM G+
    #TugaPower N 40.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip
    Replaced audiofx with Viper4Arise 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log:
    Jully Security
    manifest: android-7.1.2_r17 -> android-7.1.2_r24
    Revert "cm: add custom tiles project"
    Project name: proprietary_vendor_oneplus
    bacon: Update adreno blobs to LA.BF.1.1.3_rb1.12
    sensitive_pn: Enter full list of Indian MCC codes
    sensitive_pn: Enter full list of GB MCC codes
    sensitive_pn: Enter full list of US MCC codes
    Add LTE support for China Telecom Macau.
    Revert "cm: build custom tiles app"
    bacon: Remove deprecated BT props
    bacon: Update adreno blob listing
    PowerManagerService: add a config to light up buttons only when pressed
    SystemUI: Fix heads up tile off color
    Added show volume panel tile to QS
    SystemUI: add USB Tether tile
    QS: add Sync tile (1/2)
    SystemUI: Add heads up tile (1/2)
    SystemUI: add caffeine qs tile (1/2)
    SystemUI: Readd AmbientDisplayTile.
    SystemUI: Add adb over network tile
    Alarm: fix database indices
    Project name: android_packages_apps_LockClock
    LockClock: add option to suppress date on widget
    Gallery2: Fix crash after returning from albums in wallpaper picker
    Download: https://www.androidfilehost.com/?fid=745425885120747171
    MD5: 5d84f6f497cf544d0f357a4324572526
    pikota, warwolf22 and manlio62 like this.
  18. TugaPower
    Jelly Bean Jul 23, 2017
    TugaPower , Jul 23, 2017 :
    Build 2017/07/23 #OPO
    TugaPower ROM G+
    #TugaPower N 42.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log:
    charger: Fix small battery capacity font
    repopick: Add 'reset' option
    BootReceiver: check console-ramoops-0
    PowerProfile: allow overriding default power profile
    ScreenCap : Add jpeg support
    Remove ahbottomnavigation
    Project name: android_hardware_qcom_fm
    FM: Use some sane colors
    Use density independent units for the timer digits for sw360dp
    BUGBASH-612: do not send phone numbers to non-ssl sites for reverse/forward/people lookups
    Gallery: Fix potential crash
    Gallery2: Switch to navigationbar from support libs
    Download: https://www.androidfilehost.com/?fid=745425885120750709
    MD5: 1add8ee269d885e0ae22828dbfe36a8a
    Sources :
  19. TheJames
    Jelly Bean Jul 28, 2017
    TheJames , Jul 28, 2017 :
    Thanks man. Been with you since marsh. Will stick with you till this device dies. Hopefully you get into 'O'
    TugaPower, pikota and winstonsmith like this.
  20. TugaPower
    Jelly Bean Jul 30, 2017
    TugaPower , Jul 30, 2017 :
    Build 2017/07/30 #OPO
    TugaPower ROM G+
    Telegram Group: https://t.me/TugaPowerOPO
    #TugaPower N 43.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Powered by Magisk root v13.x and Magisk Manager 5.0.x versions
    Change log:
    Updated V4A Core and Module to latest available versions
    drivers: soc: qcom: Add error handling in function avtimer_ioctl
    msm : dma_test: Initialize newly allocated memory
    arm: oabi compat: add missing access checks
    USB: digi_acceleport: do sanity checking for the number of ports
    USB: mct_u232: add sanity checking in probe
    ALSA: seq: Fix race at creating a queue
    net: wireless: bcmdhd: check privilege on priv cmd
    Revert "Revert "vendor: cm: sepolicy: Allow rw-access to system_app_data_file""
    extract_utils: Fix cleanup variables assigment
    config: Set some default TWRP flags
    templates: Remove empty cat << EOF
    sensitive_pn: add EU 116 Numbers
    overlay: Enable “Panic Detection” mode
    apns: correct the mvno_match_data for MasMovil Spain
    sensitive_pn: Include France DOM (Overseas regions) codes
    LocationTile: Improve strings
    AppOps: Prevent deadlock when making note of applications
    cm.xml: sync caf 8998 hals
    Update webview
    Revert "Revert "SnapdragonCamera: Adding PRIVILEGED true""
    Dialer: Fix compilation warnings
    Dialer: Move padding from layout to spinner
    Project name: android_packages_apps_ContactsCommon
    Allow to edit the SIP field of contacts stored locally
    Revert "Revert "Gallery2: set module privileged in Android.mk to delete photos on SD card.""
    Gallery2: Fix various issues and glitches
    Gallery2: Fix potential crash
    Project name: android_system_netd
    SoftAp: Fix compilation in netd if LIBWPA_CLIENT_EXISTS undefined.
    Download: https://www.androidfilehost.com/?fid=889764386195919578
    MD5: 7d57aa2a82af05dbf823d9b6b6975f70
    manlio62 likes this.
