58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. TugaPower Jelly Bean Aug 6, 2017
    TugaPower, Aug 6, 2017 :
    Build 2017/08/06 #OPO
    TugaPower ROM G+
    Telegram Group: https://t.me/TugaPowerOPO
    #TugaPower N 44.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Disable manually AudioFX to hide the icon from drawer
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser beta v55.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    Kernel permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root v13.x and Magisk Manager 5.0.x versions
    What does not works:
    Let me know to add here :)
    Change log:
    Project name: android_kernel_oneplus_msm8974
    ASoC: msm: qdsp6v2: Add range checking in msm_dai_q6_set_channel_map
    ASoC: msm: q6dspv2: use correct variable type to store ION buff size
    ASoC: msm: qdsp6v2: Fix build after mismerge
    drivers: soc: add mutex to prevent response being processed twice
    trace: resolve stack corruption due to string copy
    ASoC: msm: qdsp6v2: Fix out-of-bounds access in put functions
    defconfig: msm: Disable CONFIG_CP_ACCESS
    ANDROID: ion: Protect kref from userspace manipulation
    ion: blacklist %p kptr_restrict
    ion: Fix use after free during ION_IOC_ALLOC
    msm: cpp: Fix for integer overflow in cpp
    input: misc: fix heap overflow issue in hbtp_input.c
    ANDROID: ion: check for kref overflow
    net: ipc_router: Register services only on client port
    net: wireless: bcmdhd: fix use-after-free in _dhd_pno_get_for_batch()
    ALSA: info: Check for integer overflow in snd_info_entry_write()
    perf: don't leave group_entry on sibling list (use-after-free)
    sctp: validate chunk len before actually using it
    drivers: qcom: ultrasound: Lock async driver calls
    msm: camera: sensor: Validate eeprom_name string length
    msm: camera: fix bound check of offset to avoid overread overwrite
    msm: cpp: Fix for buffer overflow in cpp.
    proc: prevent accessing /proc/<PID>/environ until it's ready
    fs/exec: fix use after free in execve
    Project name: android_vendor_cm
    Add WOM Internet/MMS (CL) apn
    qcom: Allow setting custom audio, display, and media HALs
    templates: Update to show usage for new extract_files features
    extract_files: Add support for paths without system/
    extract_files: Add support for specifying blob sections
    build: Update smali and baksmali to 2.2.1
    Project name: android_frameworks_opt_telephony
    Telephony: Keep preferred SMS Sim
    Project name: android_frameworks_base
    AppOps: Fix yet another deadlock
    Project name: android_packages_apps_Snap
    Snap: fix low resolution front camera switch icon
    Project name: android_packages_apps_Eleven
    Eleven: Add WRITE_MEDIA_STORAGE permission
    Eleven: Promote to privileged app
    Eleven: allow artwork to scale down
    Project name: android_packages_apps_Dialer
    Dialer: Provide upgrade path for removed lookup providers
    Project name: android_packages_apps_Gallery2
    Gallery2: Fix various issues and glitches
    Gallery2: Fix potential crash
    Gallery2: Switch to navigationbar from support libs
    Gallery2: Fix can't parse documents uri
    Gallery2: Fix views overlap
    Gallery2: Support GIF animation
    Gallery2: Increase the size of the tiles when decoding images
    Gallery2: Support the newly added media file types in MTP mode
    Gallery2: Fix use of uninitialized stack variables
    Gallery2: Remove unused renderscript class
    Gallery2: Fix spelling error
    Gallery2: Properly declare the own permissions
    Gallery2: Remove more possible NPEs
    Gallery2: Enable frames in the editor
    Gallery2: Remove slideshow option if there are only videos
    Gallery2: Remove 3D overscroll effect
    Gallery2: Disable dummy starting window
    Gallery2: Fix up audio effects dialog
    Gallery2: Everyone or no one
    Gallery2: Replace hamburger menu with bottom bar
    Gallery2: Change all share intents to chooser style
    Gallery2: Update menu
    Gallery2: Update theme
    Gallery2: Move & improve CAF strings
    Gallery2: Make sure no NPE happens
    Gallery2: Remove invalid comment from manifest
    Gallery2: Cleanup renderscript flags in Android.mk
    Gallery2: Reduce logspam in video player
    Gallery2: Store DATE_TAKEN as milliseconds
    Gallery2: Modify AOSP EL translations
    Gallery2: Remove CAF translations
    Gallery2: Add record time to details view
    Gallery2: Fix crash of gallery on showing details
    Gallery2: Fix crash when Bluetooth service is disabled
    Gallery2: Try to open existing camera
    Gallery2: New icon
    Gallery2: Bump minsdk and targetsdk version
    Gallery: FilterShowActivity: Fix loading spinner being show forever
    Gallery: TileImageView: fix NPE
    FaceDetect: Catch more linker errors during initialization
    FaceDetect: Catch linker errors during initialization
    Bump API to match dependencies.
    Add missing includes.
    Cleanup warnings in jni.
    Fix misc-macro-parentheses warnings in Gallery2.
    Float.NaN != ... always evaluates to true, use Float.isNaN.
    Rename app back to Gallery
    Thanks all for the support.
    Download: https://www.androidfilehost.com/?fid=889764386195921093
    MD5: 2d40fdb5249b4b045a747233a2135fa7
    Please dont mirror for now the roms zips, thanks
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
    daniga74 and manlio62 like this.
  2. TugaPower Jelly Bean Aug 12, 2017
    TugaPower, Aug 12, 2017 :
    Build 2017/08/12 #OPO
    TugaPower ROM G+
    #TugaPower N 46.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Gello removed and replaced by latest TugaBrowser ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log:
    Changelog N46.0
    Updated TugaBrowser to latest version v60.x
    Added latest tcpdump tool from tcpdump source
    sctp: avoid BUG_ON on sctp_wait_for_sndbuf
    tcp: do not lock listener to process SYN packets
    ipv4: keep skb->dst around in presence of IP options
    ping: implement proper locking
    tty: n_hdlc: get rid of racy n_hdlc.tbuf
    TTY: n_hdlc, fix lockdep false positive
    selinux: fix off-by-one in setprocattr
    Revert "proc: smaps: Allow smaps access for CAP_SYS_RESOURCE"
    net: wireless: bcmdhd: adding boundary check in wl_cfg80211_mgmt_tx
    ASoC: msm8x10-wcd: prevent out of bounds access
    Project name: android_hardware_qcom_bt
    libbt-qcom: Allow reading BT address from property
    Project name: android_packages_services_Telephony
    Telephony: Correct missing italian translation
    PhoneToggler: Update preferred network mode setting
    Changelog N45.0
    August Security Update
    manifest: android-7.1.2_r24 -> android-7.1.2_r29
    Project name: android_system_bt
    Revert "Merge tag 'LA.UM.5.5.r1-05300-8x96.0' into cm-14.1"
    msm: camera: sensor: Validate i2c_freq_mode in msm_cci_set_clk_param
    Input: gtco - fix crash on detecting device without endpoints
    Input: powermate - fix oops with malicious USB descriptors
    Input: ati_remote2 - fix crashes on detecting device with invalid descriptor
    unix: correctly track in-flight fds in sending process user_struct
    unix: properly account for FDs passed over unix sockets
    msm: crypto: set CLR_CNTXT bit for crypto operations
    input: touchscreen: gt9xx: fix memory corruption in Goodix driver
    soc: qcom: scm: add check to avoid buffer overflow
    ASoC: soc: prevent risk of buffer overflow
    ASoC: msm: qdsp6v2: return error when copy from userspace fails
    ASoC: msm: Fix to avoid crash during voip call
    Project name: android_hardware_qcom_audio
    Fix security vulnerability: Equalizer setParameter memory overflow
    Add Correios Celular (BR) APN
    SystemUI: Remove unnecessary brightness icons
    SystemUI: Fix battery meter view blacklist handling
    Download: https://www.androidfilehost.com/?fid=673368273298978179
    MD5: 6fab4c982e8d2bb1a03edeca6d539bba
    Sources :
  3. TugaPower Jelly Bean Sep 16, 2017
    TugaPower, Sep 16, 2017 :
    Build 2017/09/16 #OPO
    TugaPower ROM G+
    #TugaPower N 48.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Powered by Magisk root v14.x and Magisk Manager 5.0.x versions
    Replaced Trebuchet with latest Lawnchair beta ( https://github.com/Deletescape-Media/Lawnchair )
    Change log:
    Changelog N48.0
    Update security Patch to September
    Update Magisk to v14.x
    Update V4A core and Magisk module to latest versions
    Project name: android_hardware_broadcom_wlan
    net: wireless: bcmdhd: update bcm4354/4356 FW (7.35.101.8)
    Project name: android_hardware_qcom_display
    display: Fix ColorMetaData
    display-caf: msm8996: Use ColorMetaData in SDM in hwc2
    display-caf: 8996: Add color metadata to libgralloc1
    hwc2: Only set display_width and display_height when equal to zero
    hwc2: Handle empty lists in AcceptDisplayChanges
    msm8996: hwc2: check for null layers in layer map
    hwc2 : Fix layer updating flag
    gralloc: Return an error if the buffer was not mapped
    Revert "Revert "gralloc: Default to 601 color space""
    hwc2: Workaround use after free by surfaceflinger
    hwc2: Update composition types on AcceptDisplayChanges
    gralloc: Disable UBWC for writeback buffers
    hwc2: Initialize color mode to native
    hwc2 : Allow only top most cursor layer
    Revert "gralloc: Return an error if the buffer was not mapped"
    hwc2: Fix solid fill
    sdm:hwc2: Store higher order mode id in case of clash
    hwc2: Fix retire fences
    hwc2: Always store a release fence if a layer is presented
    hwc2: Use current frames retire fence only for the primary
    8996/HWC2: Return this frame's retire fence
    hwc2: Remove default mode application at boot.
    hwc2: Support HWC2_CAPABILITY_SKIP_CLIENT_COLOR_TRANSFORM
    hwc: Set ioprio for vsync thread
    Fix duplicate copy file rules
    Don't build lights module if vendor supplies it
    display: Use project pathmap
    Project name: android_hardware_qcom_media
    Fix duplicated OMX.qcom.audio.decoder.aac entry
    media: libOmxSw encoders require prop headers :(
    mm-video: Disable proprietary extension
    venc: Fix VQZip issue
    media: Avoid collision with FFMPEG plugin
    media: Use project pathmap
    mm-video-v4l2: venc: Advertise correct output-size for meta-mode
    qcom_target: Commonize UM target HALs
    cm: Remove old Changelog file
    cm: Remove partner interface
    cm: Remove app suggest feature
    cm: Remove LiveLockScreenService
    cm: Remove theme engine leftovers
    Project name: cm_platform_sdk
    cmsdk: Use intent extradata for WiFi triggers
    cmsdk: Disable unused services
    Project name: android_frameworks_minikin
    Reject unsorted cmap entries.
    Back-port fixes for b/62196835
    Don't disable the GPS prematurely
    PrivateStorageInfo: Exclude primary physical volume total space
    Project name: android_frameworks_av
    MPEG4Source: fix fragmented read.
    stagefright: fix crash due to bad timestamp index
    stagefright: check aac_frame_length to prevent infinite loop
    MediaPlayerService: fix access of mPlayer in client
    audio effects: filter reserved effect commands
    MPEG4Extractor: ensure returned status is checked.
    Check frame handle validity before freeing buffer.
    Change MPEG2 reinit Error Handling
    Track: Check buffer size of static tracks
    MPEG4Extractor: check size for yrrc box
    AudioFlinger: Fix memory allocation for client-less tracks
    Notify Errors Appropriately from SoftMPEG2
    EffectBundle: Check value size for get preset name
    Fix TOCTOU problem in libstagefright_soft_aacenc
    omx: Skip the whole dataspace signaling on legacy QCOM
    Add missing extension length check while parsing BNEP control packets
    Free p_pending_data from tBNEP_CONN to avoid potential memory leaks
    Add a missing check for PAN buffer size before copying data
    Add missing packet length checks while parsing BNEP control packets
    Add missing continuation offset check for SDP continuation requests
    Disable PAN Reverse Tethering when connection originated by the Remote
    Allocate buffers of the right size when BT_HDR is included
    WideAnglePanoramaUI: Show switcher on Stop Capture
    Snap: fix highspeed and high-framerate video recording
    Project name: android_packages_apps_Settings
    Back-port ag/2491664
    AppOpsDetails: Generate correct summary when changing list prefs
    Settings: Allow devices to provide remote gesture preferences
    Settings: Fix internal storage summary for non-emulated storage devices
    Project name: android_packages_resources_devicesettings
    Add strings for devices' custom gesture handlers
    manifest: switch to our forks of several repos
    cm: Use msm8996 HALs for 8953 & 8937
    cm: Remove unused projects
    Project name: android_external_libhevc
    Limit boundary PU sizes in case of errors
    Fix array size for hrd parameters
    Check number of output buffers and sizes
    Return error for invalid crop parameters
    Project name: android_external_tremolo
    Use heap instead of alloca in res012.c
    Project name: android_external_skia
    Defend against ICOs with large BMPs embedded DO NOT MERGE
    Project name: android_external_libavc
    Decoder: Fixed allocation of pv_map_ref_idx_to_poc_buf.
    Decoder: Fixed overflow in refernce list creation.
    Initialize DPB structures to valid values.
    Added error check for output buffer size.
    Project name: android_external_sonivox
    Fix interpolator
    Project name: android_external_sqlite
    fix FTS3 column pointer handling
    Project name: android_external_libvpx
    libvpx: Cherry-pick 8b4c315 from upstream
    Project name: android_packages_apps_Nfc
    Add READ_EXTERNAL_STORAGE for file based Uri while beaming.
    Project name: android_packages_apps_TvSettings
    Use new updater activity name for update button
    Project name: android_packages_apps_Messaging
    37742976 - Catch bad gifs
    Download: https://www.androidfilehost.com/?fid=673368273298986372
    MD5: 13293392049be8f2d658e13888bdcbba
    manlio62 likes this.
  4. sridiculous Gingerbread Sep 19, 2017
    sridiculous, Sep 19, 2017 :
    updated to n48 and used it for a full day without issues. on reboot, stuck in a boot loop showing 'Android is starting'. tried rebootung, wiping dalvik / cache, reinstalling n48 and n47 as well, but no luck. running out of options now and any help is greatly appreciated.
  5. TugaPower Jelly Bean Sep 19, 2017
    TugaPower, Sep 19, 2017 :
    Did you installed some Magisk module? Try on TWRP clear art-dalvik and cache
  6. sridiculous Gingerbread Sep 19, 2017
    I did not install anything from magisk. I did boot into recovery and cleared dalvik and cache as well, but to no avail. Running multirom and booting into sailfish is the only thing working.
  7. sridiculous Gingerbread Sep 19, 2017
    I wiped system and cache and reinstalled n48 with gapps and is back up now. Had to reinstall some apps and reset right permissions for some more, but is back up and running. Thanks for the help.
  8. wilsmits Jelly Bean Sep 20, 2017
    wilsmits, Sep 20, 2017 :
    Same question here
  9. Shizuma Cupcake Sep 21, 2017
    Shizuma, Sep 21, 2017 :
    Hey guys,
    I'm new here. Just bought a Second-hand OnePlus One and am pretty surprised it's got TUGAPower ROM based on LineageOS. Can't find much on the Internet a noob could understand so I've got some simple questions, hoping you can make me a bit less of a noob...
    1. Is TUGA a default system? Or was the phone modded?
    2. Can I, a noob, use it? Or should I switch to OxygenOS?
    3. CAN I even switch?
    4. What's Magisk Man?
    5. What's ViPER4Arise?
    And some other odd question, not sure if it's got something to do with the OS..
    6. How come after multiple factory resets there are still photos of the pre-owner on the phone? (I tried to get rid of them but can only delete them. However they're back after FR).
    BTW sorry for opening a new thread but wasn't really able to find anything about this whole thing.
    Thanks in advance!
    Greetz, Julia
  10. fenice Jelly Bean Sep 22, 2017
    fenice, Sep 22, 2017 :
    TugaPower is a modified version of the LineageOS ROM (which is the successor to the CyanogeMod ROM (the original for the OnePlus ONE.
    Anyone can use it, why would you want to downgrade to OxygenOS? (I'm joking, before anyone bites :)).
    Why would you want to?
    You mean Magisk Manager, it's part of the Magisk package for rooting a ROM and it's built into this ROM thanks to Daniel.
    It's a sound system for Android.
    What do you mean by "FR"?
    You didn't actually open a new thread, you've added it to the TugaPower thread. ;)
    TugaPower likes this.
  11. TugaPower Jelly Bean Sep 24, 2017
    TugaPower, Sep 24, 2017 :
    Build 2017/09/24 #OPO
    TugaPower ROM G+
    #TugaPower N 49.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Please be sure you are using one TWRP that can handle firmware flash. ( http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366 )
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip/
    Call Record
    Multi-ROM Support
    Kernel permissive
    If you guys want again Trebuchet just install as regular app ( https://meocloud.pt/link/4aa8084d-fb02-49ee-ab51-8c3006d710bc/Trebuchet.apk )
    Change log:
    SystemUI: locked tasks should have a valid view
    System Profiles in QS Tiles
    [1/3] SystemUI: add burnIn protection setting
    SystemServer: Don't start widget service when it is alarm boot
    ActivityManager: Remove POWER_OFF_ALARM intent leftover
    Always hide protected apps from the recent tasks list
    Recents: Add accessibility descriptions for lock ImageViews
    SystemUI: Add separate pref screen for the status bar tuner
    SystemUI: Revert some Tuner changes
    extract_utils: implement LOCAL_MODULE_RELATIVE_PATH
    cm/aosp/cafremote: Make variables local
    envsetup: Fix cmremote for AOSP projects
    cm: Add CMSettings package to power_off_alarm_apps
    [2/3] Settings: add burnIn protection setting
    AppOpsState: Hide undeclared Privacy Guard OPs
    Eleven: Create one cursor per background task
    Project name: android_packages_apps_CMParts
    CMParts: Update intent to start the status bar preferences
    [3/3] cmsdk: add burnIn protection setting
    Revert "cmsdk: Don't change ring volume or mode if DND is enabled"
    cmsdk: Run in core apps only for poweroff alarm boot
    Make CMParts a protected component manager
    audioflinger: Use offloaded effects in case of PCM offload
    Download: https://www.androidfilehost.com/?fid=889764386195932463
    MD5: 519148a9a3487fd2478f0c5aec4b0b9d
    Sources :
    manlio62 and daniga74 like this.
  12. TugaPower Jelly Bean Oct 8, 2017
    TugaPower, Oct 8, 2017 :
    Build 2017/10/08 #OPO
    TugaPower ROM G+
    #TugaPower N 50.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log:
    Project name: android_device_oneplus_bacon
    bacon: remove old-modem hack
    October Security patch
    Fix allocating buffers of the right size when BT_HDR is included
    Project name: android_system_vold
    Fix bug in cryptfs_verify_passwd with hardware disk encryption
    Project name: android_hardware_ril
    Fix multi sim support and warnings
    Fix security vulnerability in pre-O rild code.
    vendor: We are now LineageOS
    Fix security hole in GateKeeperResponse.
    Enforce policy for camera gesture in keyguard
    SystemUI: Cleanup BatteryMeter
    SystemUI: Improve battery icons
    Revert "Camera: ignore torch status update for aux or compsite camera"
    SystemUI: Hide ambient display tile if device does not support it
    Don't crash when checking if components are protected
    Fix 'potential memory leak' compiler warning.
    Check buffer size in useBuffer in software components
    stagefright: avoid buffer overflow in base64 decoder
    Add EFFECT_CMD_SET_PARAM parameter checking to Downmix and Reverb
    Fix memory leak in OggExtractor
    Skip track if verification fails
    Project name: android_packages_apps_PackageInstaller
    Disable overlays while installer is resumed
    Settings: Correct german translation for 1 registered fingerprint
    Disabling the activate button when paused
    Gallery: Kill media effect dialog on movies
    Gallery2: Fix crash when muting a video
    Fix gallery crash when trimming video
    Download: https://www.androidfilehost.com/?fid=673791459329051985
    MD5: 1060090ea34d6d9b70c16eb15193ca99
  13. TugaPower Jelly Bean Oct 17, 2017
    TugaPower, Oct 17, 2017 :
    Build 2017/10/17 #OPO
    TugaPower ROM G+
    #TugaPower N 51.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Compiled using UBER-Linaro ( smoth and battery should be now more improved )
    Change log N51.0 :
    Project name: android_external_wpa_supplicant_8
    Patched against KRACK
    Clear PMK length and check for this when deriving PTK
    Add debug prints on PMK configuration in WPA supplicant
    WPA: Extra defense against PTK reinstalls in 4-way handshake
    Remove all PeerKey functionality
    Add MGMT_TX_STATUS_PROCESS command for testing purposes
    FT: Do not allow multiple Reassociation Response frames
    WNM: Ignore WNM-Sleep Mode Response without pending request
    TDLS: Reject TPK-TK reconfiguration
    Fix PTK rekeying to generate a new ANonce
    Prevent installation of an all-zero TK
    Extend protection of GTK/IGTK reinstallation of WNM-Sleep Mode cases
    Prevent reinstallation of an already in-use group key
    hostapd: Avoid key reinstallation in FT handshake
    Set EAPOL-Key Key Length field to 0 for group message 1/2 in RSN
    extract_utils: Allow to interrupt the extraction
    Revert "Always hide protected apps from the recent tasks list"
    Core: Battery warning levels are inclusive, not exclusive
    Telephony: Workaround for MWI on Sprint
    Disable overlays while installer is resumed"
    Project name: android_packages_apps_Calendar
    Calendar: Show week start and end in title for Week view
    Eleven: Fix potential NPE when media server crashes
    Eleven: Don't use a sticky service
    Project name: android_packages_apps_Recorder
    Recorder: Advertise that we can record voice
    Download: https://androidfilehost.com/?fid=673791459329054476
    MD5: 137e8a6f4d86abb67244775870977486
  14. adarsh.mattu Gingerbread Oct 21, 2017
    adarsh.mattu, Oct 21, 2017 :
    I was on N46 and since yesterday I started getting random reboots. I updated to N51 and got stuck in a bootloop.
    Managed to get out of it somehow when all of a sudden phone rebooted again and was stuck in a bootloop again. (Dirty flashed N51, then tried to clean flash but phone rebooted in the middle of flashing).
    Have flashed N46 again and the phone seems to be okay for now. Anybody else faced a similar issue? Any reason for this issue?
  15. manlio62 Jelly Bean Oct 21, 2017
  16. adarsh.mattu Gingerbread Oct 21, 2017
    Did that too. Clean flashed N51. Everything went fine but a minute into N51 and the phone went into a bootloop. Has been the same since.
    Can't restore the backup from TWRP (says system partition read only)
    Can't flash again ( phone reboots in the middle of the process and goes in a bootloop again)
    EDIT: Was able to clean install N51 (phone was plugged in while flashing). But as soon as I unplugged my phone it switched off and went into that dreaded bootloop. I have no clue why. Could you help?
    EDIT #2: Battery was the problem. It's dead. That's why had issue while flashing N51 and restoring. Restored my previous TWRP backup and it's all fine now (I have to keep the plugged in at all times though)
  17. bnw Honeycomb Oct 31, 2017
    bnw, Oct 31, 2017 :
    I have two problems with mij OPO and Android Auto. I have searched all over the internet and tried many things, but without success. So maybe it has to do with this ROM or its settings? Or maybe it has not to do it all with this ROM, but I would like to know if other people with the OPO with this ROM are having troubles with Android Auto.
    Otherwise I am very happy with this ROM and am using N52 now.
    Problem 1
    My problem is, that if I am using Android Auto and play music (What's App, different MP3 Players, Internet Radio, all through Android Auto) the sound stutters at some moments. At most when zoom in or out with Google Maps. Of course this is very anoying.
    I have tried different USB cables, different Android Auto settings, exclude Android Auto from optimization. Installed the ROM completely new and with minimum apps and settings......
    Problem 2
    Sometimes Google Voice commands seem to react on itself. If I dictate a message and Google repeat the message, starting with: "Okay, this is the message....." than it seems that it starts a new voice command, because Google heard the "Okay" word (yes, I know, it said it itself....)
  18. TugaPower Jelly Bean Nov 12, 2017
  19. TugaPower Jelly Bean Nov 22, 2017
    TugaPower, Nov 22, 2017 :
    Build 2017/11/22 #OPO #N
    TugaPower ROM G+
    #TugaPower N 53.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    3 finger screenshot support
    Change log N53.0 :
    November security patch
    SystemUI: LiveDisplay tile
    DPC should not be allowed to grant development permission
    Add stub for setCursorVisibility
    Prevent deadlock when using always-on legacy VPNs
    Add powerhint function that accepts an array of data
    SDP: Bounds check 'id' parameter for free_sdp_slot()
    Project name: android_system_core
    Fix integer overflow in utf{16,32}_to_utf8_length
    Project name: android_system_netd
    Invalidate dst caches when changing network permissions.
    Don't allow seamless handover to networks requiring permissions.
    Project name: android_hardware_qcom_keymaster
    keymaster: Fix compiler warnings
    keymaster: Fix TARGET_KEYMASTER_WAIT_FOR_QSEE
    configs: Fixed BTSCO samplerate mixer control
    Ensure IMS dial uses the correct CLIR mode.
    GsmCdmaPhone: Fallback to PhoneNumberUtils if telephony-ext fails
    Project name: android_frameworks_native
    Remove window obscurement information.
    Track graphic buffer mode in OMXNodeInstance
    EffectBundle: Check parameter and value size
    cm: build: kernel: Rework kernel module logic
    extract_utils: Fix pinning when not cleaning vendor dir
    Updated apns for device bringup for S4 Mini - serranolteusc
    build: Make eat use the latest zip in $OUT
    Added more USA sensitive phone numbers
    cm: Append time of day to zip names for unofficials
    Disable LiveDisplay by default for ATV
    Project name: android_libcore
    Fix NPE in Signature getCurrentSpi.
    Telephony: Add ERI configuration for U.S. Cellular
    Telephony: NetworkSelection: Don't show blank "available networks"
    Backport overlay security fix
    Revert "Make Transceive Length configurable for ISO DEP Technology"
    Project name: android_packages_apps_CarrierConfig
    CarrierConfig: Load ERI configuration for U.S. Cellular
    Settings: Strings: Modify a few german summaries
    AppOps: Add info if app doesn't request any blockable permissions
    AppOps: Add icon for "Toggle cellular data"
    Fix wrong format in AndroidManifest.xml
    Fix crash after deleting a video on Albums tab
    Recorder: Add possibility to delete last recording from notification
    Recorder: Fix wrong denial message in Recorder
    Recorder: fix a string
    Recorder: don't allow multiple instances of the app
    Recorder: Start recording after giving permissions
    Recorder: Fix permission request texts
    Recorder: update UI
    Recorder: start overlay service as not sticky
    Recorder: add constraint-layout aar lib for aosp build env
    Project name: android_external_libnfc-nci
    Revert "Add NAME_ISO_DEP_MAX_TRANSCEIVE_LENGTH"
    Project name: android_external_libmpeg2
    Propagating Error From impeg2d_pre_pic_dec_proc
    Check on Picture Dimensions
    Fix Half Pel MC on Last Ref Row
    Check Number of MBs to Skip.
    Replace memcpy with memmove to Solve Memory Overlap Error
    Added an out of bound check on u4_num_bufs in input argument
    Fix tile index buf alloc size
    Decoder: Updated error check while parsing num_ref_idx_lx_active.
    Decoder: Corrected variable datatypes in ih264d_get_implicit_weights.
    Decoder: Conceal picture only if valid picture buffer is obtained.
    Change log N52.0 :
    Added 3 fingers screnshot ( Gestures Settings )
    Lawnchair updated to version 1.1.0.1420
    SystemUI: Profiles tile should require authentication
    Telephony: Fix wrong en-translations
    Squashed support for multilanguage T9 dialer (1/2)
    Project name: android_packages_apps_PhoneCommon
    Squashed support for multilanguage T9 dialer (2/2)
    Calendar: Show year info for week view
    Download: https://androidfilehost.com/?fid=817906626617948534
    MD5: 022e2e42ae1b361ac72bcd0dffc55a4d
  20. TugaPower Jelly Bean Dec 10, 2017
    TugaPower, Dec 10, 2017 :
    Build 2017/12/10 #OPO #N
    TugaPower ROM G+
    #TugaPower N 54.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N54.0 :
    N 54.0 Change log
    Be sure you dont have an older Magisk module called Android Pay Fix on Magisk or NFC will start to FCing
    Project name: android_device_oppo_common
    common: Update KeyHandler for api change
    bacon: Advertise support for extended length nfc
    Project name: android_packages_apps_Lawnchair
    Changelog for build 1.1.0.1739
    Merge pull request #992 from divadsn/snow
    Update build-tools and support libs
    Fix derps
    Oh no, it's raining dead smiles!
    Add more customization for snowflakes
    Add size scale for snowflakes
    Add rotation attribute for snowflakes
    Move snowfall settings to own category
    SystemUI: Fix title text clipping when task lock button is visible
    ZenModeHelper: Allow lights by default
    fw/b: Return a KeyEvent instead of a boolean in KeyHandler
    Revert "libstagefright: Use proper ctts offset"
    Add ATV apps AppDrawer and LineageCustomizer
    ATV: Ship AppDrawer
    extract_utils: Use temporary folder for system dump
    repopick: Support overriding the default commits count to check
    vendor: enable multi-user across all devices
    extract-files: Bring back old behavior for SRC
    sensitive_pn: Add BG human trafficking and domestic abuse hotlines
    Project name: android_packages_apps_Trebuchet
    Trebuchet: Use ICU4J public APIs
    BugFix:Correct fullBearer in APNSettings
    Telephony: Fix Crash in SimStatus Fragment
    Settings: fix vibrate for calls in Setting app displayed incorrect issue
    Settings: back icon doesn't work in format SD as portable page.
    Settings: Fix settings force close
    Settings: Fix crash when disconnect wifi
    Project name: android_packages_apps_AppDrawer
    Initial commit
    CMParts: gestures: Update KeyHandler for API change
    CMParts: gestures: Add volume down/up actions
    CMParts: Add strings for stylus gestures
    Project name: android_external_chromium-webview
    Update webviews to Chromium 63.0.3239.83
    Download: https://www.androidfilehost.com/?fid=889964283620771314
    MD5: acb4b7a1fedcd7d7ab6d25d690766a1c
    Sources :
