58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. TugaPower
    Jelly Bean Dec 12, 2017
    TugaPower , Dec 12, 2017 :
    Some of you already noticed that N55 it's already in OTA, did not have time to push it over ear, will do that latter end of the day.
    Its basically December security patch and one issue fixed that sometimes the install button would not work when installing an apk.
    Mean while you can use the site to download and check changelog. It already have the new build.
    http://tugapower.tk/downloads/oneplus-one/
  2. TugaPower
    Jelly Bean Mar 4, 2018
    TugaPower , Mar 4, 2018 :
    Build 2018/03/04 #OPO #N
    TugaPower ROM G+
    Telegram Group: https://t.me/TugaPowerOPO
    #TugaPower N 57.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash. ( http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366 )
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip/
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Disable manually AudioFX to hide the icon from drawer
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    Kernel permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root v16.x
    Replaced Trebuchet with latest Lawnchair beta ( https://github.com/Deletescape-Media/Lawnchair )
    If you guys want again Trebuchet just install as regular app ( https://meocloud.pt/link/4aa8084d-fb02-49ee-ab51-8c3006d710bc/Trebuchet.apk )
    Compiled using UBER-Linaro ( smoth and battery should be now more improved )
    3 finger screenshot support
    What does not works:
    Let me know to add here :)
    Change log N57.0 :
    Be sure you dont have an older Magisk module called Android Pay Fix on Magisk or NFC will start to FCing
    February 2018 Security Patch
    Project name: android_frameworks_base
    *Gabriele M - Update tint of resource icons of third party QS tiles
    *qjohn - SystemUI: Fix LiveDisplay tile off color
    *Unpublished - livedisplay: Allow tile creation before boot completed phase [2/2]
    *meganukebmp - SystemUI: Fix crash when taking screenshot in partial screenshot view
    *Michael Bestas - GlobalActions: Misc power menu cleanup
    *Italian Quadcore - GlobalActions: Fix setting ringer mode in global actions
    *Tom Marshall - fw: GlobalActions: Always dismiss any existing dialog
    *longyu.huang - The DUT can't screen shot in guest mode
    *Gabriele M - Keyguard: Don't apply input restriction if disabled by profile
    *Paul Keith - PhoneWindowManager: Make sure KeyDisabler is always called on boot
    *Beverly - DO NOT MERGE Backporting potential usb tapjacking precaution.
    *Chong Zhang - mtp: fix double free of thumbnail data
    *Leon Scroggins III - Throw OOME if Bitmap.nativeCreate fails
    *Adam Vartanian - Adjust Uri host parsing to use last instead of first @.
    *Alexander - SysUI: Add Russian translation for accessibility_battery_level_charging
    Project name: android_packages_apps_Settings
    *Antony Sargent - Reword bluetooth confirmation dialog
    *Paul Keith - FingerprintEnrollFindSensor: Don't overlay front for side sensors
    *Michael W - DevelopmentSettings: Fix possible NPE
    *Bruno Martins - DevelopmentSettings: Hide OEM unlock by default
    Project name: android_frameworks_av
    *Robert Shih - httplive: check for malformed EXT-X-STREAM-INF
    *Dongwon Kang - Apply input buffer validation also to AVC and MPEG4 encoders
    *Kevin Rocard - IAudioPolicyService: Add attribute tags sanitization
    *Pawin Vongmasa - Fix the UAF bug caused by a dead stack variable
    *Marco Nelissen - Fix edge case when applying id3 unsynchronization
    *Mikhail Naganov - Add EFFECT_CMD_SET_PARAM parameter checking to Preset Reverb
    *Edwin Wong - Validate decryption key length to decrypt function.
    *Lajos Molnar - stagefright: MP4Extractor: allow 10% overhead on default sample size
    *Naveen Kumar P - Access AVCDEC context after create fail check
    *Harish Mahendrakar - SoftAVCDec: Handle zero length input without EOS
    *Naveen Kumar P - Access HEVC context after create fail check
    Project name: android_packages_apps_Snap
    *Michael Bestas - Snap: Fix translatability issues
    *Paul Keith - Snap: Update pano and video icons to be more like photo icons
    *Sebastian Haderecker - Snap: Add missing thumbnails for filter modes
    *Paul Keith - Snap: Rip out hdr-need-1x option
    Project name: android_packages_apps_Calendar
    *Cal Archer - calendar: fix first notification after boot
    Project name: android_packages_apps_Gallery2
    *Michael Bestas - Gallery: Fix translatability of CAF additions to filtershow
    *Michael Bestas - Gallery2: Remove more CAF Chinese translation modifications
    Project name: android_packages_apps_Dialer
    *Gabriele M - Don't crash if Blocked Number Storage is disabled
    Project name: android_packages_apps_CMParts
    *Simon Shields - CMParts: add one finger swipe up from home gesture string
    *Harry Youd - Regenerate contributors cloud
    *Michael Bestas - CMParts: Remove unused power menu actions and cleanup
    *LuK1337 - CMParts: Don't disable whole home button category
    Project name: android_packages_apps_TvSettings
    *Dan Pasanen - Fix setting root option first time
    Project name: android_packages_apps_Contacts
    *Michael W - Contacts: Don't crash if Blocked Number Storage is disabled
    Project name: android_packages_apps_Recorder
    *Bruno Martins - Recorder: Avoid NPE when screen recording is about to finish
    Project name: android_packages_apps_WallpaperPicker
    *Michael W - WallpaperPicker: Move strings for translation
    Project name: android_hardware_ti_omap4
    *Daniel Jarai - pvr-km: pass BOARD_USE_TI_LIBION to make
    *D. Andrei Măceș - init: Also try to load OMAPLFB as module
    *Michael Gernoth - omap4: Fix kernel module build
    Project name: android_hardware_libhardware_legacy
    *codeworkx - wifi: add flag to wait for kernel driver to get ready
    Project name: android_hardware_qcom_display
    *Dan Willemsen - Fix duplicate copy file rules
    *Steve Kondik - hwc: Set ioprio for vsync thread
    *Rashed Abdel-Tawab - tonemapper: Depend on kernel headers
    Project name: android_hardware_qcom_audio
    *Steve Kondik - hal: Haxed header
    *Arasthel - hal: Fix soft reboots due to proximity sensor
    *Balázs Triszka - msm8998: ultrasound: Initial open source hal for Elliptic Ultrasound
    *Deeraj Soman - configs: msm8909: Add sound model config params
    Project name: android_hardware_qcom_media
    *Uma Mehta - libc2dcolorconvert: Initialize surface def to NULL
    Project name: android_external_libvpx
    *Jerome Jiang - DO NOT MERGE | libvpx: Fix OOB caused by odd frame width.
    Project name: android_external_libavc
    *Ritu Baldwa - Decoder: Modified loop condition while parsing ref_list_reordering.
    *Harish Mahendrakar - Decoder: Handle dec_hdl memory allocation failure gracefully
    *Ritu Baldwa - Decoder: Fixed incorrect use of mmco parameters.
    *Hamsalekha S - Decoder: Detect change of mbaff flag in SPS
    *Hamsalekha S - Decoder: Increased allocation and added checks in sei parsing.
    Project name: android_external_toybox
    *Ilya Kuzmich - strings tests and bugfixes
    *Rob Landley - "printf %x 64" wasn't working right on 32 bit because a variable type was wrong.
    *Michael Bestas - toybox: Don't generate symlinks for a few tools
    Project name: android_external_aac
    *Jean-Michel Trivi - Fix out of bound memory access in lppTransposer
    *Jean-Michel Trivi - DO NOT MERGE Prevent out of bound memory access in GetInvInt
    Project name: android_external_chromium-webview
    *Luca Stefani - Update webviews to Chromium 64.0.3282.137
    Project name: android_external_wpa_supplicant_8
    *Andrew Elble - PMKSA: Fix use-after-free in pmksa_cache_clone_entry()
    Project name: android_external_sonivox
    *Robert Shih - Add recursion limit to XMF_ReadNode
    *Marco Nelissen - Fix memory leak
    Project name: android_external_libmpeg2
    *Venkatarama Avadhani - Adding Error Check for f_code Parameters
    Project name: android_external_libhevc
    *Naveen Kumar P - Update ctb pu map for I slice
    *Naveen Kumar P - Check if luma wd and ht are multiple of min cb size
    *Rakesh Kumar - Add PUSH-POP of D registers in Arm Neon 32 bit functions
    *Harish Mahendrakar - Fixed few issues in SAO arm assemblies
    *Harish Mahendrakar - Decoder: Handle ps_codec_obj memory allocation failure gracefully
    *Naveen Kumar P - Fix prev slice incomplete check
    *Naveen Kumar P - Set error skip ctbs as multiple 8x8 pus
    *Naveen Kumar P - Fix first frame error return
    *Naveen Kumar P - Return error for negative crop parameters
    *Naveen Kumar P - Consume bytes for sps with unsupported resolution
    *Naveen Kumar P - Fix slice address zero for not first slice in pic
    *Naveen Kumar P - Fix incomplete frame error
    Project name: android_frameworks_ex
    *Chris Craik - Skip composition of frames lacking a color map
    Project name: android_frameworks_opt_telephony
    *Dan Pasanen - ImsPhoneCallTrackerTest: add missing imports
    Project name: android_system_core
    *tintin - libnetutil: Check dhcp respose packet length
    Project name: android_system_vold
    *lambdadroid - vold: Accept Linux GPT partitions on external SD cards
    Project name: android_system_media
    *Emilian Peev - Camera metadata: Check source metadata size
    Project name: cm_platform_sdk
    *Pranav Vashi - livedisplay: Allow tile creation before boot completed phase [1/2]
    *Sam Mortimer - cmsdk: fix picture adjustment from depending on color balance
    Project name: android_vendor_cm
    *Paul Keith - cm: Allow IPv6 on roaming for T-Mobile US APNs
    *Paul Keith - cm: Consolidate T-Mobile US APNs
    *systemcrash - Added Cape Verde carrier CVMóvel default APN as configured by sales agents
    *systemcrash - Add APN for iD Mobile UK MVNO
    *Michael W - envsetup: Clean up for install[boot|recovery]
    *Aaron Kling - ATV: Default double tap on home to the recents menu
    *Matthew Freund - sensitive_pn: added Belgium & Switzerland
    *Jonas Schwarz - Updated Syma APN
    *Demon000 - overlay: frameworks: allow gms to access persistent data partition
    *Aaron Kling - Fix cmsdk overlay path for atv
    *Michael Bestas - cm: Make appended date of time to zip opt-in
    Thanks all for the support.
    Download: https://www.androidfilehost.com/?fid=818070582850497913
    MD5: dea4d1b9dfd82d1dd6d678ac0edc5f61
    Please dont mirror for now the roms zips, thanks
    Chinaroad likes this.
  3. CaBooSe
    Gingerbread Mar 22, 2018
    CaBooSe , Mar 22, 2018 :
    Stupid question .... and i know answer will be read read read :) but can this be flashed over tugapower 6 ?? M 105 ? .... I don't use google so i have no apps and data backups ...... or any suggestions on how to go about this without loosing all my apps and data?
    Tks in advance
  4. TugaPower
    Jelly Bean Mar 22, 2018
    TugaPower , Mar 22, 2018 :
    Not possible mate, is just too many changes and database upgrade will be not possible on all stuff, my advice is to use some third app data to backup all your stuff ( not system stuff ), only user data app.
  5. CaBooSe
    Gingerbread Mar 23, 2018
  6. TugaPower
    Jelly Bean Apr 29, 2018
    TugaPower , Apr 29, 2018 :
    Build 28/04/2018 #OPO #N
    TugaPower ROM G+
    #TugaPower N 58.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N58.0 :
    April's Security Patch
    Project name: android_device_oneplus_bacon
    overlay: SnapdragonCamera: Reduce frame size of panorama pictures
    bacon: underp netmgrd groups
    Grant netmgrd proper unix perms
    manifest: Track specific revision of svox to fix security vulnerability
    GlobalActions: Don't timeout a partial screenshot
    Adjust URI host parsing to stop on character.
    Check for null-terminator in ResStringPool::string8At
    [RTT] ParcelableRttResults parcel code fix
    Fix VerifyCredentialResponse parcelling code
    Refactor MediaPlayerBase's notify
    libmediaplayerservice:Fix deadlock on gapless start failure
    Revert "libmediaplayerservice: fix deadlock on gapless start failure"
    Prevent MediaPlayerService::Client's use-after-free
    Check NAL size before looking inside
    M3UParser: detect variant streams without EXT-X-STREAM-INF
    AACExtractor: check bounds during seek
    Project name: android_packages_apps_UnifiedEmail
    Disallow attaching files from our own EmailAttachmentProvider.
    Project name: android_packages_apps_Email
    PrivacyGuard: skip icon lookup for OP_NONE
    PrivacyGuard: add a couple more missing icons
    Privacy Guard: Add icon for VPN permission
    AppOps: Add missing copyrights to icons
    AppOps: Add missing icons for alarm, bluetooth, stats, toast
    AppOpsDetails: Display all missing ops
    Project name: android_packages_apps_DeskClock
    DeskClock: Minor string fix
    DeskClock: Refactor a few strings
    Dialer: comply with EU's GDPR
    Parts: Fix notification light app hint
    Revert "Parts: add genuine validator"
    hal: Use call state to ensure voice call start
    mm-video-v4l2: vdec: Disallow changing buffer modes/counts on allocated ports
    mm-video-v4l2: venc: Disallow changing buffer count/size on allocated port
    mm-video-v4l2: Protect buffer access and increase input buffer size
    Decoder: Set prev slice type for I slice.
    Decoder: Fixed reset values in parse sps.
    Decoder: Adding Error Check for Output Buffer Size in Shared Display Mode.
    Decoder: Fixed memory overflow in shared display mode.
    MPEG-4 AAC Decoder: check against invalid height info
    Update webviews to Chromium 65.0.3325.144
    Fixing Underflow of ps_dec->u2_num_mbs_left
    Correcting Buffer Allocation for Shared Display
    Fix output buffer size check
    Check limits for log2_max_pic_order_cnt_lsb_minus4 in sps
    Add bounds checking for transparency lookup
    Project name: android_frameworks_native
    Handle glGetString returning NULL
    Triple the available egl function pointers available to a process for certain Nvidia devices
    Project name: android_system_security
    key_store:Using euid instead of uid when upgrade wifi blobs
    keystore: add upgradeKeyBlob call into keystore exportKey.
    Fix issue: upgradeKeyBlob call always return PERMISSION_DENIED.
    Project name: android_system_bt
    AVRCP: Initialize buffer for attribute values to be written to
    SDP: Check p_req_end before reading from p_req
    Truncate new line characters when adding string to config
    AVRCP: Check the number of text value attributes requested
    AVRCP: Check number of text attribute values in response
    AVRCP: Check number of text attributes in response
    bt: Fix 32k sbc_codec.sampling_rate
    BNEP: Check received frame type
    Remove memory reference to invalid mem in error log
    SDP: Include the offset in sdp_disc_server_rsp
    SDP: Pass the bounds to process_service_*_rsp
    Fix unexpected behavior in reading BNEP packets
    PAN: Fix Use-after-free in bta_pan_data_buf_ind_cback
    AVRCP: Check the number of text attributes requested
    Allocate/free the SDP connection timers only during stack startup/shutdown
    Removed alarm callback execution statistics
    Fix unexpected behavior in SDP
    CMSettingsProvider: Fix default setting for DEV_FORCE_SHOW_NAVBAR
    cm: extract_utils: Fix rootfs targets after 72765e4cc950d90abb730bc62e3f5f9eeba5aa4e
    Fix Android "Work Profiles" also known as AfW 'Android for Work'
    build: dt_image: support prebuilt DT images
    write_makefiles: fix paths in BUILD_PREBUILT with destination
    repopick: Allow to pick changes by URL
    repopick: Actually print the patchset number
    repopick: Ignore the trailing slash in change numbers
    repopick: Try to keep the changes sorted
    Revert "LOSCoins"
    LOSCoins
    apn: Add APN for spusu MVNO
    Download: https://www.androidfilehost.com/?fid=818070582850510574
    MD5: 58f8f07847ab1a21d677696666e03377
    nickelodeon likes this.
  7. TugaPower
    Jelly Bean Jun 16, 2018
    TugaPower , Jun 16, 2018 :
    Build 16/06/2018 #OPO #N
    TugaPower ROM G+
    #TugaPower N 60.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N59.0 :
    Jun Security Patch
    Updated Lawnchair
    SystemUI: Toggle USB tethering only when USB is connected
    Rework thumbnail cleanup
    ResStringPool: Fix security vulnerability
    [BACKPORT] SystemUI: Fix alignment glitch with brightness mirror
    ConnectivityService: move reportNetworkConnectivity to handler
    ConnectivityService: safer locking
    Revert "Prevent deadlock when using always-on legacy VPNs"
    Drop LE CoC fragments when frame size is too big
    Fix OOB read in process_l2cap_cmd
    [Backport] Handle bad packet length in gatts_process_read_req
    Add bounds check for BNEP_Write
    PAN: Always allocate in bta_pan_data_buf_ind_cback
    Fix unexpected behavior in bta_dm_sdp_result
    Project name: android_packages_providers_UserDictionaryProvider
    Check caller before accessing database
    Project name: android_packages_providers_MediaProvider
    Fix deadlock in MediaProvider
    Project name: android_packages_apps_Nfc
    NFC: Clean duplicated and unknown permissions
    InCallUI: Refactor primary call info card
    Fix incorrect number formatting in call stats details.
    Remove redundant layout item.
    repopick: Update SSH queries result to match HTTP queries
    EffectsFactory: add debug and trace wrappers for NXP LifeVibes
    Add check preventing div0 issue
    Sanitize effect descriptors for AudioPolicyService binder calls.
    Init gain config to prevent uninit leak.
    Fixed invalid pdu issue
    Telephony: Fix "Keep preferred SMS Sim"
    sonivox: fix hang caused by bad meta-event
    Adding Check For Number of Skip MBs
    Add limits check for depth hierarchy sps parameters
    Return error for invalid sps sub layers parameters
    Return error for invalid reorder parameter
    Encoder: Return error for odd resolution
    Decoder: Modify setting short term reference field flag
    libvpx: cherry pick fix to OOB of mv_cost index.
    manifest: Remove external/libvorbis
    manifest: Track own external/libvorbis
    Download: https://www.androidfilehost.com/?fid=746163614322272972
    MD5: c64e8f73446c87baed43316285375b86
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
  8. TugaPower
    Jelly Bean Jul 30, 2018
    TugaPower , Jul 30, 2018 :
    Build 29/07/2018 #OPO #N
    TugaPower ROM G+
    #TugaPower N 61.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N61.0 :
    Lawnchair updated to 1.2.0.1884
    Updated Magisk to 16.8-546c7ce
    Project name: android_build
    July Security patch
    Remove unnecessary casts in postUpdateSlider()
    Fix the "Alarm volume" icon is displayed incorrectly
    PhoneWindowManager: Allow torch and track skip during ambient display
    Fix wrong peek height of the notification panel
    Fix an error with hardware keyboard shortcuts
    Tuner: Move clock seconds option to status bar settings
    Truncate newline and tab characters in BluetoothDevice name
    keyguard: Handle left icon visibility properly with wifi only devices
    manifest: Track android-8.1.0_r36 for system/ca-certificates
    Track own external/bouncycastle
    Return error for invalid st/lt sps parameters
    Project name: android_external_bouncycastle
    Fix probable prime confidence calculations.
    InCallUI: Keep button states in sync with call properties
    Project name: android_packages_apps_Bluetooth
    Make sure server response doesn't exceed maximum allowable length
    CMParts: Move clock seconds option to status bar settings
    Project name: android_packages_apps_PhoneCommon
    Adjust SpecialCharInternalLayoutStyle to match other buttons
    Project name: android_packages_services_Telephony
    Telephony: Get rid of build warnings
    Speed up id3v2 unsynchronization
    Increment when attempting to read protected Parcel Data
    Disallow reading object data from Parcels with non-object reads
    Don't pad before calling writeInPlace().
    Revert "config: Remove 7z lib7z unrar unzip zip makefile entries"
    libgralloc: Fix adding offset to the mapped base address
    Merge commit 'f9e3022c474619c69a46ae7dbe11b5b531dbad57' into am-0d58d39a-0539-474e-b9c8-36cc976d15e8
    init.rc: move load_system_props to beginning of 'on fs'
    SMP: Validate remote elliptic curve points
    Prevent stack overflow in btif_storage
    Check number of attributes before writing to a buffer
    AVRC: Add bound check for AVRC_EVT_APP_SETTING_CHANGE
    Add bounds check to l2cble_process_sig_cmd L2CAP_CMD_DISC_REQ
    Fix unexpected behavior in smp_sm_event
    Download: https://www.androidfilehost.com/?fid=5862345805528061361
    MD5: d648c78e97cfcca8ab8d94e61dde6e47
  9. CaBooSe
    Gingerbread Aug 6, 2018
    CaBooSe , Aug 6, 2018 :
    how can i use my otg-drive in your twrp ... its not recognized anymore ... tks in advance
  10. DrJMun
    KitKat Aug 19, 2018
    DrJMun , Aug 19, 2018 :
    You need to mount your otg in twrp. Once it's mounted twrp should be able to see the files in it.
  11. SensouSenseiKradXR
    Donut Aug 30, 2018
    SensouSenseiKradXR , Aug 30, 2018 :
    With TugaPower N61, I cannot record using the back camera. It says "Cannot start media recorder". The front camera, however, works no problem. This was not an issue with N60.
  12. Cobrin
    Ice Cream Sandwich Sep 5, 2018
    Cobrin , Sep 5, 2018 :
    works fine here, takes pictures when touching the screen whilst recording too. Try and clear the camera cache and data used for a test, back up your pics/vids before just in case.
    wilsmits likes this.
  13. SensouSenseiKradXR
    Donut Sep 5, 2018
    SensouSenseiKradXR , Sep 5, 2018 :
    Damn it, I was so focused on something else that I totally forgot to try it... Clearing data and cache from the Camera App works now! Thanks!
    TugaPower and wilsmits like this.
  14. wilsmits
    Jelly Bean Sep 7, 2018
    TugaPower likes this.
  15. TugaPower
    Jelly Bean Sep 23, 2018
    TugaPower , Sep 23, 2018 :
    Build 17/09/2018 #OPO #N
    TugaPower ROM G+
    #TugaPower N 62.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N62.0 :
    Magisk and Lawchair updated
    August Security Patch
    Project name: android_external_curl
    Disable unused protocols.
    Updated webviews to Chromium 67.0.3396.87
    Project name: android_external_e2fsprogs
    Ignore quotes in safe_print().
    Bug fix for flush without valid frames
    Project name: android_packages_apps_PackageInstaller
    RESTRICT AUTOMERGE: Always use safe labels
    Merge translations of Bluetooth confirmation text
    DO NOT MERGE Fix unexpected behavior in Bluetooth pairing
    Project name: android_packages_apps_LineageCustomizer
    Correct package name
    LineageCustomizer: Bring inline with fugu's 14.1 version
    Project name: android_packages_apps_Messaging
    Messaging ignores file URIs shared via intent
    Revert "Messaging: Request external storage permission before handling shared files"
    Filter Attachment file name of forward slashes for .eml attachments.
    Fix potential NPE in EmergencyCallbackModeExitDialog.
    DO NOT MERGE Revise security requirements for TelephonyManager#endCall.
    Fix possible out of bounds read
    Make safe label more safe
    ResStringPool: Prevenet boot loop from se fix
    Fix DynamicRefTable::load security bug
    manifest: Track our own curl
    init: add install_keyring for TWRP FBE decrypt
    init.rc: Lock down access to /proc/net/fib_trie
    Merge commit '635193ab36302e5f65e99c7df2f256cfd37068c7' into am-b7f1a67b-2024-4274-aa7d-e88e8cceb407
    Address const issues in preparation for libcxx rebase.
    GATT: Use correct logging macro replacement
    RESTRICT AUTOMERGE: Fixes two bluetooth bugs causing remote overreads (1/2)
    Add PDU size checks in process_service_search_attr_rsp
    GATT: Handle too short Error Response PDU
    Add checks whether the AVDTP element data length is valid
    BNEP: Fix OOB access in bnep_data_ind
    Decrease length after reading from array in process_service_attr_req
    DO NOT MERGE SMP: Check p_cb->role in smp_br_state_machine_event
    Download: https://tugapower.net/TP/OP1/NOUGAT/TugaPowerN62.zip
    MD5: 58e96c2c203c1097fe15d9a38c5689b3
    Cobrin likes this.
  16. Cobrin
    Ice Cream Sandwich Sep 25, 2018
    Cobrin , Sep 25, 2018 :
    Slick update Tugapower as we've learned to expect ;), no hitches along the way, my that launcher is different.
  17. Cobrin
    Ice Cream Sandwich Sep 28, 2018
    Cobrin , Sep 28, 2018 :
    Thank you Tuga I've enjoyed your roms as you updated them and had a brilliant ride rock solid stable and everything worked without a hiccup in a quick fashion, they've all been great. You're a credit to the phone and community.
    I couldn't help myself and installed Android P (your new ROM for this phone). I feel my time with this phone (1+1) is going to be reduced as I have cut my sim card to fit into a gifted phone (Mi Mix) 6Gb ram, 256Gb storage. It were just too tempting with big screen and storage. I wish you the best and will hang in there as long as I can.
  18. wilsmits
    Jelly Bean Sep 28, 2018
    wilsmits , Sep 28, 2018 :
    Congrats and good luck with your new toy. Nice phone bytheway
    Cobrin likes this.
  19. TugaPower
    Jelly Bean Jan 12, 2019
    TugaPower , Jan 12, 2019 :
    Build 12/01/2019 #OPO #N
    TugaPower ROM G+
    #TugaPower N 65.0 LineageOS #laos #OnePlus #Android 7.1.2r36 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N65.0 :
    December Security Patch
    Updated Lawchair to Alpha 783
    Updated Magisk Cannary Release to latest version
    ( use https://bit.ly/2N8UVlq in custom magisk channel )
    Project name: android_external_v8
    Remove unrecognized compiler flag
    Revert "Backport: Fix Object.entries/values with changing elements"
    CTS error while media dump()
    Recover shady content:// paths.
    Pass userId through to singleton ContentProviders
    This android version is the last update, no more updates to Nougat
    It was a long run...
    Download: https://tugapower.net/TP/OP1/NOUGAT/TugaPowerN65.zip
    MD5: 272a0ea5dd43041d0b45a11f1470c8bb
  20. Cobrin
    Ice Cream Sandwich Apr 14, 2019
    Cobrin , Apr 14, 2019 :
    I'm back Tuga. I had a terrible run there for some time so went back to Oreo and that weren't a great run, so have come back to Nougat to start again and hopefully have reliability and rock solid run like I always had. Granted it's not the ROM but more so what I do and add to it but its a setup that never really changes and always gave a great run.
    Happy 2019 lets see this year out on N65 ;)
