58
ROM [ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. lokesh3440
    Honeycomb Sep 20, 2016
    lokesh3440 , Sep 20, 2016 :
    That's because ROM build you get from OEM is final stable build targeted for user. You can see that by going into /system/build.prop. It is userDebug in this ROM as this is specifically made for testing purposes and signed with userDebug keys during compilation.
    Prinze Martin likes this.
  2. adi_daga
    Gingerbread Sep 20, 2016
    adi_daga , Sep 20, 2016 :
    1)YouTube AdAway (xposed required)
    2)AdAway (3rd party apk,not available on play store)
  3. Tarfex
    Ice Cream Sandwich Sep 20, 2016
  4. TugaPower
    Jelly Bean Sep 20, 2016
    TugaPower , Sep 20, 2016 :
    Build 20/09/2016
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 0.4 RC CM14 #OnePlus #Android 7.0
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f9...areCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/onep...power-t3398366
    Relative to gapps, testing open gapps 7.0 nano package, working without issues, if you use exchange service email you need to use micro package.
    http://opengapps.org/?api=7.0&variant=nano
    http://opengapps.org/?api=7.0&variant=micro
    ROM have OTA updates already implemented, so next update you will be receving notification update, configure the CM Updater ( TugaPower ROM Updates) check sheduler.
    Kernel its permissive
    Gello removed and replaced by latest TugaBrowser beta v53.02785.2477845 with web refiner ( blocks ads and protect privacy)
    Viper4Android included and removed audiofx
    Multi ROM support out of the box
    Kcal control included ( use Color control included to tune RGB )
    Powered by SuperSU 2.78 SR1 by @Chainfire
    Full support for suhide out of the box, just flash latest suhide after rom flash, nothing more to do, this will survive next OTAs but the list is reseted each OTA, will see with chainfire a temp solution for this.
    What works:
    Calls
    Wifi
    Camera
    Data
    Basically it works all needed.
    What does not works:
    Settings/Status bar options its not working very good
    Change log:
    Project name: android_packages_apps_Settings
    Settings: Forward port long-press-back to kill app
    settings: Add lockscreen visualizer toggle
    settings: Add advanced reboot switch
    Settings: Add option to scramble pin layout when unlocking
    Settings : Add lockscreen shortcuts
    Re-Implementation of Protected App Settings
    settings: Apply constraints for lights preferences
    apn: Update the add actionbar icon
    Use correct icon for sim card
    Revert "Settings: Display 14 digit IMEI(Ignore Check Digit)"
    Fix AIOOBE with root access disabled.
    Settings: Show only one tab on PrivacyGuard direct access
    Settings: Root appops access in developer settings
    Settings: Apps started on boot shortcut in memory settings
    Fix NPE when starting fingerprint enrollment.
    storage: Do not allow eject for volumes on non-removable disks
    Project name: cm_platform_sdk
    cmsdk: Add constraints and behaviors for our preferences
    Project name: android_frameworks_opt_telephony
    RIL: Make RIL subclassable
    RIL: Squash support for mQANElements
    RIL: Squash support for old RIL
    Project name: android_frameworks_av
    stagefright: Disable spammy debugging
    Project name: android_frameworks_base
    core: Remove QCOM BoostFramework and ActivityTrigger
    SystemUI: use new visualizer from Eleven
    Increase brightness faster if ambient light is brightening quickly.
    audio: Don't play sound effects if stream is muted
    GlobalActions: Set the initial status of airplane mode toggle
    SystemUI: Fix NPE when setting network name
    framework: move device key handler logic, fix gesture camera launch
    SystemUI: Lockscreen shortcut customization
    SystemUI: Use AndroidManifest_cm.xml
    lights: Really make sure the lights are out
    SystemUI: Enable TunerActivity
    Revert "Telephony: Update cdma_chocies and world_phone config values."
    Allow adjusting screen density to smaller sizes.
    storage: Do not notify for volumes on non-removable disks
    Fix mounting of non-FAT formatted SD cards
    default.xml: Add arm-eabi-4.8 toolchains
    Project name: android_build
    Revert "envsetup: Always look up JAVA_HOME path"
    Revert "main: Use date -d on OSX"
    kernel: default to gcc 4.9; auto-set prefix based on TARGET_ARCH
    Project name: android_system_core
    init: Fire a trigger when a class is started/stopped
    Project name: android_system_sepolicy
    Allow appdomain to read/write files in sdcard_posix
    sepolicy: allow vold to mount ext4 sdcard
    Project name: android_system_vold
    Revert "vold: mount non-primary fuse locations with the multiuser and full write flags"
    Project name: android_packages_apps_CMParts
    cmparts: Add protected apps linkage
    cmparts: Cleanup
    cmparts: livedisplay: Fix missing color profile strings
    Project name: android_packages_apps_CMUpdater
    Update manifest to give permission automatic
    Update Service to remove deltas
    Update Config to TugaPower ROM
    Project name: android_packages_providers_MediaProvider
    Download link:
    MeoCloud: https://meocloud.pt/link/e217ffac-f834-4e08-adf8-78015fdffba3/TugaPowerN04RC.zip
    Gdrive: https://drive.google.com/open?id=0ByxlOYAKcbyTQi1oQmFqd0dqdzg
    Mega: https://mega.nz/#!9EMRGB7R!pCij-mQD1MBWFNbXNu7iDOSOR9_ef71_pHnwyyw92N8
    Android File Host: Not available, under maintenance.
    MD5: da0efc34ce1732c8ece0198342fb7893
    Please dont mirror for now the roms zips, thanks
    Special thanks to @amardeep434 for initial work on making booting and also big thanks for @updateing
    Sources :
    Rom:- http://github.com/CyanogenMod
    Device:- http://gitlab.com/amardeep434/ndevice
    Kernel:- http://gitlab.com/amardeep434/nkernel
    Jac_Q, rajaspardeshi, jstepa and 5 others like this.
  5. Tarfex
    Ice Cream Sandwich Sep 21, 2016
  6. Azezo89
    Gingerbread Sep 21, 2016
    Azezo89 , Sep 21, 2016 :
    @TugaPower: very minor bug. I can't change the battery icon to text. I chose the text option but still it is in icon mode.
    jstepa likes this.
  7. jstepa
    KitKat Sep 21, 2016
    jstepa , Sep 21, 2016 :
    Same for me and kill app back button does not work and reverts back to off.
  8. jstepa
    KitKat Sep 21, 2016
    This could have been just my problem, but when dirty flashed I lost all text messages, fortunately I had backup of those
  9. theshinybeast
    Marshmallow Sep 21, 2016
    theshinybeast , Sep 21, 2016 :
    Yes, just you maybe, mine survived a dirty flash.
    Although my substratum theme didn't. No biggy new one in place.
    ziepicwaffle and jstepa like this.
  10. rajaspardeshi
    rajaspardeshi , Sep 21, 2016 :
    since Xposed isn't available for N yet, I went with AdAway, but it doesn't help with YouTube ads at all
  11. rajaspardeshi
    Notification LED settings broken, custom settings cant be saved. Also, settings app crashes when searchinglock screen shortcuts and opening the same.
  12. Prinze Martin
    Prinze Martin , Sep 21, 2016 :
    They're working fine here @ N 0.4 RC now
    Kill -app using back button doesn't work though
  13. adi_daga
    adi_daga , Sep 21, 2016 :
    I totally forgot ..xposed isn't out for nougat yet..my bad :p
    rajaspardeshi likes this.
  14. dhana101
    Cupcake Sep 21, 2016
    dhana101 , Sep 21, 2016 :
    After flashing the rom while setuping the device , do we required internet connection? since because, im unable to setup the device.:(
  15. se7enlyn
    se7enlyn , Sep 21, 2016 :
    You need an internet connection to install apps. Unless you use tibu.
    ziepicwaffle likes this.
  16. butaixyz8016
    Honeycomb Sep 22, 2016
  17. Prinze Martin
    Ice Cream Sandwich Sep 22, 2016
    Prinze Martin , Sep 22, 2016 :
    After flashing rom, delete the setupwizard.apk (in the priv app folder in system) using file manager in TWRP :)
    butaixyz8016 likes this.
  18. prozaican
    Froyo Sep 22, 2016
    prozaican , Sep 22, 2016 :
    Found a bug...
    Go to Privacy -> Privacy Guard -> (Click on Show built-in apps) -> Advanced and click on Google Play Services. It crashes ...
  19. jstepa
    KitKat Sep 22, 2016
    jstepa , Sep 22, 2016 :
    Not for me, using Banks GApps...
  20. prozaican
    Froyo Sep 22, 2016
    switched to banks ... crash again... ;)
