48
[ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. TugaPower
    Jelly Bean Jan 21, 2017
    TugaPower , Jan 21, 2017 :
    Build 2017/01/21 #OPO
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 15.1 LineageOS #laos #OnePlus #Android 7.1.1 #OMS7 #Substratum #OPO
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise Deuteronomy 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Kcal Support
    Gello removed and replaced by latest TugaBrowser beta v54.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    kernel 3.4.113
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to SuHide ( fixed iGoogle November security patch, install suhide to pass safety net )
    Full support to Substratum OMS7 :)
    Kernel support to NetHunter aka Kali its present, you need to flash the generic zip and you are good to go ( https://goo.gl/UsFuPg )
    Powered by SuperSU 2.79 Stable
    What does not works:
    Let me know to add here :)
    Change log:
    N15.1
    bacon: re-enable blur effect support
    Project name: android_system_sepolicy
    domain: Create a dummy domain for qc's rmt and let it access /dev/mem
    Project name: android_hardware_intel_img_psb_video
    Encode: correctly handle VAConfig attributes on medfield/CTP
    Fix video encoding on clovertrail
    Add clovertrail support (based on the tree at 686e11709b57bc57ee94c3166f187fec959fd43b)
    Cleanup pvr_drv_video makefile for clovertrail support
    Project name: android_hardware_intel_common_omx-components
    omx-component: fix video corruption
    Project name: android_hardware_qcom_display
    Fix duplicate copy file rules
    Project name: android_hardware_qcom_audio
    msm8974: Remove deprecated FM stuff.
    Project name: android_hardware_qcom_fm
    Use BOARD_HAVE_QCOM_FM flag
    Revert "fm: do not build for BCM FM devices"
    Project name: android_vendor_cm
    apns: Add Freedompop foggmobile APN
    bootanimation: get all the parts
    build: Append -dtb to kernel image name if TARGET_KERNEL_APPEND_DTB is set
    cm: bootanimation: Improve boot animation
    extract_utils: Detect output existence before moving it for backup
    cm: bootanimation: Clear intermediaries
    vendor: lineage boot animation
    Sepolicy: Add perm for find cmstatusbar
    cm: config: Remove obsolete props
    Project name: cm_platform_sdk
    cmsdk: Fix @deprecated annotation mismatch warnings
    Project name: android_frameworks_base
    windowmanager: Add support for blur effects
    PlatLogo: Show lineage platlogo when tapping on LineageOS version
    SystemUI: add Notification volume stream title
    Readded Platinum Alarm sound as I miss it in newer builds.
    AudioService: Launch default music player on headset connect
    NetworkManagement : Add ability to restrict app data/wifi usage
    sensors: Allow opting out of default batch size
    Switch to Lineage chromium-webview fork
    Project name: android_build
    build sign_target_files_apks.py: clean tmp on exit
    Project name: android_packages_apps_Settings
    Revert "settings: Remove lock screen blur stuff breaking build"
    Settings: point to lineageos updater
    Settings: Launch default music player on headset connect
    Settings: Add volume link notification switch
    Move notif volume pref on top of increasing ring pref
    Settings: per-app cellular data and wifi restrictions
    Settings: DeviceInfo: Clean up the PlatLogo checks
    Project name: android_packages_apps_CMParts
    Update contributors cloud db
    Use valid network resources in getNetworkModeString()
    CMParts: profiles: Remove old PagerTabStrip hack
    ButtonBacklight: Preview timeout once user stops dragging
    CMParts: Update button backlight brightness in real time
    Download links:
    Android File Host: https://www.androidfilehost.com/?fid=745425885120702144
    MD5: 072467654df1b98336e87d79d851060b
    Please dont mirror for now the roms zips, thanks
    pikota likes this.
  2. TugaPower
    Em relação ao SYNC do TugaBrowser nao funcionar, a Google decidiu bloquear todo o acesso a API do sync, desta forma apenas a o Chrome oficial consegue aceder a esse conteudo, infelizmente se a Google nao criar uma maneira de dar acesso ou remover esse bloqueio, é o fim para todos os Browsers que fazem isto.
    Quem tinha o SYNC a funcionar desde que nao limpe os dados continuara a funcionar pois o token esta valido, mas clean install e o sync nunca mais funciona. A ver vamos o desenvolvimento desde assunto.
  3. pikota
    Marshmallow Jan 22, 2017
    pikota , Jan 22, 2017 :
    Não é por isso que deixarei de usar o teu browser. ;)
    ivomendes likes this.
  4. AnuiBay
    Ice Cream Sandwich Jan 22, 2017
    AnuiBay , Jan 22, 2017 :
    No Maps não consigo meter a vista de satélite.... alguém pode confirmar se é só com o meu???? fica ali com o menu laterla preso.... já nas anteriores fazia isto.... mas como não uso muito nem tenho ligado.
  5. pkas
    Honeycomb Jan 22, 2017
    pkas , Jan 22, 2017 :
    testei agora, nenhum problema em mudar
  6. wachagga
    Eclair Jan 22, 2017
    wachagga , Jan 22, 2017 :
    Estou na versão 15 ainda mas reparei num bug. Não sei se é apenas no meu meu mas estava a ver um episódio usando o MXplayer e reparei que se tivesse o Tlm rodado num sentido tinha som (entrada usb para a direita) e ao contrário não tinha som. Voltei a testar num jogo e reparei que acontece o mesmo. Se rodar para um lado há som para o outro não.
    Isto não é nada de mais mas foi algo que reparei. Vou actualizar para a 16. Caso veja mais alguma coisa aviso.
    Mais uma vez parabéns pelo excelente trabalho.
  7. sometheway
    Ice Cream Sandwich Jan 23, 2017
  8. AnuiBay
  9. pikota
    Marshmallow Jan 23, 2017
    AnuiBay likes this.
  10. marcoprofeta
    Froyo Jan 23, 2017
    Peles likes this.
  11. pikota
    AnuiBay likes this.
  12. AnuiBay
  13. lemor
    Jelly Bean Jan 23, 2017
  14. pgomes2000
    Gingerbread Jan 23, 2017
    pgomes2000 , Jan 23, 2017 :
    Boas pessoal,
    Alguém sabe como fazer backup dos icons e widgets que estão nos home screens?
    É que dava muito jeito para quando se faz uma clean install :)
    E se não for pedir muito, todas as configurações de toques etc.... :D
    Estou a usar como home launcher a Trebuchet
  15. pikota
    Marshmallow Jan 24, 2017
    pikota , Jan 24, 2017 :
    Na última versão, sempre que faço uma chamada as opções desaparecem, acontece com vocês?
  16. espalha704
    Ice Cream Sandwich Jan 24, 2017
  17. pikota
    Até ver está a funcionar bem, tive um pequeno stress com as chamadas mas após reboot ficou tudo ok.
    espalha704 likes this.
  18. espalha704
    espalha704 , Jan 24, 2017 :
    E estás com a qual? 16 ou 17?
    Como assim stress com as chamadas?
  19. pikota
    A última versão.
  20. rf1967
    Honeycomb Jan 24, 2017
