48
[ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. luiscarneirorm
    Gingerbread Feb 18, 2017
  2. marcoprofeta
    Froyo Feb 18, 2017
    marcoprofeta , Feb 18, 2017 :
    Sim é essa que tenho, tenho que flashar cada vez que actualizo?
  3. pikota
    Marshmallow Feb 19, 2017
    pikota , Feb 19, 2017 :
    Talvez, eu a minha flashei estes dias e funciona. :)
    marcoprofeta likes this.
  4. TugaPower
    Jelly Bean Feb 19, 2017
    TugaPower , Feb 19, 2017 :
    Build 2017/02/19 #OPO
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 22.0 LineageOS #laos #OnePlus #Android 7.1.1 #OMS7 #Substratum #OPO
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Here you have a build by me of TWRP: http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise Deuteronomy 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser beta v54.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    kernel 3.4.113
    Kernel is permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 :)
    Powered by Magisk root and Magisk Manager
    What does not works:
    Let me know to add here :)
    Change log:
    Project name: android_packages_apps_Magisk
    Update Magisk Manager to version 4.2
    Update Deuterenomy Magisk Module to v3
    Project name: android_device_oneplus_bacon
    bacon: fix rmt_storage denial after cafrebase
    Project name: android_device_oppo_common
    oppo-common: Replace variable for setup wizard complete
    Project name: android_system_bt
    Revert "Bluetooth-Wipower: Enable WiPower feature."
    Project name: android_system_vold
    vold: Update path to cryptfs_hw
    Project name: android_hardware_qcom_bootctrl
    bootctl: use TARGET_RECOVERY_UPDATER_LIBS macro for linking
    Project name: android_hardware_qcom_media
    media: add missing 8952 symlink
    Project name: android_hardware_qcom_fm
    jni: Confine the firmware-load skipping to the actual loading
    Project name: android_hardware_libhardware
    hardware: power: Remove POWER_HINT_AUDIO
    Revert "power: Add support for camera preview in powerHAL"
    Project name: android_hardware_ril
    ril: Setting ril to v10 or v11 serves no purpose
    Project name: android_vendor_qcom_opensource_cryptfs_hw
    cryptfs_hw: Remove keymaster partition check
    Cleanup temporarily stored passwords
    cryptfs_hw: update the listener property with keymaster property
    Wait for QSEECom listeners before calling KMS APIs
    cryptfs_hw: Tie HW FDE keys with keymaster
    cryptfs_hw: Update module as per vold project
    cryptfs_hw: add string.h
    cryptfs_hw: Update APIs to take old password
    cryptfs_hw: Add support for wipe_key routine
    Adding support for eMMC based ICE
    Adding support of Inline Crypto Engine (ICE)
    qcom/common: Added O_NOFOLLOW to avoid follow the symlink
    Port cryptfs_hw library to 64bit platform
    Wrong function pointer usage
    Place library in vendor folder on device
    vold: HW based device encryption
    Project name: proprietary_vendor_qcom_binaries
    Revert "bluetooth: Add aptX & aptXHD to comfirmed platforms"
    Project name: android_vendor_cm
    CyanogenSetupWizard > LineageSetupWizard
    cm: config: dont build CMWallpapers
    Project name: cm_platform_sdk
    cmsdk: Deprecate CM_SETUP_WIZARD_COMPLETED
    RemotePreferenceManager: Fix receiver registration issues.
    Project name: android_device_qcom_sepolicy
    Bluetooth: Remove stray characters
    Project name: android_device_qcom_common
    Revert "extractors: Add aptX & aptXHD to confirmed platforms"
    cryptfs_hw: Move to vendor/qcom/opensource/cryptfs_hw
    Project name: android_frameworks_native
    sf: fixes for HWC2
    Project name: android_frameworks_base
    SystemUI: Network Traffic [1/3]
    Re-introduce custom charging on/off sounds
    Clean up CAF translations
    Show infinity for large notification counts
    Don't reposition the clock when pulling down the notification bar
    SystemUI: Use mContext.getDrawable for battery icon
    cm: Sync the new cryptfs_hw repo
    cm.xml: remove CMWallpapers repo
    Project name: android_build
    dumpvar: Dump RECOVERY_VARIANT if not empty
    Add dumpvar for WITH_SU
    edify: Fix AssertSomeBaseband
    Revert "build_image: Unbreak verity/FEC generation"
    core: Output full OTA package path to terminal
    Project name: android_external_e2fsprogs
    e2fsck: Add e2fsck_static
    Project name: android_external_ntfs-3g
    Loaded the fuse kernel module with no environment
    Project name: android_packages_providers_ContactsProvider
    dbhelper: fix schema disaster from pre-cafrebase repo
    Project name: android_packages_services_Telephony
    Telephony: Fix qtistrings
    Project name: android_packages_apps_Contacts
    Contacts: Fix quotes
    Improve CAF strings
    Project name: android_packages_apps_Snap
    Snap: CaptureModule: fix preview being invisible on first start
    CaptureModule: Fix UI.
    Snap: CaptureModule: re-apply flash setting when disabling manual iso
    Snap: CaptureModule: check if ZSL is supported before using it
    Snap: CaptureModule: enable noise reduction
    Snap: CaptureModule: enable redeye reduction
    Snap: CaptureModule: enable and fix manual iso control
    Snap: CaptureUI: remove camera2 option
    Snap: detect and use Camera2 if available
    Project name: android_packages_apps_Settings
    Track RemotePreferenceManager API changes.
    wifi: Allow configuration of country code for wifi
    Settings: Add status bar tap to sleep pref to gestures
    Project name: android_packages_apps_CMParts
    CMParts: Replace variable for setup wizard complete
    CMParts: Add strings for sRGB
    Move status bar settings back to personal category.
    CMParts: strings: Fix indentation
    CMParts: gestures: Specify a qualified user for update broadcast
    Project name: android_packages_apps_Dialer
    Improve CAF strings
    Project name: android_packages_apps_ContactsCommon
    ContactsCommon: Fix derp
    cmsdk: Add Network Traffic [2/3]
    CMParts: Network Traffic [3/3]
    Download links:
    Android File Host: https://www.androidfilehost.com/?fid=817550096634747573
    MD5: 2ac961823d5c67cd525fc1d054bb4268
    Please dont mirror for now the roms zips, thanks
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
    lemor, pikota, mordep and 2 others like this.
  5. manholas
    Lollipop Feb 19, 2017
    manholas , Feb 19, 2017 :
    Uma nova versão da N22. É nova é traz alterações. Os gestos é uma delas. Descarreguem e flashem por cima. Está por ota, veham nas definições/acerca do telefone/tugapower actual.
    Dá-lhes com força TUGA
    Edit: cheguei tarde, o Tuga chegou primeiro
    scp41 and TugaPower like this.
  6. TugaPower
    Tambem tem uma nova setting, na Status bar ( Network traffic ), e nao so :D
  7. TugaPower
    TugaPower ROM G+
    #TugaPower N 23.0 LineageOS #laos #OnePlus #Android 7.1.1 #OMS7 #Substratum
    Call Record
    Multi-ROM Support
    kernel 3.4.113
    Change log:
    N23.0
    Fix issue phone wont boot with clean install
    Changed boot animation to be more clear
    opo: Hide sRGB toggle in developer options
    Project name: android_packages_apps_CellBroadcastReceiver
    CellBroadcastReceiver: Fix strings
    N22.0
    sf: fixes for HWC2
    Improve CAF strings
    Improve CAF strings
    Download links:
    Android File Host: https://www.androidfilehost.com/?fid=745425885120709426
    MD5: cf66aba6a100ffb46e33c9d24f288f51
    Sources :
    lemor, pikota, mordep and 3 others like this.
  8. pikota
    Marshmallow Feb 20, 2017
  9. pkas
    Honeycomb Feb 20, 2017
    pkas , Feb 20, 2017 :
    No meu ficou.. uns bons 'ai a m3rd@.. queres ver??' :D:D:D
    Depois ficou normal e funciona e tudo ;)
    pikota likes this.
  10. Jorge Aguiar
    Froyo Feb 20, 2017
  11. Gauthamarun
    Ice Cream Sandwich Feb 20, 2017
    Gauthamarun , Feb 20, 2017 :
    Strange, when I need to set up the phone, it won't connect to the wifi. I used mobile data to set up and when i hopped over to Wifi settings, it won't turn on. I keep clicking it but it just turns on for a second and turns back off.
  12. lemor
    Jelly Bean Feb 21, 2017
    lemor , Feb 21, 2017 :
    Pessoal, como se pode ativar a opção de bloqueio de chamadas de números anónimos? Já não aparece essa opção no Nougat?
  13. pikota
    Marshmallow Feb 21, 2017
    pikota , Feb 21, 2017 :
    Sim aparece, faz assim:
    Clicas no ícone do telefone - 3 pontinhos - definições - Bloqueio de chamadas. :D
  14. mso07runner
    Ice Cream Sandwich Feb 21, 2017
    mso07runner , Feb 21, 2017 :
    Que tal N23?
  15. lemor
    Números anónimos? Olha que não.
  16. Steeplechase
    Ice Cream Sandwich Feb 22, 2017
    Steeplechase , Feb 22, 2017 :
    Acho que não é impressão minha mas esta 23 está muito mamona assassina. Parece-me que a culpa é do "Google services". :O
  17. pikota
    Marshmallow Feb 22, 2017
    pikota , Feb 22, 2017 :
    Até agora tudo bem, sem qualquer problema.
    Tens a certeza que estás no local que referi?
    Coloca aqui um screen shot.
  18. lemor
    Jelly Bean Feb 22, 2017
    lemor , Feb 22, 2017 :
    Tenho. Estou com a N23.
    Não posso mais meter os prints diretamente do telemóvel ?
  19. lemor
  20. pikota
