48
[ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. cmanzini
    Donut Mar 17, 2017
  2. wachagga
    Eclair Mar 19, 2017
    wachagga , Mar 19, 2017 :
    Algo que eu reparei na N26 mas que não me lembro de ver nas anteriores. A minha ligação Wi-Fi está muito lenta... Em vários Wi-Fi reparo que devia estar a sacar a 5/6 Mb mas não passo dos 200/300 kB..
    Para esta fiz clean install ( full wipe ). Como já vinha de de uma versão anterior não re-instalei firmware.
  3. marcoprofeta
    Froyo Mar 19, 2017
    marcoprofeta , Mar 19, 2017 :
    Ainda não tinha tido problemas com o WiFi até a N26, simplesmente perde a ligação mas continua a aparecer ligado.
    sometheway likes this.
  4. TugaPower
    Jelly Bean Mar 19, 2017
    TugaPower , Mar 19, 2017 :
    Build 2017/03/19 #OPO
    TugaPower ROM G+
    Telegram Group: https://telegram.me/TugaPowerRom
    Telegram Channel: https://telegram.me/TugaPowerOnePlusOne
    #TugaPower N 27.0 LineageOS #laos #OnePlus #Android 7.1.1 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash.
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/54c1eb88-f902-4411-aa7a-e1872ac5a47a/TugaPowerFirmwareCM13_v4.zip
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise Deuteronomy 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser beta v55.x Stable ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    kernel 3.4.113
    Kernel is permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root and Magisk Manager
    What does not works:
    Let me know to add here :)
    Change log:
    Increased Volume steps ( Media and call )
    Project name: android
    cm: add custom tiles project
    Project name: android_system_core
    init: Don't update recovery on boot
    Project name: android_hardware_intel_img_psb_video
    psb_video: fix video encoding on clovertrail once again
    Project name: android_hardware_qcom_media
    mm-video-v4l2: vdec: Fix makefile derp introduced in d443c0d
    Project name: android_hardware_cyanogen
    livedisplay: SDM: Fix display mode handling
    Project name: android_vendor_cm
    repopick: encode commit subjects in utf-8 for printing
    cm: build custom tiles app
    overlay: Disable recovery updates
    apns: Remove proxy for the "TIM WAP" APN
    Add TvSettings to common tv config.
    Project name: android_frameworks_base
    Move wakelock option for flashlight to CameraManager.
    SingleHandWindow: Allow locking the rotation to 180°
    Add tile information to ACTION_QS_TILE_PREFERENCES intent
    PackageManager: Always let UID 0 start FallbackHome
    SystemUI: Dismiss keyguard on boot if disabled by current profile
    Fix intermittent slowness in resolver activity towards end of day.
    Revert "Wifi: Introduce a config parameter for IpReachabilityMonitor"
    Project name: android_frameworks_av
    Conditionally revert "CameraService: Allow HAL to handle video buffer duped FD's."
    Project name: android_build
    Revert "ota: Remove cruft we don't care about"
    Project name: android_packages_services_Telephony
    Telephony: AIRPLANE_MODE_ON has moved
    Telephony: Fix "Redirect to roaming SIM network setting(Dual SIM)"
    Project name: android_packages_apps_Contacts
    contacts: Add support for import contacts to local phone storage
    Project name: android_packages_apps_LockClock
    res: use selectableItemBackgroundBorderless for refresh button background
    Project name: android_packages_apps_CustomTiles
    CustomTiles: support direct boot
    CustomTiles: remove compass tile
    Project name: android_packages_apps_Settings
    AppOpsDetails: Check app permissions safely
    Fix possible NPE on SIM settings shutdown.
    Clean up SIM enable toggle implementation
    Settings: port manual provisiong support
    Project name: android_packages_apps_CMParts
    CMParts: update contributors db
    Project name: android_packages_apps_Dialer
    Dialer: AIRPLANE_MODE_ON has moved
    Project name: android_packages_apps_Bluetooth
    Revert "Introduced Active device for volume updates and volume update in pause state"
    Bluetooth: AIRPLANE_MODE_ON has moved
    Project name: android_packages_apps_ContactsCommon
    AccountType: use a pretty phone account icon for local storage account
    SelectAccountActivity : Support local phone account
    Add local phone account as a writable AccountTypes.
    Store all local contacts in only one account.
    contacts-common: Add support for import contacts to local phone storage
    Thanks all for the support.
    Download links:
    Android File Host: https://www.androidfilehost.com/?fid=457095661767146119
    MD5: f86dc1040adbcd4318d6032715873240
    Please dont mirror for now the roms zips, thanks
    pikota, scp41, Peles and 1 other person like this.
  5. okak24
    Gingerbread Mar 19, 2017
  6. TugaPower
    Quase que foi em sintonia...
  7. marcoprofeta
    Froyo Mar 19, 2017
  8. TugaPower
    A N27 não sairá via OTA porque onde as roms <N27 verificaram por updates era na Dropbox e eles decidiram acabar com as pastas públicas, automaticamente isso deu cabo da OTA, na N27 ela já vai verificar a outro lado, para resolver isso tens de alterar uma coisa no ficheiro build.prop ou então fazes download manualmente e flashas. Se quiseres alterar o build.prop avisa que coloco aqui instruções.
    manholas and marcoprofeta like this.
  9. okak24
    okak24 , Mar 19, 2017 :
    Pontaria. Nice. Na 28 a ota já funciona ou precisamos seguir os passos do build.prop? Se na próxima ainda for preciso fazer isso, coloca aqui os passos para agente tratar já do assunto. Mas suponho que a 27 já traga isso feito e a 28 já faz automático sozinho. Já agora, era no dropbox e agora passou para onde? Meocloud?
  10. marcoprofeta
    Froyo Mar 19, 2017
    Se não fosse pedir muito agradecia então que colocasses os passos a seguir. Obrigado
  11. moedinha
    Jelly Bean Mar 20, 2017
    moedinha , Mar 20, 2017 :
    Tenho um stress com a câmara, desde a N25. Fotos em landscape dá "erro desconhecido" e fecha a aplicação. No Camera FX dá bem . Alguma dica ?
  12. bobcat
    Ice Cream Sandwich Mar 20, 2017
    bobcat , Mar 20, 2017 :
    Fiquei com o meu OPO sem ligar após a instalação mas acho que foi ao aplicar o backup das apps com o Titanium Backup...
    Fiz novos wipes e instalação limpa e está novamente tudo ok. Aproveitei e apliquei outro firmware para ver se resolve os problemas que tinha com o Bluetooth desde a N24
    Estava era a tentar alterar o padrão de cores do relógio (pôr o alarme a vermelho quando está activo) mas, por algum motivo, não está a aceitar.
    Alguém tem o mesmo problema?
  13. Steeplechase
    Steeplechase , Mar 20, 2017 :
    Desde a N26 que me aparece isto sempre que tento instalar o gsam com permissões de root.
    Alguém me sabe dizer qual o problema?
    @TugaPower ?
  14. luiscarneirorm
    Gingerbread Mar 20, 2017
    luiscarneirorm , Mar 20, 2017 :
    Boas.
    Estou com problemas no micro nas chamadas, tenho que gritar para me ouvirem. Já experimentei a aplicação para gravar voz e funciona bem. Tenho certeza que já li alguém a queixar-se do mesmo mas agora não encontro onde.
    Alguém sabe qual é a solução?
  15. TugaPower
    TugaPower , Mar 20, 2017 :
    Experimenta montar o system como rw antes de efectuar esse processo com o Gsam.
    https://play.google.com/store/apps/details?id=com.blogspot.superthomaslab.mountsystemrorw
    Procura no Magisk Manager um módulo chamado OnePlus One Mic Fix e instala, verifica se fica melhor.
    Steeplechase likes this.
  16. Steeplechase
  17. luiscarneirorm
    Nem por isso. :/
    Já vi andei a pesquisar e vi para ir ao ficheiro mixer_path.xml aumentar os valores RX1 digital volume e por aí fora, mas estes valores estão a 0, não era suposto estarem praí a 80?
  18. pkas
    Honeycomb Mar 21, 2017
    pkas , Mar 21, 2017 :
    Esta última versão faralhou-me a máquina toda... Rollback efetuado.
    Notificações sempre presentes e a entrar, e a sair (abrem e fecham sozinhas e nem as consigo retirar do écran inicial)
  19. Steeplechase
    Ice Cream Sandwich Mar 21, 2017
  20. bobcat
    bobcat , Mar 21, 2017 :
    Era eu que tinha o problema. O módulo do Magisk que o @TugaPower referiu ajudou um pouco mas ainda há pessoas que não me ouvem.
    Onde é que encontraste a solução que referes nesta resposta? Já a tentaste?
