47
[ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. Bananinha Ice Cream Sandwich Oct 1, 2017
    Bananinha, Oct 1, 2017 :
    saquei o 14.0 e ja instalou tranquilo...e o resto ??
  2. TugaPower Jelly Bean Oct 2, 2017
    TugaPower, Oct 2, 2017 :
    Que resto?
  3. TugaPower Jelly Bean Oct 8, 2017
    TugaPower, Oct 8, 2017 :
    Build 2017/10/08 #OPO
    TugaPower ROM G+
    Telegram Group: https://t.me/TugaPowerOPO
    #TugaPower N 50.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash. ( http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366 )
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip/
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Disable manually AudioFX to hide the icon from drawer
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    Kernel permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root v14.x and Magisk Manager 5.0.x versions
    Replaced Trebuchet with latest Lawnchair beta ( https://github.com/Deletescape-Media/Lawnchair )
    If you guys want again Trebuchet just install as regular app ( https://meocloud.pt/link/4aa8084d-fb02-49ee-ab51-8c3006d710bc/Trebuchet.apk )
    What does not works:
    Let me know to add here :)
    Change log:
    Project name: android_device_oneplus_bacon
    bacon: remove old-modem hack
    October Security patch
    Project name: android_system_bt
    Fix allocating buffers of the right size when BT_HDR is included
    Project name: android_system_vold
    Fix bug in cryptfs_verify_passwd with hardware disk encryption
    Project name: android_hardware_ril
    Fix multi sim support and warnings
    Fix security vulnerability in pre-O rild code.
    Project name: android_vendor_cm
    vendor: We are now LineageOS
    Project name: android_frameworks_base
    Fix security hole in GateKeeperResponse.
    Enforce policy for camera gesture in keyguard
    SystemUI: Cleanup BatteryMeter
    SystemUI: Improve battery icons
    Revert "Camera: ignore torch status update for aux or compsite camera"
    SystemUI: Hide ambient display tile if device does not support it
    Don't crash when checking if components are protected
    Project name: android_frameworks_av
    Fix 'potential memory leak' compiler warning.
    Check buffer size in useBuffer in software components
    stagefright: avoid buffer overflow in base64 decoder
    Add EFFECT_CMD_SET_PARAM parameter checking to Downmix and Reverb
    Fix memory leak in OggExtractor
    Skip track if verification fails
    Project name: android_packages_apps_PackageInstaller
    Disable overlays while installer is resumed
    Project name: android_packages_apps_Settings
    Settings: Correct german translation for 1 registered fingerprint
    Disabling the activate button when paused
    Project name: android_packages_apps_Gallery2
    Gallery: Kill media effect dialog on movies
    Gallery2: Fix crash when muting a video
    Fix gallery crash when trimming video
    Thanks all for the support.
    Download: https://www.androidfilehost.com/?fid=673791459329051985
    MD5: 1060090ea34d6d9b70c16eb15193ca99
    Please dont mirror for now the roms zips, thanks
    jonathan89, bobcat, moedinha and 4 others like this.
  4. bobcat Ice Cream Sandwich Oct 10, 2017
  5. moedinha Jelly Bean Oct 11, 2017
    moedinha, Oct 11, 2017 :
    Ao atualizar para a última versão , fiz o wipe dos system, cache e dalvik e depois instalei a Rom e a seguir as gapps ; mas estas não ficaram bem, e reinstalei a ROM e as gapps.
    Ainda dá erro ao iniciar as apps da google. Coloquei as nano, v. 7.1
    ** EDIT ** Continua igual, será que tenho que fazer um clean install ?
    ** EDIT 2** Não foram só as apps da google, outras apps tb não abrem. Vou mesmo fazer um reset.
  6. marcoprofeta Eclair Oct 13, 2017
    marcoprofeta, Oct 13, 2017 :
    Após a última actualização noto o sistema muito mais lento, nomeadamente ao sai das aplicações.
  7. jorgesecoz Froyo Oct 16, 2017
    jorgesecoz, Oct 16, 2017 :
    Boas eu estou com a Rom oficial da Lineage OS a versão mais actualizada no entanto acho a Rom muito comilona em termos de bateria, queria saber como se comporta esta Rom se vale a pena a mudança e a vossa opinião em relação à Rom.
    Obrigado
  8. felixdacosta Ice Cream Sandwich Oct 16, 2017
    felixdacosta, Oct 16, 2017 :
    Sem razão de queixa, antes pelo contrário. Quanto a bateria, o mesmo desempenho d que com as outras ROMs que já usei.
  9. marcoprofeta Eclair Oct 16, 2017
    marcoprofeta, Oct 16, 2017 :
    Também não tenho razões de queixa a nível de bateria até porque tenho os dados ligados 24h além de ainda usar muito o Spotify, whatsapp e instagram.
  10. jorgesecoz Froyo Oct 16, 2017
    Mas o desempenho da bateria é bom? É que a Rom que uso da Lineage OS que uso a bateria voa literalmente
  11. felixdacosta Ice Cream Sandwich Oct 16, 2017
    Com os dados ligados de manha até ao fim da tarde num local com rede fraca e depois wi-fi até à noite, dura pouco mais de um dia.
  12. jorgesecoz Froyo Oct 16, 2017
  13. felixdacosta Ice Cream Sandwich Oct 16, 2017
    TugaPower and pikota like this.
  14. TugaPower Jelly Bean Oct 17, 2017
    TugaPower, Oct 17, 2017 :
    Build 2017/10/17 #OPO
    TugaPower ROM G+
    #TugaPower N 51.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Compiled using UBER-Linaro ( smoth and battery should be now more improved )
    Change log N51.0 :
    Project name: android_external_wpa_supplicant_8
    Patched against KRACK
    Clear PMK length and check for this when deriving PTK
    Add debug prints on PMK configuration in WPA supplicant
    WPA: Extra defense against PTK reinstalls in 4-way handshake
    Remove all PeerKey functionality
    Add MGMT_TX_STATUS_PROCESS command for testing purposes
    FT: Do not allow multiple Reassociation Response frames
    WNM: Ignore WNM-Sleep Mode Response without pending request
    TDLS: Reject TPK-TK reconfiguration
    Fix PTK rekeying to generate a new ANonce
    Prevent installation of an all-zero TK
    Extend protection of GTK/IGTK reinstallation of WNM-Sleep Mode cases
    Prevent reinstallation of an already in-use group key
    hostapd: Avoid key reinstallation in FT handshake
    Set EAPOL-Key Key Length field to 0 for group message 1/2 in RSN
    extract_utils: Allow to interrupt the extraction
    Revert "Always hide protected apps from the recent tasks list"
    Core: Battery warning levels are inclusive, not exclusive
    Project name: android_packages_services_Telephony
    Telephony: Workaround for MWI on Sprint
    Disable overlays while installer is resumed"
    Project name: android_packages_apps_Calendar
    Calendar: Show week start and end in title for Week view
    Project name: android_packages_apps_Eleven
    Eleven: Fix potential NPE when media server crashes
    Eleven: Don't use a sticky service
    Project name: android_packages_apps_Recorder
    Recorder: Advertise that we can record voice
    Download: https://androidfilehost.com/?fid=673791459329054476
    MD5: 137e8a6f4d86abb67244775870977486
  15. TugaPower Jelly Bean Oct 17, 2017
    Pessoal vejam a N51 , teve a ser testada no grupo do telegram nos ultimos 2 dias, bateria e desempenho deve agora ser melhor um bocado.
    felixdacosta, Peles, bobcat and 2 others like this.
  16. pgomes2000 Froyo Oct 17, 2017
  17. pgomes2000 Froyo Oct 18, 2017
    pgomes2000, Oct 18, 2017 :
    No xda já existe o LineageOS 15 (Oreo) em versão Alpha.
    Dizem que está mt estável e que pode já ser usada no dia-a-dia. É uma questão de exprimentares e dá feedback :)
    AnuiBay likes this.
  18. jorgesecoz Froyo Oct 18, 2017
    jorgesecoz, Oct 18, 2017 :
    Está com melhores rendimentos?
  19. bobcat Ice Cream Sandwich Oct 18, 2017
    bobcat, Oct 18, 2017 :
    Fiz agora o update e vou testar... Obrigado @TugaPower
  20. AnuiBay Ice Cream Sandwich Oct 18, 2017
