48
[ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. pikota
    Marshmallow Moderator Nov 29, 2017
    pikota , Nov 29, 2017 :
    Quando tinha o OnePlus One isso acontecia às vezes, ultrapassava isso fazendo download da ROM via browser e depois entrava na TWRP e flashava, experimenta fazer assim. :)
    Não sei se já viste, mas tens aqui já Android 8.0 para o OnePlus One do @TugaPower. :)
  2. André Mendes
    Froyo Nov 29, 2017
    pikota likes this.
  3. pikota
    Na passagem para o Android 8.0, faz uma instalação limpa, é melhor e prevines problemas. :)
  4. TugaPower
    Jelly Bean Dec 10, 2017
    TugaPower , Dec 10, 2017 :
    Build 2017/12/10 #OPO #N
    TugaPower ROM G+
    Telegram Group: https://t.me/TugaPowerOPO
    #TugaPower N 54.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash. ( http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366 )
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip/
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Disable manually AudioFX to hide the icon from drawer
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    Kernel permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root v14.x and Magisk Manager 5.0.x versions
    Replaced Trebuchet with latest Lawnchair beta ( https://github.com/Deletescape-Media/Lawnchair )
    If you guys want again Trebuchet just install as regular app ( https://meocloud.pt/link/4aa8084d-fb02-49ee-ab51-8c3006d710bc/Trebuchet.apk )
    Compiled using UBER-Linaro ( smoth and battery should be now more improved )
    3 finger screenshot support
    What does not works:
    Let me know to add here :)
    Change log N54.0 :
    N 54.0 Change log
    Be sure you dont have an older Magisk module called Android Pay Fix on Magisk or NFC will start to FCing
    Project name: android_device_oppo_common
    common: Update KeyHandler for api change
    Project name: android_device_oneplus_bacon
    bacon: Advertise support for extended length nfc
    Project name: android_packages_apps_Lawnchair
    Changelog for build 1.1.0.1739
    Merge pull request #992 from divadsn/snow
    Update build-tools and support libs
    Fix derps
    Oh no, it's raining dead smiles!
    Add more customization for snowflakes
    Add size scale for snowflakes
    Add rotation attribute for snowflakes
    Move snowfall settings to own category
    Project name: android_frameworks_base
    SystemUI: Fix title text clipping when task lock button is visible
    ZenModeHelper: Allow lights by default
    fw/b: Return a KeyEvent instead of a boolean in KeyHandler
    Project name: android_frameworks_av
    Revert "libstagefright: Use proper ctts offset"
    Add ATV apps AppDrawer and LineageCustomizer
    Project name: android_vendor_cm
    ATV: Ship AppDrawer
    extract_utils: Use temporary folder for system dump
    repopick: Support overriding the default commits count to check
    vendor: enable multi-user across all devices
    extract-files: Bring back old behavior for SRC
    sensitive_pn: Add BG human trafficking and domestic abuse hotlines
    Project name: android_packages_apps_Trebuchet
    Trebuchet: Use ICU4J public APIs
    Project name: android_packages_apps_Settings
    BugFix:Correct fullBearer in APNSettings
    Telephony: Fix Crash in SimStatus Fragment
    Settings: fix vibrate for calls in Setting app displayed incorrect issue
    Settings: back icon doesn't work in format SD as portable page.
    Settings: Fix settings force close
    Settings: Fix crash when disconnect wifi
    Project name: android_packages_apps_AppDrawer
    Initial commit
    Project name: android_packages_apps_CMParts
    CMParts: gestures: Update KeyHandler for API change
    CMParts: gestures: Add volume down/up actions
    CMParts: Add strings for stylus gestures
    Project name: android_external_chromium-webview
    Update webviews to Chromium 63.0.3239.83
    Thanks all for the support.
    Download: https://www.androidfilehost.com/?fid=889964283620771314
    MD5: acb4b7a1fedcd7d7ab6d25d690766a1c
    Please dont mirror for now the roms zips, thanks
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
    pikota, scp41, mordep and 4 others like this.
  5. TugaPower
    Jelly Bean Dec 12, 2017
    TugaPower , Dec 12, 2017 :
    Como alguns já devem ter reparado, a N55 já se encontra na OTA, não tive tempo para colocar o post habitual, devo fazer lo ao fim do dia de hoje.
    Its basically December security patch and one issue fixed that sometimes the install button would not work when installing an apk.
    Podem usar o site para fazer download da última versão e respectivo changelog entre outras coisas.
    http://tugapower.tk/downloads/oneplus-one/
  6. Bananinha
    Ice Cream Sandwich Dec 30, 2017
    Bananinha , Dec 30, 2017 :
    Pessoal, o meu OPO esta inutilizável por algum motivo. Tinha a N49, não atualizei desde então. Hoje, estava no PC e peguei no telemóvel para ver as horas. Voltei a pousá-lo. 5 minutos depois faço o mesmo e ele simplesmente apagou. Pensei que fosse um random reboot. Reiniciei, e qual o meu espanto quando entra normalmente mas chega a um ecrã em que so aparece "O ANDROID ESTA A INICIAR" e fica continuamente assim. Esperei uma hora e nada...Alguem me pode ajudar ? @TugaPower @pikota alguém ?
  7. pikota
    Marshmallow Moderator Dec 30, 2017
    pikota , Dec 30, 2017 :
    Experimenta entrar na recovery e fazer wipe à cache e dalvik, vê se resulta.
    TugaPower likes this.
  8. jmarks
    Honeycomb Dec 30, 2017
    jmarks , Dec 30, 2017 :
    Desejo a todos um bom final de ano e um 2018 com tudo de bom.
    @TugaPower, com a prestimosa colaboração do @pikota instalei a TugaPowerN54 num OPO. Agora recebo informação de que está disponível a versão N55 mas o download via OTA falha sistematicamente. Algum de vós me pode dar uma explicação para este facto e como resolver a situação?
    Cumprimentos,
    JMarks
    pikota likes this.
  9. Peles
    Gingerbread Jan 2, 2018
    TugaPower and pikota like this.
  10. marcoprofeta
    Eclair Jan 3, 2018
    marcoprofeta , Jan 3, 2018 :
    Estou sempre a perder a ligação ao WiFi dentro de casa já desde a N55 e agora com a N56 continua. Mais alguém com o mesmo problema?
  11. TugaPower
    Jelly Bean Jan 4, 2018
    TugaPower , Jan 4, 2018 :
    Experimenta mudar de firmware...
    A todos um bom ano de 2018
    Peles, pikota and AnuiBay like this.
  12. felixdacosta
    Ice Cream Sandwich Jan 8, 2018
    felixdacosta , Jan 8, 2018 :
    Uma perguntinha (não sei se já está falado algures para trás). Esta ROM tem possibilidade de incluir botão de acesso a perfis na barra de estado? Obrigado.
  13. felixdacosta
    Ice Cream Sandwich Jan 13, 2018
    felixdacosta , Jan 13, 2018 :
    Tem, sim senhor. Já que ninguém te responde, respondo eu... :D
  14. npr3dator
    Honeycomb Jan 14, 2018
    npr3dator , Jan 14, 2018 :
    Boas...
    Desculpa @TugaPower mas estou com o mesmo problema... Estou com o teu firmware.. Qual aconselhas para mudar... Só para não dar caga**..
    Obrigado
  15. TugaPower
    Jelly Bean Jan 15, 2018
    pikota and npr3dator like this.
  16. Steeplechase
    Ice Cream Sandwich Jan 22, 2018
    Steeplechase , Jan 22, 2018 :
    @TugaPower há dias resolvi fazer factory reset e instalar tudo de novo. Fiz o download da TugaPower 56, gapps e firmware que estava na tua página. Tudo correu dentro da normalidade.
    Há dias percebi que ao abrir o MEO DRIVE o GPS andou para ali aos papeis durante dois ou três minutos. Logo a seguir descobri que a app da câmara dá erro, nem abre. Fiz download da Bacon Camera e o vídeo não funciona. Faz vídeos de uns décimos de segundo...
    Sabes o que se passa?
  17. marcoprofeta
    Eclair Jan 22, 2018
  18. TugaPower
    Jelly Bean Jan 23, 2018
    TugaPower , Jan 23, 2018 :
    E durante o flash correu tudo bem? Que twrp estás a usar? Quanto a câmara se limpares os dados e cache da mesma, a mesma funciona?
    Steeplechase likes this.
  19. Steeplechase
    Ice Cream Sandwich Jan 23, 2018
    Steeplechase , Jan 23, 2018 :
    Como é que não me lembrei de limpar dados e cache??? Fiz isso e já funciona. Obrigado. És uma máquina.
  20. felixdacosta
    Ice Cream Sandwich Jan 24, 2018
    felixdacosta , Jan 24, 2018 :
    Tenho um problema curioso. Neste momento estou com esta ROM mas já o senti com outras. De vez em quando os botões de menu, pagina inicial e back deixam de funcionar ou funcionam de forma deficiente. A solução passa sempre por reiniciar o telemóvel. Curiosamente, quando esta situação se apresenta, o menu de reinicio deixa de ter as opções expandidas, resumindo-se apenas ao simples reinicio do telemóvel. Agora passei para os botões virtuais a ver se faz alguma diferença.
    Alguém tem ou já teve um problema similar?
    Obrigado.
