47
[ROM][LineageOS][Android 7.1.2][OMS7] TugaPower
  1. moedinha Jelly Bean May 4, 2018
    moedinha, May 4, 2018 :
    Com esta versão 58 o meu consumo de bateria disparou .... mais alguém notou ?
  2. youbi Portuguese POC Assistant Head Moderator May 4, 2018
    youbi, May 4, 2018 :
    Quanto tempo já tem o teu opo? É que se for dos primeiros até pode ser já a bateria a começar a dar sinais.
    Pelo que tenho visto estando a fazer 4 anos existe pessoal que já se começa a queixar por esta altura (o que acaba por ser expectável).
  3. moedinha Jelly Bean May 6, 2018
    moedinha, May 6, 2018 :
    Sim, o meu é dos primeiros :) Mesmo assim, só com o update a bateria reduzir para quase metade era coincidência. Vou fazer um clean install e logo vejo.
    Entretanto vou ver baterias novas :) Alguma dica ?
    youbi likes this.
  4. TugaPower Jelly Bean Jun 16, 2018
    TugaPower, Jun 16, 2018 :
    Build 16/06/2018 #OPO #N
    TugaPower ROM G+
    Telegram Group: https://t.me/TugaPowerOPO
    #TugaPower N 60.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    If you have some spare bucks consider donating, it will be really appreciated: https://www.paypal.me/TugaPower
    Please be sure you are using one TWRP that can handle firmware flash. ( http://forum.xda-developers.com/oneplus-one/development/unofficial-twrp-3-0-x-tugapower-t3398366 )
    Also be sure you are using proper firmware. The one recomended its the one from cm 13 nighly, you can find here: https://meocloud.pt/link/c1d9a297-e3f7-480b-9567-1bc601c073dd/TugaPowerFirmwareCM13_v4.zip/
    Relative to gapps, testing open gapps 7.1 nano package, working without issues
    http://opengapps.org/?api=7.1&variant=nano
    Replaced built in OTA by OTA Updates app ( https://github.com/MatthewBooth/OTAUpdates )
    Replaced audiofx with Viper4Arise 2.4 ( https://forum.xda-developers.com/android/software/r-s-e-sound-systems-auditory-research-t3379709 )
    Disable manually AudioFX to hide the icon from drawer
    Kcal Support ( use Color Control app to adjust colors )
    Gello removed and replaced by latest TugaBrowser ( built in OTA for the Browser ) ( blocks ads and protect privacy)
    TugaBrowser -> http://forum.xda-developers.com/android/apps-games/app-tugabrowser-t3472457
    Call Record
    Support out of the box to microG GmsCore ( http://forum.xda-developers.com/android/apps-games/app-microg-gmscore-floss-play-services-t3217616 )
    No more need to make microG system app
    Multi-ROM Support
    Increase max chg current to 2000/500mA
    Kernel permissive
    PoGO: Gonna catch then all
    Partial screenshot ( activate screenshot on power menu button and long press there to activate partial screenshot )
    Full support to Substratum OMS7 RootLess:)
    Powered by Magisk root v16.x
    Replaced Trebuchet with latest Lawnchair beta ( https://github.com/Deletescape-Media/Lawnchair )
    3 finger screenshot support
    What does not works:
    Let me know to add here :)
    Be sure you dont have an older Magisk module called Android Pay Fix on Magisk or NFC will start to FCing
    Change log N59.0 :
    Jun Security Patch
    Updated Lawnchair
    Project name: android_frameworks_base
    SystemUI: Toggle USB tethering only when USB is connected
    Rework thumbnail cleanup
    ResStringPool: Fix security vulnerability
    [BACKPORT] SystemUI: Fix alignment glitch with brightness mirror
    ConnectivityService: move reportNetworkConnectivity to handler
    ConnectivityService: safer locking
    Revert "Prevent deadlock when using always-on legacy VPNs"
    Project name: android_system_bt
    Drop LE CoC fragments when frame size is too big
    Fix OOB read in process_l2cap_cmd
    [Backport] Handle bad packet length in gatts_process_read_req
    Add bounds check for BNEP_Write
    PAN: Always allocate in bta_pan_data_buf_ind_cback
    Fix unexpected behavior in bta_dm_sdp_result
    Project name: android_packages_providers_UserDictionaryProvider
    Check caller before accessing database
    Project name: android_packages_providers_MediaProvider
    Fix deadlock in MediaProvider
    Project name: android_packages_apps_Nfc
    NFC: Clean duplicated and unknown permissions
    Project name: android_packages_apps_Dialer
    InCallUI: Refactor primary call info card
    Fix incorrect number formatting in call stats details.
    Remove redundant layout item.
    Project name: android_vendor_cm
    repopick: Update SSH queries result to match HTTP queries
    Project name: android_frameworks_av
    EffectsFactory: add debug and trace wrappers for NXP LifeVibes
    Add check preventing div0 issue
    Sanitize effect descriptors for AudioPolicyService binder calls.
    Init gain config to prevent uninit leak.
    Project name: android_frameworks_opt_telephony
    Fixed invalid pdu issue
    Telephony: Fix "Keep preferred SMS Sim"
    Project name: android_external_sonivox
    sonivox: fix hang caused by bad meta-event
    Project name: android_external_libmpeg2
    Adding Check For Number of Skip MBs
    Project name: android_external_libhevc
    Add limits check for depth hierarchy sps parameters
    Return error for invalid sps sub layers parameters
    Return error for invalid reorder parameter
    Project name: android_external_libavc
    Encoder: Return error for odd resolution
    Decoder: Modify setting short term reference field flag
    Project name: android_external_libvpx
    libvpx: cherry pick fix to OOB of mv_cost index.
    manifest: Remove external/libvorbis
    manifest: Track own external/libvorbis
    Thanks all for the support.
    Download: https://www.androidfilehost.com/?fid=746163614322272972
    MD5: c64e8f73446c87baed43316285375b86
    Please dont mirror for now the roms zips, thanks
    Sources :
    Rom:- https://github.com/LineageOS
    Kernel:- https://github.com/LineageOS/android_kernel_oneplus_msm8974
  5. TugaPower Jelly Bean Jul 30, 2018
    TugaPower, Jul 30, 2018 :
    Build 29/07/2018 #OPO #N
    TugaPower ROM G+
    #TugaPower N 61.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N61.0 :
    Lawnchair updated to 1.2.0.1884
    Updated Magisk to 16.8-546c7ce
    Project name: android_build
    July Security patch
    Remove unnecessary casts in postUpdateSlider()
    Fix the "Alarm volume" icon is displayed incorrectly
    PhoneWindowManager: Allow torch and track skip during ambient display
    Fix wrong peek height of the notification panel
    Fix an error with hardware keyboard shortcuts
    Tuner: Move clock seconds option to status bar settings
    Truncate newline and tab characters in BluetoothDevice name
    keyguard: Handle left icon visibility properly with wifi only devices
    manifest: Track android-8.1.0_r36 for system/ca-certificates
    Track own external/bouncycastle
    Return error for invalid st/lt sps parameters
    Project name: android_external_bouncycastle
    Fix probable prime confidence calculations.
    InCallUI: Keep button states in sync with call properties
    Project name: android_packages_apps_Bluetooth
    Make sure server response doesn't exceed maximum allowable length
    Project name: android_packages_apps_CMParts
    CMParts: Move clock seconds option to status bar settings
    Project name: android_packages_apps_PhoneCommon
    Adjust SpecialCharInternalLayoutStyle to match other buttons
    Project name: android_packages_services_Telephony
    Telephony: Get rid of build warnings
    Speed up id3v2 unsynchronization
    Project name: android_frameworks_native
    Increment when attempting to read protected Parcel Data
    Disallow reading object data from Parcels with non-object reads
    Don't pad before calling writeInPlace().
    Revert "config: Remove 7z lib7z unrar unzip zip makefile entries"
    Project name: android_hardware_qcom_display
    libgralloc: Fix adding offset to the mapped base address
    Project name: android_system_media
    Merge commit 'f9e3022c474619c69a46ae7dbe11b5b531dbad57' into am-0d58d39a-0539-474e-b9c8-36cc976d15e8
    Project name: android_system_core
    init.rc: move load_system_props to beginning of 'on fs'
    SMP: Validate remote elliptic curve points
    Prevent stack overflow in btif_storage
    Check number of attributes before writing to a buffer
    AVRC: Add bound check for AVRC_EVT_APP_SETTING_CHANGE
    Add bounds check to l2cble_process_sig_cmd L2CAP_CMD_DISC_REQ
    Fix unexpected behavior in smp_sm_event
    Download: https://www.androidfilehost.com/?fid=5862345805528061361
    MD5: d648c78e97cfcca8ab8d94e61dde6e47
    pikota likes this.
  6. TugaPower Jelly Bean Sep 23, 2018
    TugaPower, Sep 23, 2018 :
    Build 17/09/2018 #OPO #N
    TugaPower ROM G+
    #TugaPower N 62.0 LineageOS #laos #OnePlus #Android 7.1.2 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N62.0 :
    Magisk and Lawchair updated
    August Security Patch
    Project name: android_external_curl
    Disable unused protocols.
    Project name: android_external_chromium-webview
    Updated webviews to Chromium 67.0.3396.87
    Project name: android_external_e2fsprogs
    Ignore quotes in safe_print().
    Bug fix for flush without valid frames
    Project name: android_packages_apps_PackageInstaller
    RESTRICT AUTOMERGE: Always use safe labels
    Project name: android_packages_apps_Settings
    Merge translations of Bluetooth confirmation text
    DO NOT MERGE Fix unexpected behavior in Bluetooth pairing
    Project name: android_packages_apps_LineageCustomizer
    Correct package name
    LineageCustomizer: Bring inline with fugu's 14.1 version
    Project name: android_packages_apps_Messaging
    Messaging ignores file URIs shared via intent
    Revert "Messaging: Request external storage permission before handling shared files"
    Project name: android_packages_apps_UnifiedEmail
    Filter Attachment file name of forward slashes for .eml attachments.
    Fix potential NPE in EmergencyCallbackModeExitDialog.
    DO NOT MERGE Revise security requirements for TelephonyManager#endCall.
    Fix possible out of bounds read
    Make safe label more safe
    ResStringPool: Prevenet boot loop from se fix
    Fix DynamicRefTable::load security bug
    manifest: Track our own curl
    init: add install_keyring for TWRP FBE decrypt
    init.rc: Lock down access to /proc/net/fib_trie
    Project name: android_system_vold
    Merge commit '635193ab36302e5f65e99c7df2f256cfd37068c7' into am-b7f1a67b-2024-4274-aa7d-e88e8cceb407
    Address const issues in preparation for libcxx rebase.
    GATT: Use correct logging macro replacement
    RESTRICT AUTOMERGE: Fixes two bluetooth bugs causing remote overreads (1/2)
    Add PDU size checks in process_service_search_attr_rsp
    GATT: Handle too short Error Response PDU
    Add checks whether the AVDTP element data length is valid
    BNEP: Fix OOB access in bnep_data_ind
    Decrease length after reading from array in process_service_attr_req
    DO NOT MERGE SMP: Check p_cb->role in smp_br_state_machine_event
    Download: https://tugapower.net/TP/OP1/NOUGAT/TugaPowerN62.zip
    MD5: 58e96c2c203c1097fe15d9a38c5689b3
    pikota and Carluuz like this.
  7. TugaPower Jelly Bean Jan 12, 2019
    TugaPower, Jan 12, 2019 :
    Build 12/01/2019 #OPO #N
    TugaPower ROM G+
    #TugaPower N 65.0 LineageOS #laos #OnePlus #Android 7.1.2r36 #OMS7 #SubstratumRootLess
    Call Record
    Multi-ROM Support
    Kernel permissive
    Change log N65.0 :
    December Security Patch
    Updated Lawchair to Alpha 783
    Updated Magisk Cannary Release to latest version
    ( use https://bit.ly/2N8UVlq in custom magisk channel )
    Project name: android_external_v8
    Remove unrecognized compiler flag
    Revert "Backport: Fix Object.entries/values with changing elements"
    CTS error while media dump()
    Recover shady content:// paths.
    Pass userId through to singleton ContentProviders
    This android version is the last update, no more updates to Nougat
    It was a long run...
    Download: https://tugapower.net/TP/OP1/NOUGAT/TugaPowerN65.zip
    MD5: 272a0ea5dd43041d0b45a11f1470c8bb
  8. TugaPower Jelly Bean Jan 12, 2019
    TugaPower N 65.0 foi o ultimo update, chegou o seu fim.
    Foi um grande caminho por muitos acompanhado.
    Um grande obrigado pelo suporte que voces teem me dado ao longo destes anos.
    Cumprimentos
  9. taunus Ice Cream Sandwich Jan 12, 2019
    taunus, Jan 12, 2019 :
    Caro Daniel
    Obrigado nós por teres dado suporte a este grande terminal que é o Oneplus One. Ainda hoje estive a comentar o facto de nunca ter pensado comprar uma bateria nova para um terminal com 4,5 anos, mas foi o que fiz na semana passada pois parece-me prematuro pendurar as botas ;)
    TugaPower likes this.
