23
[ROM][MIUI8][ONEPLUS 3] - Chinese ROMs, Global and Patch ROMs
  1. pvsuru
    Eclair Jul 27, 2016
    pvsuru , Jul 27, 2016 :
    In
    Thanks for providing this ROM. Installed and working perfectly.
    Can we have OTA for update for this ROM?
  2. Hogyoku
    Donut Jul 27, 2016
    Hogyoku , Jul 27, 2016 :
    Dont expect that since this rom is a hack job. If a new rom comes out just flash it over the current one
  3. djmarco
    Honeycomb Jul 27, 2016
  4. pokexperto1
    Eclair Jul 27, 2016
  5. pvsuru
    Eclair Jul 27, 2016
    English and chinese only
  6. Jbyron602
    Cupcake Jul 27, 2016
    Jbyron602 , Jul 27, 2016 :
    Does anyone know if xposed will work with this rom? Currently have it installed, and after finally getting Google services to be able to sync my contacts, realized I didn't install xposed as I usually do. Any knowledge would be appreciated. (Side note; everything seems to be working just fine, except the alert slider)
  7. Hogyoku
    Donut Jul 28, 2016
    Hogyoku , Jul 28, 2016 :
    Flash this miui exposed zip
    http://forum.xda-developers.com/xposed/unofficial-xposed-miui-t3367634
    Jbyron602 likes this.
  8. nrjkmrdll
    Froyo Jul 28, 2016
    nrjkmrdll , Jul 28, 2016 :
    Any idea to get VoLTE working on this ROM. This thing flies and equally beautiful.
  9. Jbyron602
    Cupcake Jul 29, 2016
  10. raiyan hossain
    Donut Jul 29, 2016
    Shafiqur016 likes this.
  11. Hogyoku
    Donut Jul 29, 2016
    Hogyoku , Jul 29, 2016 :
    Check under screen setting i think it should be there
  12. pvsuru
    Eclair Jul 31, 2016
    pvsuru , Jul 31, 2016 :
    ROM is very stable. Dash works very fine. Slider button will not work.
    This ROM is very customised so you need to check at least once all setting sub-menu to use the ROM at fullest.
    Only drawback is battery usage is higher compared to OxygenOS (Approx. 20% higher), may be due to many inbuilt apps which you will not find in any other ROM.
  13. pvsuru
    Eclair Jul 31, 2016
    Global Beta
  14. iamstormeee
    Cupcake Aug 1, 2016
  15. tobias14
    Ice Cream Sandwich Aug 1, 2016
    tobias14 , Aug 1, 2016 :
    yes, it is based on chinese beta
  16. pvsuru
    Eclair Aug 2, 2016
    pvsuru , Aug 2, 2016 :
    Sorry, it is Chinese beta. But all things are available in English.
  17. pvsuru
    Eclair Aug 2, 2016
    Not able to change the default application. e.g. If I want to change laucher, though default is changed to other launcher from system launcher, MIUI will open up system launcher only on home button touch. It is not selecting another launcher made as defaulter launcher. Same things happens about other defaults. Can anybody help to make default changed permanently.
    Also, camera is too slow to take the pictures.
  18. itssandeepd
    Honeycomb Aug 2, 2016
    #38
  19. masterone9
    Cupcake Aug 12, 2016
    masterone9 , Aug 12, 2016 :
    As far as network connectivity is concerned does LTE work or is its just 3g for the time being. Or does it more depend on your carrier?
    #39
  20. gaster
    Moderator Moderator Aug 12, 2016
    gaster , Aug 12, 2016 :
    Thanks for sharing pal
    #40
    mido25 likes this.
