23
[ROM][MIUI8][ONEPLUS 3] - Chinese ROMs, Global and Patch ROMs
  1. Mobile Fan
    Froyo Sep 7, 2016
    Mobile Fan , Sep 7, 2016 :
    ^^ I know that. I was talking about keyboard settings which can be accessed by "Settings -> Additional Settings -> Language and Input -> Sogou Keyboard for MIUI". They all are in Chinese.
    #81
  2. ashoktvm
    Ice Cream Sandwich Sep 7, 2016
  3. mido25
    #83
  4. pvsuru
    Eclair Sep 7, 2016
    #84
  5. Danderlion
    Cupcake Sep 7, 2016
    #85
  6. x.0ni.x
    Eclair Sep 8, 2016
    #86
  7. pvsuru
    Eclair Sep 9, 2016
    pvsuru , Sep 9, 2016 :
    You can create your own id on pan.baidu.com by using your mobile number with country code. Do login with user id as mobile number or quick login through OTP. After successful login, you can bind your email id and give a user name to your profile.
    Now you can login either with your profile name or email id as user name. In stead of downloading the file, you should save it to baidu cloud (5 to 7 GB cloud storage). On PC or mobile download BaiduYun cloud app and using this app, you can download saved link to your PC or mobile.
    Video Tutorial is available on Google.
    #87
  8. mido25
    Ice Cream Sandwich Sep 11, 2016
    #88
    Danderlion likes this.
  9. 12nightmare
    Cupcake Sep 13, 2016
    #89
  10. G_Fabio_Andres_Plata_Tor
    Donut Sep 13, 2016
    G_Fabio_Andres_Plata_Tor , Sep 13, 2016 :
    Watch out. for this miui roms has 2 versions. one of them with OTA updates and the other only weekly updates without otas, are differents, for your problem, make a clean install, probably you mix the roms.
    Name of the zip "Otas version" miui-oneplus3-6.9.8-6.0.zip" (this version include OP3 the camera app and not include MIUI camera app - dont work one hand mode, but has many features"
    Name of the Weekly updates miui-oneplus3-6.9.8_20160909_6.0.zip
    #90
  11. 12nightmare
    Cupcake Sep 14, 2016
    #91
  12. pvsuru
    Eclair Sep 14, 2016
    pvsuru , Sep 14, 2016 :
    Successfully updated OTA from v 6.9.8 to v 6.9.12 through Updater App (Update App which is installed during full installation of 6.9.8).
    Do not use settings > About phone > System update.
    #92
  13. viral1221
    #93
  14. G_Fabio_Andres_Plata_Tor
    Donut Sep 14, 2016
    G_Fabio_Andres_Plata_Tor , Sep 14, 2016 :
    Works on 6.9.8 Weekly update, dont work on 6.9.8 or 6.9.12 Otas update.
    #94
  15. G_Fabio_Andres_Plata_Tor
    Donut Sep 14, 2016
    have you problem with camera app? I mean when use flash to take a picture? it's OP3 camera app right? not miui app
    #95
  16. pvsuru
    Eclair Sep 15, 2016
    pvsuru , Sep 15, 2016 :
    I don't find any problem with camera flash. Flash works fine with Flash Alway On and Auto flash. It is of OP3 Camera.
    #96
  17. viral1221
    Cupcake Sep 15, 2016
    viral1221 , Sep 15, 2016 :
    k thanks and VOLTE is working or not ?
    #97
  18. boydivalor
    Honeycomb Sep 16, 2016
    boydivalor , Sep 16, 2016 :
    So you're telling that the OTA version and the Weekly downloadable versions are different in their features ?
    Can you please describe the most of them ?
    And if you can place a direct link for the lastest versions, i would love to give it a try.
    Thanks !
    #98
  19. G_Fabio_Andres_Plata_Tor
    Donut Sep 16, 2016
    G_Fabio_Andres_Plata_Tor , Sep 16, 2016 :
    Please, try to take a picture in a dark room, and check if the picture appear good or completely white. thanks
    #99
  20. G_Fabio_Andres_Plata_Tor
    Donut Sep 16, 2016
