15
[ROM] [MOD] 4.4.2 ColorOS v.2.0.35_Beta
  1. rikardo1979
    Community Veteran Nov 21, 2014
    rikardo1979 , Nov 21, 2014 :
    here is my mod of 4.4.2 ColorOS v.2.0.35_Beta
    • easy to root
    • recovery updating script removed
    • removed chinese apps
    • added android keyboard
    • added OPPO Find7 camera+all plugins
    • added international theme market
    • changed default DPI to 380 (really nice) [custom launcher recommended as the default can be buggy with this settings]
    • some tweaks in audio (louder earphone speaker, microphone sensitivity turned UP)
    Files to download
    A0001ROM_12_OTA_021_all_R1213_wipe_RD.zip 644.7MB
    root_find7_2.0.0i_supersu_2.14_rdis.zip
    Official PA-Micro Modular GAPPS - original thread
    1. flash the rom - (Clean install needed= Wipe Dalvik Cache+System+Data+Cache)!!! So make sure you have a backup!!!
    2. setup the phone after first reboot
    3. boot to recowery
    4. flash root - root_find7_2.0.0i_supersu_2.14_rdis.zip
    5. flash gapps - Official PA-Micro Modular
    6. wipe chache+Dalvik
    7. reboot
    8. start SUperSU and update normally
    9. reboot
    10. sett you Google account
    11. enjoy
    For those who would like to stay od default launcher and to use the default widgets, as mentioned you need to set default DPI back.
    So how to do?
    get any file manager, like Root Explorer and edit this file
    /system/build.prop
    quote the line ro.sf.lcd_density=380 with # or remove it
    Than reboot and all should be back to default
    [​IMG] [​IMG] [​IMG]
    ptran, biltoad, mcsememo and 12 others like this.
  2. Scann69
    Honeycomb Nov 21, 2014
    Scann69 , Nov 21, 2014 :
    Question....after flashing gapps, does it break the stock calendar? I can't launch the stock calendar from the calendar widget.
  3. rritambhar
    Jelly Bean Nov 21, 2014
    netr0pa likes this.
  4. rikardo1979
    possibly, I have not tested this as I use google one and also I do not use the stock launcher so means I dont use the default ColorOS widgets
  5. rritambhar
    rritambhar , Nov 21, 2014 :
    quick question :) is it based on the official release ?
  6. rikardo1979
    yes, as mentioned at the first line ;)
  7. rritambhar
    sorry,dumb me :oops:
    great work! one last question, since it is based on 4.4.2, can i use the supported franco kernel(for 4.4.2) with it?
  8. rikardo1979
    not sure to be honest
    you have to test yourself, but should be OK.
    as usual, no responsibility here and make sure you have a proper backup ;)
    rritambhar likes this.
  9. rritambhar
    u shall not be taken responsible for this ! u have my word buddy :) i will try it tonight.
    rikardo1979 likes this.
  10. Scann69
    If you know how to link the stock calendar after flashing gapps, that would be wonderful.
    Also, are you able to get google location to work correctly?
    I did write to the Chinaman in the Chinese forum to check if he is able to get gapps to work correctly....still waiting for his reply :p
  11. rikardo1979
    not sure about calendar, dont have much time for this
    and what do you mean by problems with location? seems to be working fine here. can you evaluate in detail please?
  12. Scann69
    Well....normally when you move from one place to another, the weather app will be able to location you and update the weather based on your location (this is without turning on GPS).
    In this case, it does not work with ColorOS + gapps. Location is not working based on Wifi + Mobile Network.
    Hope you know what i'm trying to say
  13. relic242
    KitKat Nov 21, 2014
    relic242 , Nov 21, 2014 :
    no problem (battery saving mod)
    biltoad likes this.
  14. rikardo1979
    biltoad likes this.
  15. Scann69
    I did....but still no go.
    To test....download Waze from Playstore then run the app. See if it detects your location without GPS turned on.
    And while you are testing with Waze, press the home button and wait for about 5 seconds...see if Waze gets terminated on it's own.
    This COS is great but I've notice these few bugs from the early 4.3 beta and now 4.4.2 beta so just wondering if it's just me or others are having this issue. It's not a deal breaker....just checking ;)
    Thanks for the reply guys.
  16. gaster
    Moderator Moderator Nov 21, 2014
    gaster , Nov 21, 2014 :
    Good job m8. I supposed in the default launcher there is no app drawer right?
  17. rikardo1979
    no there is not
    I prefer Apex but you can install what ever you like, Nova, etc..
    biltoad likes this.
  18. jackdsparker
    Ice Cream Sandwich Nov 21, 2014
  19. rikardo1979
    well, when you launching Waze there is a warning information that it requires High accuracy, so means GPS+WiFi(data)
    Screenshot_2014-11-21-18-38-56-670.png Screenshot_2014-11-21-18-39-10-25.png
    Scann69 likes this.
  20. madeferro
    Eclair Nov 21, 2014
