144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. BOSSPDA
    Jelly Bean Jan 14, 2015
    BOSSPDA , Jan 14, 2015 :
    You are the man! Thanks a lot for your devotion and comitment.:p:p:p:p
    So easy, but we have to know first.;):p
    relic242 likes this.
  2. BOSSPDA
    @relic242 I did the prodecure but the automatic localization doesn't work. I don't know why, but the gps service doesn't start when I choose the automatic position. Only leaves choose citys by add, by the same way before the procedure. I think the app works with framework. What do you think about it? I remeber that in 2.0.4i when OppoWeater is open, to automatic localization, the GPS icon apears in status bar.
  3. peppebi
    Froyo Jan 14, 2015
    peppebi , Jan 14, 2015 :
    The ROM is stable and the camera app is amazing but I have poor battery life compared to cm11s. I don't succeed to cover 8am to 6 pm; with cm11s at 6pm the phone had half battery left. Is this normal? I have tried to wipe dalvik and cache but nothing changed.
  4. Hassan_Abdul
    KitKat Jan 14, 2015
    Hassan_Abdul , Jan 14, 2015 :
    Did you do a clean install? Usually a problem like yours happens after dirty flashing.
    I did a clean install and can not complain about battery life
  5. peppebi
    Froyo Jan 14, 2015
    Yes, clean install. Full wipe than os installation, boot, configuration, reboot recovery, update 5 installation, dalvik and cache wipe and reboot.
  6. uomoint
    Eclair Jan 14, 2015
    uomoint , Jan 14, 2015 :
    try using amplify module in exposed e greenify
  7. vladson
    Eclair Jan 14, 2015
    vladson , Jan 14, 2015 :
    relic242, thanks again for the beautiful transparent weather widget with white font. May I ask you to
    make it absolutely perfect (at least for me :) ) and somehow remove the gray circle which serves as a backgroud for the arrows updating the weather? (thus leaving only the arrows). I mostly to use dark wallpapers and the gray circle stands out too much. Thank you!
  8. relic242
    KitKat Jan 14, 2015
    relic242 , Jan 14, 2015 :
    How to easy backup and restore installed apps in ColorOS /in few mins/ with KeKeMarket:
    /translated KeKeMarket if need.../
    1.Open KeKeMarket
    2.Go to My Profile
    3. Open Software backup
    4. Choice one:
    a) Software to be backed up /need backup some apps there - it backed-up selected apps somewhere in internal storage/
    b) Backed-up software /use this after full wipe install ROM to restore selected apps, disable verify apps by google - in Google settings/
    ...2 mins take to restore cca 30 apps /test example/
    Makova, eocampos and Korazza like this.
  9. relic242
    KitKat Jan 14, 2015
    you are right /only one time get me auto loc./... test full wipe install modified ROM /and it dont work/...
    (work only manually - add city)
  10. hoangtu2410
    Donut Jan 14, 2015
    hoangtu2410 , Jan 14, 2015 :
    me too here . Tried everything, only have 3 hours SOT . This is the final problem
  11. BOSSPDA
    So, it's not possible to fix. Nor using the 2.0.4i app?
  12. relic242
    KitKat Jan 14, 2015
    i tested weather app from 2.0.4i - didnt work too
  13. relic242
    KitKat Jan 14, 2015
    use greenify... no problem 5 hrs
  14. hhrocha_00
    Gingerbread Jan 14, 2015
  15. BOSSPDA
    Bad news. Thanks.
  16. BOSSPDA
    Tadiks likes this.
  17. BOSSPDA
    @relic42 any chance to fix Messages.apk recognize incoming SMS, when the contact didn't use country code? I think we have to create a exception in code to recognize the number with country code as same number without it. Any ideas?
    Tadiks likes this.
  18. BOSSPDA
    How to change the name of mobile company to show in Bluetooth car kit? With CM roms the name correct is showed. But in COS it shows the old name and is so big that is impossible to show complete in Bluetooth car kit screen.
    I post a scree of the field.
    Screenshot_2015-01-14-20-46-32-744.png Screenshot_2015-01-14-20-46-51-639.png
    The correct name is meo not telecomunicações móveis nacionais
  19. delpinsky
    Ice Cream Sandwich Jan 14, 2015
    delpinsky , Jan 14, 2015 :
    Using the 3.0.0.6 I receive sms.
    I tried sending myself an sms through the website of my email and I got it. A pop-up opened with the text.
    Oh, by the way I don't use the default sms app. I use Messenger by Google.
    But I see the default app has the text I sent, so it works.
  20. EvoDemon
    Cupcake Jan 15, 2015
