144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. rubenito77
    Gingerbread Jan 23, 2015
    rubenito77 , Jan 23, 2015 :
    Hello.
    Sorry for my English , but it is google traslated .
    I am not able to art by the runtime .
    When I give to accept , the phone restarts, but no optimizes applications at startup, and does not change
    You know they can be.
    Thank you very much everyone.
    Screenshot_2015-01-23-10-05-10-786.png Screenshot_2015-01-23-10-05-30-291.png
  2. relic242
    KitKat Jan 23, 2015
    relic242 , Jan 23, 2015 :
    ART works ok /2.0.43i/ - bug is in show % optim. apps bar after reboot /try eng. language and you will see it/
    rubenito77 likes this.
  3. rubenito77
    Yes, i have 2.0.43i.
  4. relic242
    KitKat Jan 23, 2015
    change phone language to english and select ART /you will see working optim. bar after reboot - its only transl. bug/
  5. rubenito77
    I did , but still the same .
    The only change I've noticed is asking me 2 times the pino_O
    I'm working . I'll try at home with calm
  6. relic242
    KitKat Jan 23, 2015
    Warning!!!
    Never apply OTA updates on modified ROM /you can very easy brick your device - it's only for info about new incoming firmware updates/ !!!
    Latest ColorOS 2.0.44_beta
    - source - orig. ROM
    md5:92269a9823acd4f08ad0c57c1719faec
    Modified ROM:
    ColorOS_244_pure.zip - mirror google drive
    md5:b4b15d4384d5fad5fd7fef086e6810e6
    Changelog:
    - only base modifications - /it takes 2-3 days to add more languages - decompiling, modifying, re-compiling, testing.../
    - added gapps, Pacperformance, rebooter
    - full root (SuperSU 2.40)
    - added google keyboard 14.12.2014 /fix settings.apk, SettingsProvider.apk - to show it after first boot/
    - replaced OneplusTuner, KeKeMarket, ThemeMarket /eng/
    - removed some chinese apps
    - prepared to use new camera /Oppo Find 7, inc. supermacro/
    - disabled Auto cleaning memory by default /Settings - Apps/
    - enabled install. apps from Unknown sources /disabled by default/
    - disabled google verify apps /enabled by default/
    - added ART mode to Develover options
    - disabled OTA /deleted OTA.apk/
    Install /TWRP/:
    - for sure check md5 /after downloading ROM/
    - backup installed software /easy backup & restore - KeKeMarket - guide/
    - goto recovery
    - full wipe /except internal storage, otg usb/
    - reboot to system
    - restore apps from backup - KeKeMarket
    - done
    Update:
    new KeKeMarket v.3.8.2 /eng./ - download /twrp install/
    OppoCamera.apk - mirror google drive /newest from Oppo Find 7 - normal install/
    mcsememo, ma9ic32, mikeniccy and 5 others like this.
  7. gilvanio motta
    Froyo Jan 23, 2015
  8. gilvanio motta
    Froyo Jan 23, 2015
    gilvanio motta , Jan 23, 2015 :
    well, i´m still waiting for komprado´s n3 port at xda... but i ´ll make this "great effort" to install .44...rs
  9. Korazza
    Donut Jan 23, 2015
    Korazza , Jan 23, 2015 :
    Thanks Relic!!Really Ultrafast release!
    ...Weather widget working now for auto location?
  10. relic242
    KitKat Jan 23, 2015
    still no :(
  11. kingcedz
    Ice Cream Sandwich Jan 23, 2015
    kingcedz , Jan 23, 2015 :
    no offence but colorOS is a bad bad choice.
    It was bad when Oppo first developed it, and not a single release of it is up to standard.
    what's wrong with sticking with a vanilla android version?
  12. gilvanio motta
    Froyo Jan 23, 2015
    im using colors for 5 months and i´m sorry, i´m very happy with it.
    i have to thank all the people that is working hard to keep this forum, no matter what people say about colors.
    Shrapnelist, ma9ic32, ronclon and 4 others like this.
  13. vladson
    Eclair Jan 23, 2015
    vladson , Jan 23, 2015 :
    What's happen to the icons that used to be located at the bottom of Music Widget?
    Last two updates do not seem to show these. Or is it only me?
  14. relic242
    KitKat Jan 23, 2015
    i dont want unstable OS!!!
    ma9ic32, Hassan_Abdul and rubenito77 like this.
  15. heeroluca
    Froyo Jan 23, 2015
    heeroluca , Jan 23, 2015 :
    Have you installed xposed? If yes art will noto optimaze you app and won't work
    rubenito77 and relic242 like this.
  16. rubenito77
    Ooooole!!!!.
    Thanks
    heeroluca likes this.
  17. heeroluca
    Froyo Jan 23, 2015
  18. Hassan_Abdul
    KitKat Jan 23, 2015
    Hassan_Abdul , Jan 23, 2015 :
    So this is honestly the wrong thread for you :) because this is a color is thread and the people here like the color OS and do not want plain vanilla android, sorry ;-)
  19. delpinsky
    delpinsky , Jan 23, 2015 :
    @relic242
    Have you got the "screen rotation" issue?
    Because I still have it, while a guy from the Italian forum showed me he has no such issue with ColorOS 2.0.43i.
    Actually I got your version 2.0.44 pure installed and to be sure everything was fine, I cleaned the internal storage, but nothing, still the screen rotates in the wrong side.
  20. relic242
    KitKat Jan 23, 2015
    dont have this issue...
    (3.0.0.x had this bug)
