144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. ameen123
    Honeycomb Jan 27, 2015
    ameen123 , Jan 27, 2015 :
    Honestly I just changed to a different ROM as no one responded to me a couple of days ago. Now I miss coloros but the one problem was the notifcations, is it a known bug? You think that will lfix it?
  2. ameen123
  3. relic242
    KitKat Jan 27, 2015
    relic242 , Jan 27, 2015 :
    i dont have problems with notifications...
  4. ameen123
    What can I do to get notifications , can u link me to the version u have downloaded. Any extra steps to flash the ROM I should take?
  5. eocampos
    Jelly Bean Jan 27, 2015
    eocampos , Jan 27, 2015 :
    By default, you would say that any app is "blacklisted" so any of them can't use your data connection and consume RAM/CPU if idle.
    First, you should disable Data Protection (see Security Center app) so any app can't access data network or wifi by itself. Another option is to whitelist your trusted apps (this is what I do).
    Second, you should disable Permission monitoring (see Security Center > Permission) or leave it enabled and whitelist the apps you trust adding them to Auto-start management list.
    HTH.
    relic242 likes this.
  6. khantariquealam
    Ice Cream Sandwich Jan 28, 2015
  7. relic242
    KitKat Jan 28, 2015
    relic242 , Jan 28, 2015 :
    must have Oppo Camera from Find 7 (plugin version, no stock Oneplus One COS camera), if yes - try install plugin and you will see..
  8. khantariquealam
    khantariquealam , Jan 28, 2015 :
    Thanks @relic242 I had oppo camera plugin and this install this plugin...I didn't see any update..showing already install plugin... :( ... I don't know what special I got from this
  9. relic242
    KitKat Jan 28, 2015
    after installing apk - open camera, open plugins /press + to add plugins/ and install Picture plus
  10. khantariquealam
    It is not showing this plugin...see this screen...Also whenever I open front camera..it's goes to black screen and plugin is beutify...when I switch to normal then show my pic :(
  11. CBpbxEcmecmBeH
    Jelly Bean Jan 28, 2015
    CBpbxEcmecmBeH , Jan 28, 2015 :
    Hi @relic242 can you do the same with microspur camera's apk? Or that's a different story? Thanks!!!!
    Btw, is there a difference between PicturePlus that and Ultra HD?
  12. relic242
    KitKat Jan 28, 2015
    Microspur plugin is included in my ROM...
  13. psalex
    Froyo Jan 28, 2015
    psalex , Jan 28, 2015 :
    Has that rom bugs? (no wifi,bluetooth?)
    and Wich lanuages has that rom? (only chinese and english?)
    Thank you :)
  14. relic242
    KitKat Jan 28, 2015
    Ultra HD - 50/24 mpx photos
    Picture Plus - 13 mpx photos /CM11s - Clear picture/
    tripod is required to use these camera mods
    CBpbxEcmecmBeH likes this.
  15. relic242
    KitKat Jan 28, 2015
    ...the same as international COS from Oppo Find 7 /2.0.4i/
    Bugs?
    - robotic voice tts google maps /3rd navig. app are ok - sygic, waze... or so/
    - identification of incoming call /local vs international numbers format/
    its Beta, but very stable...
    maybe too old Oppo Camera /use newer one, or install last build ROM/
    psalex likes this.
  16. Trusconi
    Trusconi , Jan 28, 2015 :
    I have the plugin...
    I don't know why cam is in Chinese but phone is in Italian
  17. relic242
    KitKat Jan 28, 2015
    - missing ital. translation /then show all - chinese + eng :) ... a little bad coded app/
    if you switch phone lang. to eng. - it show only eng. descript.
    Trusconi likes this.
  18. khantariquealam
    I used newer one plugin...but no sucess..I think I need to install last build rom...Is last rom contains gapps + colorui + rom?
  19. relic242
    KitKat Jan 28, 2015
    yes, gapps, colorui, ART, smoth scroll mod... etc: link /added languages from international Oppo Find 7/
    full changelog
  20. Trusconi
