144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. alex inthi
    Ice Cream Sandwich Jan 29, 2015
  2. uomoint
    Eclair Jan 29, 2015
    uomoint , Jan 29, 2015 :
    Hi @relic242 , is it possible to have carrier icon of "vodafone italy", as in komprado version. In your version is not present. Thank you
  3. relic242
    KitKat Jan 29, 2015
    relic242 , Jan 29, 2015 :
    its better i think...
  4. Trusconi
    Jelly Bean Jan 29, 2015
    eocampos likes this.
  5. apersonnamedmike
    Honeycomb Jan 29, 2015
    apersonnamedmike , Jan 29, 2015 :
    I think that the CyanogenMod is good. If the OnePlus ROM ends up being so fantastic that there's no question, I might switch over to that one, but until then, I think I'm sticking with Cyanogen
  6. loler95
    Donut Jan 29, 2015
  7. Trusconi
  8. Trusconi
    Trusconi , Jan 29, 2015 :
    45.5K antutu :cool:
    Restore app through Gmail account was easy :D
    If keep pushed "home" on lock screen flash light goes On :eek:
    If keep pushed "home" when screen is on phone will be locked and start greenify o_O
  9. ronclon
    Honeycomb Jan 30, 2015
    ronclon , Jan 30, 2015 :
    Wow relic, this ROM is awesome. Love the music player and camera. Theme store works great. This is my new ROM. Loving it.
    relic242 likes this.
  10. ronclon
    BTW you should start a new thread for your fix version ROM. Then you could just update the first post with new versions.
  11. Scann69
    Scann69 , Jan 30, 2015 :
    Good for you.....
    badtzmark likes this.
  12. Darkos
    Donut Jan 30, 2015
  13. relic242
    KitKat Jan 30, 2015
  14. RahulKundathil
    Froyo Jan 30, 2015
    RahulKundathil , Jan 30, 2015 :
    Is official beta builds are good to use, than the modded ones.
    Is this rom based on Android 4.4 or its still on 4.3
    I am planning to switch from CM11s, as we cant expect much from Cyanogen anymore
  15. Trusconi
    Jelly Bean Jan 30, 2015
    Trusconi , Jan 30, 2015 :
    Relics are 4.4.4
    F7 port are 4.4.2
    With these rom i have better reception (LTE)
  16. RahulKundathil
    Froyo Jan 30, 2015
    Those are ported ones ??
    what about the official builds, so that I can get weekly updates like Oppo find7.
    What about battery backup and performance compared to CM11s
  17. DaxNagtegaal
    Marshmallow Jan 30, 2015
    DaxNagtegaal , Jan 30, 2015 :
    Can I flash this (clean flash) directly after being on CM12 nightlies or will I have to flash 4.4.2 modem and firmware first? or is it included in this zip? I mean the modded version of ColorOS @relic242 @Trusconi
  18. Trusconi
  19. Trusconi
    I was in your situation
    Clean installed 16/1 CM12 Nightly and unpdated with cyandelta till 24 (flashed also alpha modem)
    You have just to flash the ZIP (2.0.5i or 2.0.44i) after wiped all without SD and OTG
    In the ZIP you have all: rom, gapps,modem, boot animatio, etc
  20. relic242
    KitKat Jan 30, 2015
    relic242 , Jan 30, 2015 :
    if you want OTA - you can use orig ROM - its no problem /but: no root, no gapps, a lot of chinese apps..., chinese orig. recovery... etc - it is unusable i think/
    modem is included in ROM...
