144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. relic242
    KitKat Jan 30, 2015
    shwan, eocampos, Franspain and 4 others like this.
  2. lukesan
    Honeycomb Jan 30, 2015
    lukesan , Jan 30, 2015 :
    Don't forget ... it's also weekend!
  3. relic242
    KitKat Jan 30, 2015
    relic242 , Jan 30, 2015 :
    Latest ColorOS 2.0.1 /2.0.45_beta, first 4.4.4 COS for OPO/ - source - orig. ROM
    md5:21dcf7a0e198723c879c9a7263c8aba2
    Modified ROM:
    ColorOS_2.0.1_pure_fix3.zip - mirror google drive
    md5:09686f56f7a1f1902250f13caa6becac
    ColorOS 2.0.1i:
    ColorOS_2.0.1i_fix.zip - mirror mega
    md5:653ec2b141ddfe4a1b45a7fb57402a7f
    Changelog:
    - only base modifications
    - added gapps (PA GAPPS by TKruzze, 25.1.2015), Pacperformance, rebooter
    - full root (latest SuperSU 2.45)
    - added google keyboard 14.12.2014 /fixed settings.apk, SettingsProvider.apk - to show it after first boot/
    - replaced OneplusTuner, KeKeMarket, ThemeMarket /eng./
    - removed some chinese apps
    - disabled Auto cleaning memory /enabled by default/
    - enabled install. apps from Unknown sources /disabled by default/
    - disabled google verify apps /enabled by default/
    - added ART mode to Develover options
    - Xposed + Flat style colored bar mod
    - enabled Eye protection
    - disabled Voice control
    - fix - fixed 50 mpx camera plugin
    - fix2 - added Ubifocus
    - fix3 - sms fix
    Changes 2.0.1_pure_fix3 vs 2.0.1i_fix:
    - added more languages
    - smoothscroll mod
    - colored settings & systemUI /status bar/
    - changed wallpaper
    - changed mms
    - fixed dialer & contacts
    - removed user center from settings
    - enabled night camera plugin
    - removed YellowPages framework /chinese/
    - new Theme Market
    - other small fixes...
    Install /TWRP/:
    - for sure check md5 /after downloading ROM/
    - backup installed software /easy backup & restore - KeKeMarket - guide/
    - goto recovery
    - full wipe /except internal storage, otg usb/
    - reboot to system
    - restore apps from backup - KeKeMarket
    - done
    Addons:
    - Maxxaudio /TWRP install/
    - patch to remove Maxxaudio /TWRP install/
    Mjo, jussepp, nikku_hot123 and 8 others like this.
  4. dadme
    Eclair Jan 30, 2015
  5. relic242
    KitKat Jan 30, 2015
    delpinsky likes this.
  6. delpinsky
    Ice Cream Sandwich Jan 30, 2015
  7. Trusconi
    Jelly Bean Jan 30, 2015
    Trusconi , Jan 30, 2015 :
    I have a Lot of problem downloading through mega and drive... Could someone make a mirror on androidfilehost? Thanks
  8. delpinsky
    delpinsky , Jan 30, 2015 :
    I wrote you on xda and linked you the guide to change your DNS and make Mega to work from Italy.
    *leggi la guida :) è facilissimo cambiarli (very easy to change them)
    edit:
    if you already did and you still have problems, try using jdownloader and paste the link of Mega there. See if it helps, because here Mega goes at max speed.
  9. Trusconi
    Thanks for your help
    Ho problemi solo con coloros
    Da PC va
    Con Cm12 va
    Cmq grazie
  10. vijay_ar
    Froyo Jan 31, 2015
    vijay_ar , Jan 31, 2015 :
    Hey Relic, installed your latest version, sending receiving SMS is not working. Problem with weather app location, still have to manually put the city and the weather theme reverts to default skimming theme.
  11. relic242
    KitKat Jan 31, 2015
    relic242 , Jan 31, 2015 :
    New camera plugin (latest COS 2.0.1):
    UBIFOCUS
    (Technical principles UbiFocus actually not complicated, simply, is the phone to shoot different focal lengths, different focus of multiple photos, and then synthesized to form one can choose to focus photos.
    UbiFocus similar technique in fact we do not unfamiliar, before more high-end Lumia handsets have re-focus function, as well as HTC One (M8) utilizing dual cameras offer similar features, of course, the performance of such functions is the most professional Lytro light field camera.)
    fix_ubifocus_camera.zip /TWRP install/
    ColorOS_2.0.1_pure_fix2.zip (build inc. ubifocus)
    Screenshot_2015-01-31-06-59-43-905.png 126.jpg 127.jpg 218.jpg implementing-computational-camera-11-638.jpg
    lukesan and neotoky like this.
  12. relic242
    KitKat Jan 31, 2015
    you are right... /they have a bug -> mms.apk - replaced from 2.0.44i/
    sms_fix.zip /TWRP install/
    uploading fixed build...
    done>
    neotoky likes this.
  13. Trusconi
    Jelly Bean Jan 31, 2015
    Trusconi , Jan 31, 2015 :
    Thanks to @delpinsky
    I can download with Mega if I select desktop version in Chrome :cool:
  14. FamouzUnique
    FamouzUnique , Jan 31, 2015 :
    WIth this build i got a issue with the front camera, i don't see anything when i turn on front camera, but when i capture a image the image comes up just fine..
    please check and get back to me thanks :)
  15. relic242
    KitKat Jan 31, 2015
    dont have this problem... (install ROM with full wipe except int. storage)
  16. alex inthi
    Ice Cream Sandwich Jan 31, 2015
    alex inthi , Jan 31, 2015 :
    In message app why it makes 2 views from single number. One with Saved Name and other with country code. Any fix?
  17. alex inthi
    Yup. Latest builds camera works fine.
  18. relic242
    KitKat Jan 31, 2015
    try sms fix if you dont have fix3 build...
  19. vijay_ar
    Froyo Jan 31, 2015
    Relic missing the colored icons in the Setting Menu that was in earlier version
    "white is boring " :)...Any help here ?
    Also fix3 is with all the cam updates or do i have to flash independently ?
  20. CBpbxEcmecmBeH
