144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. Vector
    Jelly Bean Oct 26, 2014
    Vector , Oct 26, 2014 :
    That works for me, but if you're referring to holding down the home button type of launch, I don't have that working on mine. I haven't investigated that yet though.
  2. maskelisuvari
    Cupcake Oct 26, 2014
    maskelisuvari , Oct 26, 2014 :
    Could somebody let me know how i can flash Color Os by Msm8974 Download Tool? I have some network problems and i need to get back to first day of OPO i bought.I think some problems occoured Color Os to CM11s.I hope i can solve it by Msm8974 Download Tool flashing Color OS .Thanks in advance.
  3. Maica
  4. topfreitas
    Froyo Oct 26, 2014
    Maica likes this.
  5. Maica
    Maica , Oct 26, 2014 :
    search does work
  6. Vector
    mikeniccy likes this.
  7. maskelisuvari
  8. Vector
    I have test flashed this ROM probably a good 50 times now and haven't run into any issues. Did you backup? You might want to attempt a restore if you did. You can also attempt to connect to WIFI and go into settings to ensure that your APN is updated to the latest version, it will auto update if you have WIFI on so it can connect. Also double check your sim card is securely in place.
    If all else fails, you can try this tutorial on XDA which is used to fix multiple issues: http://forum.xda-developers.com/oneplus-one/help/fix-brickloop-audio-fx-fc-efs-corrupt-t2879061
    topfreitas and Maica like this.
  9. maskelisuvari
    @Vector
    Yes i have the backup.I dont think the problem is your rom,the problem is my OPO.When you lost your imei you cannot connect to wifi eighter,thats the beauty :).I try to flash color os by msm8974 download tool.
    Maica likes this.
  10. Vector
    New version!
    So what's new?
    Fixed NFC bug
    AND if you're ready for kick *** sound we now have...
    Waves MAXX Audio. This one took a while to figure out. Hope you all enjoy this one. I was really looking forward to porting this one over from the find series.
    Now you have an awesome camera and awesome sound. :)
    I'm tired, but if anyone wants to write a tutorial on how they got everything working for the noobs, might be helpful to some.
    A few pics:
    Screenshot_2013-12-31-11-10-01-891.png Screenshot_2013-12-31-11-10-32-50.png Screenshot_2014-10-26-04-47-25-100.png
    Enjoy!
    https://mega.co.nz/#!GhBD3CJK!Q54dfabGHBnI2CsY6r1lxR5vc8f6iFx16sT9-DB7CKM
    mikeniccy, relic242, 9600pro and 2 others like this.
  11. Maica
    Thanks
    you're great!!!
  12. liop
    Eclair Oct 26, 2014
    liop , Oct 26, 2014 :
    Hello
    I'm on Miui and I want to try Color OS.
    Can I just flash the zip files in philz recevery ?
    Thank you for your help.
  13. Tadiks
    Tadiks , Oct 26, 2014 :
    turned on...
  14. Tadiks
    also in new version the same, its always opening task manager... any idea?
    p.s. its happening only for me?
  15. chintanv
    Eclair Oct 26, 2014
    chintanv , Oct 26, 2014 :
    Hey @Vector
    Could you link me to the post where you have mentioned instructions to flash your version of the ROM? Many thanks!
  16. chintanv
    Eclair Oct 26, 2014
    @Vector man you are killing it. These are awesome features.
    This may have been asked before, but do these builds feature the ultra-hd 50Mp mode in the camera app?
    Vector likes this.
  17. topfreitas
    Froyo Oct 26, 2014
    Vector likes this.
  18. relic242
    KitKat Oct 26, 2014
    chintanv likes this.
  19. chintanv
    Eclair Oct 26, 2014
    Is mega not working for anyone else? A mirror on Google Drive would be so much better!
  20. Vector
    Was working ok when I checked it, but if anyone wants to mirror and share, I'm ok with that.
