144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. rikardo1979
    Community Veteran Nov 21, 2014
    shwan likes this.
  2. rikardo1979
    rikardo1979 , Nov 21, 2014 :
    if you want good panorama pictures with good selection of modes, definitely get the google camera. others I have tested are not even close to it, if is CM camera, or others
  3. madeferro
    Eclair Nov 21, 2014
    madeferro , Nov 21, 2014 :
    Its your camera version from ColorOS 4.4.pre_RD_mod
  4. aakashjhaveri
    Lollipop Nov 21, 2014
    komprado likes this.
  5. lukesan
    Honeycomb Nov 21, 2014
  6. shwan
    Froyo Nov 21, 2014
  7. relic242
    KitKat Nov 21, 2014
    relic242 , Nov 21, 2014 :
    1.Untouch version /replace recovery!!!/
    A0001ROM_12_OTA_021_all_R1213_wipe.zip
    md5:0719bb7b470fa41cb33627c40a7256bb
    https://mega.co.nz/#!BN1nCTLD!SWcoka2tkulZ6aZM1dXzloFBPmWhAm78PVBswtk2PUs
    2.Modified version
    - removed directory /recovery
    - removed check device name from update-script
    - removed replacing recovery
    md5:830a36813ed83193482572f637546fe8
    https://mega.co.nz/#!MRtxRarJ!sMUQQUKiDpoiIRWXBjKk4Glj7Z4VPyNEjeyBmX94lcc
    modified version /tested twrp install - 100% work/
    working gapps (for example):https://www.androidfilehost.com/?w=files&flid=15803
    working root:
    1. Download on phone non full root zip file root_find7_2.0.0i_supersu_2.14_rdis.zip
    2. Press Volume DOWN + Power
    3. U should see TWRP Recovery Menu.
    4. Pick install and find root_find7_2.0.0i_supersu_2.14_rdis.zip and flash it.
    5. Reboot the phone. (cash and davlik wipe not nessesary)
    6. Update binaries by clicking 'normal' method in SuperSU app.
    7. Copy "su" file from xbin to bin in system folder:
    7.1 Download android terminal and write:
    Code:
    su
    cp /system/xbin/su /system/bin/</code>
    7.2 Download any root explorer change inside from Read-only to Read/Write and copy file "su" from:
    /system/xbin/
    to
    /system/bin/
    8. Reboot your phone.
    9. Phone is rooted.
    source
  8. shwan
    Froyo Nov 21, 2014
    shwan , Nov 21, 2014 :
    That was really quick - Many thanks.
    Do you know if the COS 4.4 betas create partitions, I am missing 10GB of internal storage since I flashed one of the betas and it's driving me mad?
  9. relic242
    KitKat Nov 21, 2014
    64GB /10 GB take a system - same as CM11s/ and where is a problem?
    shwan likes this.
  10. shwan
    Froyo Nov 21, 2014
    My storage used to show up more than 54GB, which is what I am getting now. I panicked after I had the invalid NV partition message on one of the last COS betas o_O
  11. shwan
    Froyo Nov 21, 2014
    One more query. Why do people who modify and repack the COS betas, like @komprado @Vector and @relic242, still include the modem, boot logo...etc from the official betas? The modem on a 4.4 beta, for instance, broke my proximity sensor. Can't we just have the firmware flash on it's own?
    Please forgive my technical ignorance!
  12. donalgodon
    Ice Cream Sandwich Nov 21, 2014
    donalgodon , Nov 21, 2014 :
    No, because it has dependent libraries from Color OS.
  13. rikardo1979
    these are "untouched" ROMs. basically its same as official source with a really little mod, like removed recovery update. etc
    but core is untouched
  14. netr0pa
    Jelly Bean Nov 21, 2014
    netr0pa , Nov 21, 2014 :
    The official one doesn't allow to work with MultiROM and a lot of people are interested into installing cm11s parallel with color os in order to get the amazing camera and a familiar system in cm11s
  15. relic242
    KitKat Nov 21, 2014
    this appears only on ROMs from komprado...
    shwan likes this.
  16. lukesan
    lukesan , Nov 21, 2014 :
    Ok guys this is not funny. Flashed again clean and getting this on Antutu ... check screenshots.
    This is my last request to just do the test and compare against my results. I thought we were here to help and share ... so
  17. shwan
    Froyo Nov 21, 2014
    Does the method below not work (same source)? it seems less complicated.
    III.A METHOD:
    1. Press Volume DOWN + Power
    2. U should see TWRP Recovery Menu.
    3. Pick install and find file JaCh0o_KG3.4.0.zip and flash it.
    4. Reboot the phone. (cash and davlik wipe not nessesary)
    5. Phone is rooted. (Check is there working Kingroot app, you can delete Explorer app)
    Thanks
    netr0pa likes this.
  18. relic242
    KitKat Nov 21, 2014
    maybe yes but i dont like kinguser :)
    shwan and rikardo1979 like this.
  19. netr0pa
  20. shwan
    Froyo Nov 21, 2014
