144
[ROM][OFFICIAL][4.3] ColorOS V.2.0.0_Beta
Thread Status:
Not open for further replies.
  1. vladson
    Eclair Dec 12, 2014
    vladson , Dec 12, 2014 :
    Thanks for the tip, relic242, will try it, even thought i seem to start taking to the new theme :)
  2. Darkos
    Donut Dec 12, 2014
  3. toplevel
    Donut Dec 12, 2014
    toplevel , Dec 12, 2014 :
    flashed and work like a champ.... btw, should I get grant system uid root access when prompted after reboot?
    Many thanks...
  4. relic242
    KitKat Dec 12, 2014
    relic242 , Dec 12, 2014 :
    denied or not (dont see any dif., i set denied...)
  5. toplevel
    Donut Dec 12, 2014
    Thanks.... BTW the build in video app having fc problem....
  6. relic242
    KitKat Dec 12, 2014
    Screenshot_2014-12-12-19-54-37-473.png Screenshot_2014-12-12-19-54-44-366.png
    thx... (there are propably some connections with removed chinese applications)
    solution /hot fix/:
    delete:
    root:system/app/VideoGalley.apk
    install:
    (the same app from 2.0.37 - but working ok):
    VideoGallery.apk
    ROM fixed - link updated
    Dr.Now likes this.
  7. Dr.Now
    Honeycomb Dec 12, 2014
  8. relic242
    KitKat Dec 12, 2014
    use root explorer or xplore and edit build.prop:
    root:system/build.prop
    remove (uncoment) "#" from line:
    # ro.sf.lcd_density=380
    and save... (grant root access for this app)
    restart phone
    done
    (FYI - stock launcher has sometimes a problem with changed DPI)
    i use 400... (apex launcher)
    Dr.Now likes this.
  9. toplevel
    Donut Dec 13, 2014
  10. wrezanoor
    Gingerbread Dec 13, 2014
    wrezanoor , Dec 13, 2014 :
    I like the way my CM11 looks and feels. My question is if I change ROM, and want to come back to CM11 all my settings and data will be retrieved? Or is there any chance for it to go wrong?
  11. alex inthi
    Ice Cream Sandwich Dec 13, 2014
  12. alex inthi
    alex inthi , Dec 13, 2014 :
    Still colored toggle icons remain. How can I change it to default
  13. relic242
    KitKat Dec 13, 2014
    relic242 , Dec 13, 2014 :
    Copy and replace (from orig.):
    root:system/priv-app/SystemUI.apk,
    root:system/priv-app/Settings.apk
    Maybe you get FC (its ok), but restart phone... done
    Modified Anysys ROM:
    Anysys-Coloros2.0.38_mod.zip
    /gapps.../
    lukesan likes this.
  14. tainguyen2704
  15. alex inthi
  16. relic242
    KitKat Dec 13, 2014
    tainguyen2704 likes this.
  17. jarevalo
  18. alex inthi
    It worked. Now its better. Thank you :)
    relic242 likes this.
  19. tzadka
    Donut Dec 13, 2014
    tzadka , Dec 13, 2014 :
    Thanks for the rom. It's the only one that works stable on my device.
    Does anyone know what's the difference between this rom and the CM based, that only Color OS works good?
  20. netr0pa
    Jelly Bean Dec 13, 2014
